Fuel Gauge Vibrator and Sender late bay t2b 1973-79 FAQ
Tcash
Tcash is offline
PostPosted: Mon Jun 18, 2018 12:36 pm    Post subject: Fuel Gauge Vibrator and Sender late bay t2b 1973-79 FAQ Reply with quote
To link to this post copy and paste
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=701705&start=0&postdays=0&postorder=asc&highlight=]Fuel Gauge Vibrator and Sender late bay t2b 1973-79 FAQ[/url]
Fuel Gauge and Sender late t2b 1973-79
Quick Test
Disconnect the ignition coil wire during testing.
Check fuses first. Test for power 12 volts at gauge.
Turn the ignition key on and ground (earth) the wire that is on the sender.
Gauge works, sender or sender ground connection is bad.
Gauge does not work, Gauge, vibrator (73-79) or wiring to gauge is bad.
Ground the brown wire at the gauge or vibrator (73-79).
Gauge works, wire to sender is bad.
Gauge does not work replace gauge, Note: (73-79) gauges with vibrator test for power on both sides of vibrator. Vibrator is good replace gauge. Vibrator is bad replace vibrator.
Don't forget to hook the coil back up!
HOW TO: Revive your fuel gauge sender for $1
Fuel Gauge Troubleshooting ('73-'77 Type 2)
http://www.type2.com/library/misc/vwggauge.htm
Late Bay fuel sender calibration values
https://www.thesamba.com/vw/forum/viewtopic.php?t=693930
