bird blaster Samba Member
Joined: June 04, 2018 Posts: 49 Location: Ontario, Canada
Posted: Mon Jun 18, 2018 4:52 am Post subject: Help with chrome Molding hood replacement |
Long story short. I found me the VW that will suit most of my needs and in my price point. An absolute must for me was matching numbers including motor. I found that in my 1963. The hood on this car looks to have had some work including a repaint. The chrome molding has been changed, and incorrectly for the thin type. I have ordered the right one in stainless from WW including the appropriate mounting hardware. I had a few questions to hopefully avoid trouble. Are the hole sizes different in the hood to accommodate the clips for thick vs thin? How do I take the chrome off easily? I saw some good videos on how to put it on, so I think I have that covered.
Thanks!
I hope to post more pics when the car arrives.
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Mon Jun 18, 2018 7:44 am Post subject: Re: Help with chrome Molding hood replacement |
The hole sizes are bigger for the wide trim. Use a wood/plastic gizmo to pop off the narrow trim. If the hood is in decent shape consider selling it as it might be a one year only 67 hood and buy a different hood your bug. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Mon Jun 18, 2018 8:44 am Post subject: Re: Help with chrome Molding hood replacement |
I fully agree with Rick ^^^. It's clear it's been repainted (perhaps) to L380 code- but not to match the fade of surrounding metal.
It's value to a '67 restorer would finance the repaint of a proper hood. Also, you can determine if your car was supposed to have a Wolfsburg crest by looking up your VIN's range in the progressive refinements listing. _________________
EverettB wrote: |
FU#5 |
Posted: Mon Jun 18, 2018 10:55 am Post subject: Re: Help with chrome Molding hood replacement |
Thank you!
Is there a way that I can tell if it is a 67? I’m not that familiar yet with being able to spot the differences.
For a good hood. What years will work? Ie) 61-65? The VIn is 5143xxx so I do not believe it should have Wolfsburg crest. |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11056 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
Posted: Mon Jun 18, 2018 12:27 pm Post subject: Re: Help with chrome Molding hood replacement |
.. before we all get too excited here..
#1.. figure out if it's original 67 hood.. if it's not.. . no Original Oppressors would want it.. repop hood of years past had small trim holes.. or no holes at all..
Here is an OO 67 hood topic reference
https://www.thesamba.com/vw/forum/viewtopic.php?t=578083
#2 For a 63.. for the MAJORITY of the model year build.. you would typically want to find a raised platform hood for the VW larger 3 pin emblem, with large trim holes... 1963-1966.
Now..
#3
If your 63 just so happened to have been built.. in the first two months.. (August September 1962 , ending at/on VIN 5010447) you would want to find a "1962 Hood"
Flat emblem area, 3 pins and a smaller (4 tab style) emblem.
62 hood topic..
https://www.thesamba.com/vw/forum/viewtopic.php?t=419735
glutamodo wrote: |
That's first TWO months of production - August and September 62, with the crest.
If you find its aftermarket.. and can stand it.. just drill the holes add the wide molding and get on with your life
If it IS an original 67 hood.. and you must change it.. yes it has value.. but it will NOT pay for a good solid correct original hood with the added cost of having it painted to almost never match..
or worse for cost.. .. finding a perfect solid nice sun faded match..
Yeah.. good luck with that last one..
Whew..
Me= Id just drill what ya have, get the molding on.. and drive the damn thing.
But.. from this single statement..
bird blaster wrote: |
An absolute must for me was matching numbers including motor. |
sounds like you want it ..NEED it right.. only you can determine if it's worth the cost and hassle.
. _________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Mon Jun 18, 2018 3:23 pm Post subject: Re: Help with chrome Molding hood replacement |
... when I had my '63 I added an earlier-style Wolfsburg crest... not original, but who cares - looks awesome. i'd just pry that thin one off and put it in my scrap metal pile and add a strip for crest.
... not a bad paint match... could keep it till you found an original replacement.
this was my '63.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK
EVfun Samba Member
Perhaps I missed it reading on a phone, but I never saw information on how to determine if was a real '67 hood. Other than the trim hole size, how can one tell a '66 from a '67 or a decent quality repop?
I would likely open up the trim holes and run early trim, perhaps with a 3 color Wolfsburg crest if I wanted to spend the extra money. Well, unless I had a local friend looking for a correct '67 hood. _________________
Wildthings wrote: |
Posted: Mon Jun 18, 2018 3:40 pm Post subject: Re: Help with chrome Molding hood replacement |
EVfun wrote: |
Perhaps I missed it reading on a phone, but I never saw information on how to determine if was a real '67 hood. . |
I provided a topic link..
Posted: Mon Jun 18, 2018 4:46 pm Post subject: Re: Help with chrome Molding hood replacement |
Here are a few different angles that include the hood. I appreciate the comments guys. I know this car isn't perfect...but I think it is a good start for me and I will over time get it how I want it.
EVfun Samba Member
Posted: Mon Jun 18, 2018 5:30 pm Post subject: Re: Help with chrome Molding hood replacement |
I'd be more than happy to drive that -- nice car!
What are your plans for the car? That will influence how you best move forward. _________________
Wildthings wrote: |
Posted: Mon Jun 18, 2018 5:45 pm Post subject: Re: Help with chrome Molding hood replacement |
EVfun wrote: |
What are your plans for the car? That will influence how you best move forward. |
I'm still debating what to do to be honest. My first goal was a motor matching vehicle. The interior appears to be completely original which is great and as far as I can tell thus far the body is in very good condition. Hopefully I am not wrong on that count.
My options in my mind are
a) Change the chrome strip and move on. Drive it every day in the summer as were my intentions when purchasing the car. Drive it for 5-10 years and sell it to get an Oval that has been completely restored. (Unless I can convince my wife to let me have two).
b) Change the chrome and drive it like in (A) and then after 5-10 years do a complete restoration of the car to what is needed
c) Change the chrome and in 1-2 years get the rest of the body repainted to all the same Turkis colour.
I am still not sure what to do about potentially adding 3-point harnesses in the rear. I would love for my kids (2 & 5) to be able to come with me places. |
Sharp64 Samba Member
Joined: August 27, 2015 Posts: 5304 Location: Central Florida
Posted: Tue Jun 19, 2018 4:46 am Post subject: Re: Help with chrome Molding hood replacement |
I’m sure someone will correct me if I’m wrong but three point seat belts should be a bolt in. There should be attachment points under the rear carpet and the third just behind the quarter window. _________________ 1960 Indigo Blue Ragtop (Blue Barry)
1967 Ghia
1985 Westy Money Pit
“...some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn.” - Michael Caine |
Posted: Tue Jun 19, 2018 6:49 am Post subject: Re: Help with chrome Molding hood replacement |
HAHAHA.. Indecisive are you..
first and foremost .... What month of production is the car?
You didn't state whether its an original 67 hood using the link I provided as a guide.
GOOD original hoods are getting expensive and getting harder to find..
My opinions...
Even if its an original 67.. in good condition.. and If you plan to eventually do a full on repaint refurb resto and don't want to try and hope to find a good 63-66 hood later... .. drill and drive. . the larger clip hole size is 8mm.
If it's aftermarket.. drill it.. add the right molding and enjoy it..
Only a few of the elite snobs .. will point fingers and laugh at you.. .
Then take your time.. and find a the right hood you need, store it for later or have it painted and swap out..
Option..
Remove narrow chrome.. use the proper chrome (or chrome and crest) for month of manufacture.
Dont drill the holes.. use a blob of high quality RTV over each existing clips.. tape it down until cured.. ... done..
Double sided tape may work too.
Saves the hood if it is legit 67.
Posted: Tue Jun 19, 2018 7:53 am Post subject: Re: Help with chrome Molding hood replacement |
... everyone will suggest something different - that's human nature. i'd leave as much original paint as possible showing and repaint what is needed. So, it does not match perfectly... how can that make any kinda' difference... is a beauty, at any rate.
I liked my very original turquoise patina '63. That was natural paint deterioration. Took 50 years to get to that look - too beautiful to update with new paint on the whole car. The guy who bought the car will ruin it and paint one even color He had a problem with being a perfectionist too... that's the way things are - we all have to do what suits us, instead of what's best for the car and future owners - we ARE NOT OWNERS, we are stewards of our cars, for a little while and then someone else takes over, down the road.
... I think it would be a shame to paint your whole car and ruin it's originality, but do what you think is best. _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
All super-heroes, wear a MASK |
EVfun Samba Member
Posted: Tue Jun 19, 2018 5:19 pm Post subject: Re: Help with chrome Molding hood replacement |
It sounds like you are in the high respect for "as VW intended" category. One option seems to be getting ignored. If that is a real '67 hood you could run feel guilt free -- give props to real life by keeping the skinny trim. VW did all kinds of changes that put later parts on older cars. I can find documents on how to put later frames under pre-'60 cars and put automatic chokes onto 36 horse engines. Using a later, and last year that is bolt on compatible, hood to repair from a minor accident is plenty legit, and a good part of your Bug's preservation. You could run it with pride as a good repair on a loved old Bug. _________________
Wildthings wrote: |
Posted: Tue Jun 19, 2018 6:33 pm Post subject: Re: Help with chrome Molding hood replacement |
VOLKSWAGNUT wrote: |
My opinions...
Option..
Month of production is November 1962.
The car wont make it to my house for probably another 2 weeks. So I won't be able to get better pics or see it in person until then to determine if it is a 1967 or repro hood.
I chatted with the previous owner about it and it has been like that for as long as he has owned it. He was never told a new hood was placed on it and always assumed it was the original hood. Is there any way that when it got repainted some boob was able to put on a thin strip chrome on an original 1963 hood?
fantastic ideas for some options that wouldn't ruin the hood either in the case it was a 1967. |
Posted: Tue Jun 19, 2018 6:35 pm Post subject: Re: Help with chrome Molding hood replacement |
ZENVWDRIVER wrote: |
... I think it would be a shame to paint your whole car and ruin it's originality, but do what you think is best. |
great perspective. Definitely food for thought as I digest this whole "dilemma" which is mostly in my mind! haha |
Posted: Wed Aug 15, 2018 6:32 am Post subject: Re: Help with chrome Molding hood replacement |
Car finally arrived!
I'm going to take some more pictures of the hood so you guys can help me out a bit.
I am currently leaning towards just putting on the larger strip chrome.
The paint difference bugs me a bit, any suggestions to dull it a bit?
Thanks
BB |
Littoral Samba Member
Posted: Wed Aug 15, 2018 7:28 am Post subject: Re: Help with chrome Molding hood replacement |
"The paint difference bugs me a bit, any suggestions to dull it a bit? "
Tanning Booth.
More seriously, perhaps over buffing? |
Posted: Wed Aug 15, 2018 7:46 am Post subject: Re: Help with chrome Molding hood replacement |
Littoral wrote: |
Tanning Booth.
hahaha - thanks!!
Once I am home tonight I'm going to snap some more pics of the hood. I just had this on the phone showing the worse of the discrepancy. It isn't as bad compared to the fenders as the area in front the window.
