ajl1971 Samba Member
Joined: December 09, 2010 Posts: 89 Location: New York
Posted: Tue Jun 19, 2018 7:33 pm Post subject: My 66 Squareback 6V dual carb keeps dying |
Hi guys.
For the past month or so I have been experiencing some problems with my Squareback, after running for few minutes it dies. The longest I drove it was for about 40 minutes and I thought I have fixed the problem. Now I can run it for 5-10 minutes. For the most part car starts right up.
These are the things I have done so far :
- Mechanical fuel pump is working
- Points were changed and calibrated
- Condenser were changed
- Coil was changed
- Distributor cap and rotor were changed
I dont know what else I can do. Here is a little video where you can see the car that was already running and at the end it just dies. It looks like I had flip a switch to turn it off. Lights still on the dash.
Is there anything else (electronically) that keeps the car running.
I do see like a relay and such underneath the backseat.
http://vimeo.com/275442824 |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22727 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Tue Jun 19, 2018 8:51 pm Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
Check for 12v at the coil when it dies. If no power the switch may be heating up and losing contact.
Does it have fuel?
If so, is the ignition coil hot?
How old is the condenser?
Point gap too small?
How long since the last valve adjustment?
Are the chokes opening?
Does it have electromagnetic cutoff jets? If so, are they hooked up and working? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Wed Jun 20, 2018 3:35 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
Tram wrote: |
Does it have fuel?
Of course
Noy sure but it was replaced
New
017
2 years but only 300 miles driven
I think so because the car starts right up. its only after few minutes the car shuts off
Does it have electromagnetic cutoff jets? If so, are they hooked up and working Im going to check that, not sure yet
BTW car is 6v still |
EverettB Administrator
Joined: April 11, 2000 Posts: 69823 Location: Phoenix Metro
Bobnotch Samba Member
Joined: July 06, 2003 Posts: 22425 Location: Kimball, Mi
Posted: Thu Jun 21, 2018 9:18 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
Tram wrote: |
Does it have fuel?
Does it have electromagnetic cutoff jets? If so, are they hooked up and working? |
I'm glad you decided to post your problem into an open forum. I didn't even think about a possible ignition switch being flaky. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Thu Jun 21, 2018 10:07 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
Bobnotch wrote: |
Tram wrote: |
Does it have fuel?
I'm glad you decided to post your problem into an open forum. I didn't even think about a possible ignition switch being flaky. |
How do i check a flaky ignotion switch, replacing it ? |
Posted: Thu Jun 21, 2018 10:08 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
EverettB wrote: |
I agree with checking power at the coil.
Does it start right back up or do you have to wait?
This could indicate something is getting hot and failing. |
From what I can tell starts right up |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13280 Location: Tejas!
Posted: Thu Jun 21, 2018 10:21 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
ajl1971 wrote: |
Bobnotch wrote: |
Tram wrote: |
Does it have fuel?
I would temporarily disconnect the wire at the coil that comes from the ignition (and tape it off). Run a new wire from the fuse box (one thats always hot) with a switch to the coil instead. Flip the switch, use your key to start it, should start right up. Drive it around. If it still acts up it's something else. If it's now fine, it's your ignition switch. _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Fri Jun 22, 2018 10:12 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
Erik G wrote: |
ajl1971 wrote: |
Bobnotch wrote: |
Tram wrote: |
Does it have fuel?
I would temporarily disconnect the wire at the coil that comes from the ignition (and tape it off). Run a new wire from the fuse box (one thats always hot) with a switch to the coil instead. Flip the switch, use your key to start it, should start right up. Drive it around. If it still acts up it's something else. If it's now fine, it's your ignition switch. |
Yup. Exactly how I'd do it. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Jun 25, 2018 3:57 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
I checked the carbs last night and I do have 2 Solex 32 Pic 3, each one has a cut off valve. Is there anyway to check a cut off valve ?
If one fails, both carbs dies or one just dies and the other carb should still be running ?
Thanks |
Posted: Mon Jun 25, 2018 9:07 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
ajl1971 wrote: |
Thanks |
Carbs are independent of each other. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Mon Jun 25, 2018 9:12 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
ajl1971 wrote: |
Thanks |
The electric cutoff valves? They are independent.
To check them, turn the key to on.
Disconnect the power wire to one of them, then reconnect it.
You should hear a click.
No click = it's bad. _________________ How to Post Photos
Posted: Mon Jun 25, 2018 8:06 pm Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
EverettB wrote: |
ajl1971 wrote: |
Thanks |
No click = it's bad. |
I heard when a cutoff valve is bad the engine wont idle but the engine should stay on at high rpm. Mine dies because because I cant rev it up. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34013 Location: Conejo Valley, CA
Posted: Mon Jun 25, 2018 8:40 pm Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
I suppose it's possible a shorting EM jet could bring down the ignition voltage and affect both carbs as well as the spark. I haven't had that happen to me, however. |
Posted: Mon Jun 25, 2018 10:52 pm Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
ajl1971 wrote: |
EverettB wrote: |
ajl1971 wrote: |
Thanks |
Yes, it would stall at idle as it would be cutting off the idle circuit for gas.
When the car is revved up, you are "above" the idle circuit. _________________ How to Post Photos
Erik G Samba Member
Posted: Tue Jun 26, 2018 9:27 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
It's not very common for them to go bad though. also, they are on the same wire coming from your ignition to your coil which we went over earlier _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
Posted: Tue Jun 26, 2018 12:31 pm Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
KTPhil wrote: |
Sorry but what is EM jet |
Posted: Wed Jun 27, 2018 10:21 am Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
ajl1971 wrote: |
KTPhil wrote: |
Electro Mechanical jet. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
Posted: Wed Jun 27, 2018 4:12 pm Post subject: Re: My 66 Squareback 6V dual carb keeps dying |
Bobnotch wrote: |
ajl1971 wrote: |
KTPhil wrote: |
Electro Mechanical jet. |
OK, I guess my carb has one, I need to know where its. |
