OldBlueSyncro Samba Member
Joined: April 24, 2018 Posts: 206 Location: British Columbia
Posted: Mon Jun 18, 2018 8:17 pm Post subject: Wear on power steering pump rotor. |
I just pulled my power steering pump apart to reseal it and there appears to be chunks missing from the rotor. Is this how its supposed to look? Or are there really pieces missing?
If there are in fact pieces missing, can I still run it like this?
11BC2 Samba Member
Joined: August 27, 2017 Posts: 495 Location: Cool, California
Posted: Tue Jun 19, 2018 6:07 am Post subject: Re: Wear on power steering pump rotor. |
That doesn't look good, but I've never pulled my pump apart.
I'd suggest not using it and replacing it so as to prevent more damage to rest of the system. |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Tue Jun 19, 2018 6:19 am Post subject: Re: Wear on power steering pump rotor. |
I just resealed a pump and the slots were square. Yours seems pretty beat compared to the one I just did. For others, the impeller pieces also had an in and out, so pay attention to how your vanes are in the section. I recall on mine the chamfered end was in. _________________ ☮️ |
Posted: Tue Jun 19, 2018 7:33 am Post subject: Re: Wear on power steering pump rotor. |
MarkWard wrote: |
I just resealed a pump and the slots were square. Yours seems pretty beat compared to the one I just did. For others, the impeller pieces also had an in and out, so pay attention to how your vanes are in the section. I recall on mine the chamfered end was in. |
I'm thinking I'll just buy a new pump. I'd rather be safe than sorry.
I'll keep the reseal kit on hand for the future. |
Posted: Tue Jun 19, 2018 7:36 am Post subject: Re: Wear on power steering pump rotor. |
I think it served it's life. There are not many moving parts if you could find a used one and reseal it. That might be a good way to go. _________________ ☮️ |
Vanagon Nut Samba Member
Posted: Tue Jun 19, 2018 11:24 am Post subject: Re: Wear on power steering pump rotor. |
Does this wear indicate excessive end play? Safe to assume there's wear at the cover and that there will be a loss of efficiency at this pump?
Neil.
_________________ 1981 Westy DIY 15º ABA
1988 West DIY 50º ABA
VE7TBN |
