Mispeld Samba Member
Joined: April 29, 2018 Posts: 355 Location: Jacksonville - Coastal NC
Posted: Mon Jun 18, 2018 6:23 pm Post subject: Oil leak below #1 cyl |
Showed my daughter how to drive a stick yesterday around the block a few times adding 4 miles to the bus out of the 8 total miles driven since we got it going. Anyway, i smelled oil burning. When I parked it a little smoke was coming out. I figured and hoped it was just dirty oily heat exchangers. I pulled the lower tins and here is a picture of the wet areas. I did clean that tin when I changed the lifter in #2 cyl... 4 miles ago. The wet area is above the pushrod tubes below #1 cyl. The only place I can think of a leak is the base gasket? The pushrod tubes could use some seals, which I have but need to install.
I do know it all needs a good cleaning and the old crap on the tins and heat exchangers from pushrod tube seals needs attention. I'm just curious where this fresh looking oil is coming from. _________________ Tom
1977 Westy. 2.0 Fuel Injected. |
Posted: Mon Jun 18, 2018 7:01 pm Post subject: Re: Oil leak below #1 cyl |
Clean and watch, clean and watch. The leak could be between the cylinder and the head, not something you can fix without partially disassembling the engine.
You can get dyes that will show up in black light. |
