greenboat4 Samba Member
Joined: April 04, 2014 Posts: 81 Location: Fort Myers
Posted: Mon Jun 18, 2018 1:24 pm Post subject: Clutch adjustment help |
I have a lowered 1967 bus, flipped spindles on front and 1969 Beetle engine & transmission in the rear.....With the 1969 Beetle engine & transmission in the rear, I can not get my hand up to the wing nut to adjust the clutch cable. There is just NO ROOM to work up there...I need to tighten the clutch cable a little bit....Anyone have any ideas that I can try? |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24733 Location: Olympia Wash Rinse & Repeat
Posted: Mon Jun 18, 2018 4:47 pm Post subject: Re: Clutch adjustment help |
Remove engine.
A. Measure from front of engine case where it mates to the transaxle to the front of the pressure plate.
B. Measure from TO bearing to the rear surface of the transaxle where it mates to the engine case.
B should be about 1/8" (3mm) more than A.
Make a tool to adjust the clutch wing nut and adjust.
Install engine.
Check clutch play. If it needs more adjustment, pull engine and do so. _________________ In Stereo, Where Available! |
Posted: Tue Jun 19, 2018 5:58 am Post subject: Re: Clutch adjustment help |
I heard of wrapping a thin rag around the wing nut and then pulling ....what do you think and another tricks? |
Clara Samba Member
Posted: Tue Jun 19, 2018 6:08 am Post subject: Re: Clutch adjustment help |
If you can't fit your arm up in there, pay a shop.
I don't see much difference in adjusting the clutch on a split bus compared to my 69 bug, so maybe I'm missing something in the question.
If you need more ground clearance, use a jack to create some.
If it is hard to turn the wingnut, use a pair of vise grips on the cable (non threaded portion).
I have a tiny adjustable wrench I use for the wingnut, it gives a little more leverage.
When the engine is out, I make a point of making sure the clutch cable threads are greased and the wingnut is easy to turn... so when it needs to be adjusted it is easier. Sometimes they get rusted stuck which is frustrating to deal with when the engine is in. I've bent wingnut arms.
I need to go adjust my clutch too. |
2Pack Samba Member
Joined: September 20, 2005 Posts: 807 Location: Virginia
Posted: Tue Jun 19, 2018 6:33 am Post subject: Re: Clutch adjustment help |
The older style cable has two nuts, which are fairly easy to reach with ratcheting wrenches.
Maybe you could use a nut like this instead of the wingnut and reach it with a wrench instead? I've never tried it, just a thought.
https://www.thesamba.com/vw/classifieds/detail.php?id=2064736
The size of the threads have varied over the years so be aware of that. _________________ Please buy my Treasure |
Posted: Tue Jun 19, 2018 7:04 am Post subject: Re: Clutch adjustment help |
greenboat4 wrote: |
If you can not get your hand up there, how is a rag tossed over it going to help?? _________________ In Stereo, Where Available! |
Spezialist Banned
Posted: Tue Jun 19, 2018 7:54 am Post subject: Re: Clutch adjustment help |
Eric&Barb wrote: |
greenboat4 wrote: |
If you can not get your hand up there, how is a rag tossed over it going to help?? |
Someone got their hand in there to instal engine. _________________
Posted: Tue Jun 19, 2018 8:22 am Post subject: Re: Clutch adjustment help |
Spezialist wrote: |
Eric&Barb wrote: |
greenboat4 wrote: |
Someone got their hand in there to instal engine. |
Yet OP states " I can not get my hand up to the wing nut to adjust the clutch cable. ". Might be the upper bolts were glued in place. _________________ In Stereo, Where Available! |
Spezialist Banned
Posted: Tue Jun 19, 2018 9:07 am Post subject: Re: Clutch adjustment help |
Eric&Barb wrote: |
Spezialist wrote: |
Eric&Barb wrote: |
greenboat4 wrote: |
Yet OP states " I can not get my hand up to the wing nut to adjust the clutch cable. ". Might be the upper bolts were glued in place. |
Maybe they were glued in place or “locktighted”, wouldn’t prevent a hand and arm from squeezing in there. It’s been a few years, but the basics haven’t been lost to me. I would recommend pulling the front tin ( behind fan shroud) at least on one side.
Not everyone has the ability to work on cars, limits and range of motion etc.
or should. _________________
mike brind Samba Member
Posted: Tue Jun 19, 2018 11:16 am Post subject: Re: Clutch adjustment help |
there always a pain to get at , made a little easier if u remove the tube from heat exchanger to cab , also with the wheel removed and on axle stands . |
OB Bus Samba Member
Joined: February 09, 2003 Posts: 2537 Location: Ocean Beach in Beautiful BLUE California
Posted: Tue Jun 19, 2018 3:06 pm Post subject: Re: Clutch adjustment help |
I just did the adjustment a few days ago. My single cab is not lowered. There is no way I could get my arm up to do it with the bus on the ground. I put the back end up on one ramp and then I could reach my arm up in to make the adjustment. Fingertips were enough to turn the wing that with a vice grip on the cable. FWIW I am not a small person. It was a tough job to do. _________________ Larry in OB
69 Westfalia and 2002 Eurovan Camper. |
velvetgreen Samba Member
Posted: Wed Jun 20, 2018 11:29 am Post subject: Re: Clutch adjustment help |
i find breaking my arm in three places helps a lot with getting at wingnut/bolt - failing that take off the heater box accordion thing and jack the car up and remove the tires makes life easier.
please use a jack stand on some form of secondary support if you are gonna be crawling under the car with the wheel off |
turkis-deluxe Samba Security
Posted: Wed Jun 20, 2018 8:26 pm Post subject: Re: Clutch adjustment help |
uh did you try removing the tire and putting your bus on stands? There's plenty of room that way. It should not be that difficult......
Good luck! |
otis_bartleh Samba Member
Joined: August 19, 2009 Posts: 1106 Location: Burlington, WA
Posted: Thu Jun 21, 2018 9:47 am Post subject: Re: Clutch adjustment help |
Clara wrote: |
...I don't see much difference in adjusting the clutch on a split bus compared to my 69 bug, so maybe I'm missing something in the question. ... |
Same here... _________________ -Adam
'59 Mango Bus - getting buried in it
'69 Bug - sold and highly missed, so it stays in the sig |
Harleyelf Samba Member
Joined: April 23, 2009 Posts: 1572 Location: Appleton, WI
Posted: Thu Jun 21, 2018 10:09 am Post subject: Re: Clutch adjustment help |
You can drive the two left wheels up on the curb to give you room to get under the bus, but that means lying in the gutter. I'd remove the left rear wheel and put a jackstand under the torsion tube, should be an easy reach from there.
Eric & Barb always have good advice. With the engine out is easiest, learn to check the clutch every time you drop the motor. |
Posted: Thu Jun 21, 2018 5:29 pm Post subject: Re: Clutch adjustment help |
Harleyelf wrote: |
I've had to readjust clutches from time to time after an &R with nothing else done. Weird how it happens......so i always recheck clutch every time motor goes back in. |
Posted: Sat Jun 23, 2018 5:28 pm Post subject: Re: Clutch adjustment help |
First ....thank you all everyone .... I am able to get my fingers on the wing nut however cant hand turn wing nut, just to tight of a space.
Taking off the wheel helped greatly !!! I could get my hand in and create enough torque to turn the wing nut.
Great ideas and greatly appreciated
Love this forum |
Posted: Sat Jun 23, 2018 5:38 pm Post subject: Re: Clutch adjustment help |
Great that you got it working!! _________________ In Stereo, Where Available! |
Posted: Sun Jun 24, 2018 2:06 am Post subject: Re: Clutch adjustment help |
Two pairs of vise grips. Larger one on the cable, smaller one turn the wingnut a quarter turn at a time. |
aeroFlutter Samba Member
Joined: August 06, 2017 Posts: 53 Location: Washington
Posted: Fri Jul 13, 2018 7:54 am Post subject: Re: Clutch adjustment help |
greenboat4 wrote: |
Love this forum |
Great to hear you got it working! I have a similar swap in my SC. Do you happen to know what clutch cable you are using in yours?
Thanks! _________________ Dave
'59 Single Cab
'69 Squareback
'16 Volvo V60 Polestar
'05 JCW MINI |
