9.5isCanadian Samba Member
Joined: September 16, 2017 Posts: 465 Location: In your blind spot.
Posted: Wed Jun 27, 2018 1:37 pm Post subject: Re: WheelSkins steering wheel cover |
Well look see what the mail human left in my box today.
Put it on last night and took a few pictures of the process.
This one I call the "no way is that going to fit. Its too small." shot
But if you've ever spooned a motorcycle tire on a wheel, you know it will fit. I put the electrical tape on the top to keep it centered at 12 o'clock. Then another piece at 3 to hold that portion in place while I worked my fingers around the clock stretching it over the wheel.
Making sure the 'gap' is uniform around the circumference of the wheel by pinching it with my grubby fingers.
and the other side
Pay careful attention to the spoke areas to ensure that the stitches don't fall out of sync front to back and that they pull tight against the spoke.
Note how the stitch goes across front to back on top of the wheel while the needle goes across to the next hole inside the wrap (diagonally)
Finished wheel wrapped and ready for my sweaty mitts to soil its virginal surface.
Very happy with the quality and fit of the wrap. Sadly I'm waiting for my Tdi starter to arrive so I can test the wheel out.
as an aside, you can push start a Vanagon in a flat parking lot. Ask how I know.
_________________ 9 1/2 - missing a few pieces.
1987 Getaway Hightop
1980 Sunroof Vanagon
2018 BMW R Nine T
2012 Golf tdi |
SCM Samba Member
Joined: January 26, 2011 Posts: 3119 Location: Bozeman MT
Posted: Wed Jun 27, 2018 2:23 pm Post subject: Re: WheelSkins steering wheel cover |
That's one of my favorite upgrades that I've made to my van. After 7 years it still looks and feels perfect. _________________ '91 Westfalia GL Automatic (GTA "Turbo" Rebuild w/Peloquin) and 2.3L GoWesty Engine |
OddN Samba Member
Joined: August 19, 2010 Posts: 690 Location: Northern Norway
calo1956 Samba Member
Joined: April 18, 2011 Posts: 703 Location: long Island new york
Posted: Thu Jun 28, 2018 5:28 pm Post subject: Re: WheelSkins steering wheel cover |
Nice Job 9.5, looks sweet! Nice photo documentation! _________________ Enjoy the ride....
72 bug
80 westfalia |
otiswesty Samba Member
Joined: November 21, 2006 Posts: 1731 Location: Portland
Posted: Fri Jun 29, 2018 10:57 am Post subject: Re: WheelSkins steering wheel cover |
I installed one on my bus in 1992, still love it!
People asked me how I managed to get it to fit. The trick I found for an easy and nice tight fit is to soak the Wheelskins cover in hot water for 30-40 min and then mount and stich it on, It will dry even snugger to the steering wheel than otherwise possible. _________________ 1978 Sage Green P22 Westfalia
1989 T3 Syncro Single cab
Just a regular guy |
dlb154 Samba Member
Joined: December 27, 2006 Posts: 359 Location: Reno, NV
Posted: Sat Jul 21, 2018 2:24 pm Post subject: Re: WheelSkins steering wheel cover |
Here is an alternative cover that worked well for a fraction of the cost. I used the soak for shrinking method to get a tight fit.
Bought on Amazon for $13.99 Prime shipped - Get the XL size
https://www.amazon.com/gp/product/B071F1C7X7/ref=od_aui_detailpages00?ie=UTF8&psc=1
Original Install after soaking in water for an hour:
Texture of the leather:
Cover tightened up after a few days in the HOT weather we've had in Reno this week:
Back side:
[/img] |
E1 Samba Member
Joined: January 21, 2013 Posts: 6572 Location: Westfalia, Earth
Posted: Sat Jul 21, 2018 3:04 pm Post subject: Re: WheelSkins steering wheel cover |
I love our Wheelskins cover.
I had to do it twice, it seemed pulling the string really tightly to get the ends to snug up tightly would break the string, but it doesn't.
Crank 'er down! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
pinetreeporsche Samba Member
Joined: June 11, 2009 Posts: 752 Location: Falls Church, VA
Posted: Sat Jul 21, 2018 3:54 pm Post subject: Re: WheelSkins steering wheel cover |
[quote="dlb154"]Here is an alternative cover that worked well for a fraction of the cost. I used the soak for shrinking method to get a tight fit.
https://www.amazon.com/gp/product/B071F1C7X7/ref=od_aui_detailpages00?ie=UTF8&psc=1 [quote]
dlb: I just ordered one, the XL as you recommended. Then remembered that there are two steering wheel sizes- I've got power steering, thus the smaller wheel. Iw that what you have or should I cancel and re-order a size or two smaller? -Thanks -pinetree |
dlb154 Samba Member
Posted: Sun Jul 22, 2018 11:08 am Post subject: Re: WheelSkins steering wheel cover |
Pinetree -
The XL is what you want for power steering. Measure your steering wheel diameter. It should be about 16.5". The circumference of the grip area is about 3.5"
The XL size is listed with slightly larger diameter (they say 17"-18") but using the soak/shrink method mine fits very nice. Circumference was perfect. |
Posted: Sun Jul 22, 2018 11:12 am Post subject: Re: WheelSkins steering wheel cover |
Hey, whatever works, as long as you got it on! _________________ Enjoy the ride....
72 bug
80 westfalia |
Guybrush Samba Member
Posted: Sun Jul 22, 2018 11:55 am Post subject: Re: WheelSkins steering wheel cover |
I've had one for years in my Volvo, but it has become relatively slick as it wore a bit, so the grip isn't that great. For the Vanagon, I used the Europerf version (all in black for me) and I really recommend that one.
I have actually broken the string while tightening, but that was when trying to put one on the Eurovan steering wheel that I had. The wheelskins doesn't fit well on that due to how wide the spokes are. I went back to a Vanagon steering wheel anyway. Wheelskins sent me a replacement immediately.
I've also cut myself at the crease of the fingers when putting this on, then remembered to wear a glove. |
DustyMiller Samba Member
Joined: June 01, 2019 Posts: 7 Location: St. Albert, Alberta, CAN
Posted: Thu Jan 21, 2021 4:16 pm Post subject: Re: WheelSkins steering wheel cover |
I see what you did there. It's the Euro but you put it on up side down to fit the wheel spoke.
How do you like it two years later? Are the perforations full of hand grime? _________________ 1987 Westfalia, Automatic Transaxle,2.1L
23,500km when she found her forever home.
"I'm not going to tell you these [cars] will increase in value, or even hold their current value. The truth is, you bought 'em because you like 'em. They have value to you. That's what matters."
Rick Sanchez, J19ζ7 |
Thor-bob Samba Member
Posted: Thu Jan 21, 2021 6:00 pm Post subject: Re: WheelSkins steering wheel cover |
This is the single best thing you can do to your van.
You touch the wheel more than anything else. In the van. Of the van.
Support WheelSkins - they do custom stuff!
Thor-bob |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Thu Jan 21, 2021 7:32 pm Post subject: Re: WheelSkins steering wheel cover |
I installed a Wheelskin 10 years ago... still looks new.
It's a lot easier if you remove the steering wheel. That way you can move it around for the best access.
_________________ Glenn
Member #1009
#BlueSquare |
Zeitgeist 13 Samba Member
Posted: Thu Jan 21, 2021 8:39 pm Post subject: Re: WheelSkins steering wheel cover |
Has anyone tried to add some thickening material on the wheel rim prior to installing the Wheelskins? I've used these before, and I have a stock Vanagon rim here with one, but I find the girth to be lacking. I'm used to a girthy heft in my hand and won't settle for less. The rim just feels kinda boney underneath and seems like it should have some padding. I can't remember if there's enough stretch in the leather to allow for some additional padding. Anyone? _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Thu Jan 21, 2021 8:58 pm Post subject: Re: WheelSkins steering wheel cover |
A material that may work quite well for padding would be bicycle handlebar tape. It's literally designed to wrap around a tubular control surface of about this diameter. It's designed to withstand years of hard use, weathering, and hand oils, so will hold up well under there. Keep in mind it will have a texture if wrapped certain ways so if you don't want that look at different materials as some of them have beveled edges to minimize that. Also, you'll have to get a substantially larger steering wheel wrap than that specified for your vehicle. _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
valvecovergasket Samba Member
Posted: Thu Jan 21, 2021 9:11 pm Post subject: Re: WheelSkins steering wheel cover |
Glenn wrote: |
I just put one of these on our van a few weeks ago while it was down for some other winter work. Was just thinking how nice it was to have the wheel mounted so it was really easy to pull against when snugging the stitches
Different strokes I guess!
Zeitgeist 13 wrote: |
Has anyone tried to add some thickening material on the wheel rim prior to installing the Wheelskins? I've used these before, and I have a stock Vanagon rim here with one, but I find the girth to be lacking. I'm used to a girthy heft in my hand and won't settle for less. The rim just feels kinda boney underneath and seems like it should have some padding. I can't remember if there's enough stretch in the leather to allow for some additional padding. Anyone? |
It adds a decent bit of heft to the wheel once on. I was impressed. That dainty feel was one of my gripes with the factory unit.
If you added something you'd need to find a different wheel skin to fit, as it's already juuuust big enough to roll over the factory wheel _________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
Posted: Thu Jan 21, 2021 9:31 pm Post subject: Re: WheelSkins steering wheel cover |
It's definitely an improvement, but it still doesn't feel as nice as the factory leather wheel that originally came on my Bluestar, or the Mk1 Cabriolet wheel currently on there, or the Mk4 GLI version on my T4. I'd just like to have a little extra something to put on a standard T3 wheel. I wonder if you soaked the leather in hot water prior to install, it would be possible to add some extra padding underneath. My mind never stops trying to muck up progress. _________________ Casey--
y u rune klassik? |
uberaudi Samba Member
Joined: June 24, 2013 Posts: 503 Location: Hi-top Country
Posted: Thu Jan 21, 2021 9:51 pm Post subject: Re: WheelSkins steering wheel cover |
Wheelskins are great, I plan on getting another couple for my other vans.
On my old 91 20vt Avant, I sent the wheel off to Redline Goods to get it reskinned and also thickened. I believe I added a 1/16" foam to it, so an 1/8" increase in girth overall. Such a small amount made all the difference. _________________ '84 Adventurewagen 1Z Tdi, '89 Tintop ABA, and a 86 Syncro tintop WBX. |
Posted: Thu Jan 21, 2021 10:12 pm Post subject: Re: WheelSkins steering wheel cover |
It's definitely an improvement, but it still doesn't feel as nice as the factory leather wheel that originally came on my Bluestar, or the Mk1 Cabriolet wheel currently on there, or the Mk4 GLI version on my T4. I'd just like to have a little extra something to put on a standard T3 wheel. I wonder if you soaked the leather in hot water prior to install, it would be possible to add some extra padding underneath. My mind never stops trying to muck up progress. |
Might be worth bugging wheel skins about it, I've heard nothing but great things about their customer service. Maybe they have some idea of how much you could get away with before it won't fit under the existing wrap
I was never a fan of the mk1 leather wheels, but I've probably only felt them super worn out already hah _________________ MegaSquirt resource - SpitfireEFI.com
