johnanddes Satellite Wrangler
Joined: October 17, 2004 Posts: 692 Location: Orcutt CA
Posted: Tue Jun 19, 2018 9:00 pm Post subject: Belt tension |
Alright, attempted a search, combed through the first 150 of 353 pages, no luck. My question is is the belt tension 1/4” or 1/2”? Reason why i ask is because half the manuals (to include offical VW Owner’s Maintenance and Repair Guide) say 1/4” while the other half (Bentley, Haynes) says 1/2” delfection. Which one is correct? _________________ John
1969 documented numbers matching bug
1968 F250
Keepin the ISS from colliding with space junk |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Tue Jun 19, 2018 9:13 pm Post subject: Re: Belt tension |
Should be about 5/8".
From 1970 OM:
_________________ In Stereo, Where Available! |
Posted: Tue Jun 19, 2018 9:34 pm Post subject: Re: Belt tension |
Thanks Eric&Barb. Thats my issue though. Some say 1/2”, some say 1/4” like this one:
1968 F250
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Tue Jun 19, 2018 10:16 pm Post subject: Re: Belt tension |
Surprising to see that (it's gotta be a typo) in an "official" VW manual. Everything I'd read up until now was in general agreement, 1/2" or slightly more. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Tue Jun 19, 2018 10:18 pm Post subject: Re: Belt tension |
I’ve never seen the 1/4 inch deflection for the belt. How strange. That’s way too tight; although, when that manual was printed, perhaps they had belts that stretched a lot during the first 100 miles, or so. In that case, you probably wouldn’t have to readjust. But, you’d sure be messing with your generator/alternator bears .
I’ve always set the deflection to around 5/8 inch—which is just a smidge more than 1/2.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Posted: Tue Jun 19, 2018 10:24 pm Post subject: Re: Belt tension |
Towel Rail wrote: |
Surprising to see that in an "official" VW manual. |
Yeah i thought so too which is why i posted here. Doesnt make sense. Here is the date/print page
1968 F250
Posted: Tue Jun 19, 2018 11:14 pm Post subject: Re: Belt tension |
I suspect they gave the 1/4 inch measurement because the belts at the time would stretch more than a modern one. If you installed it initially at that measurement, after a few hundred miles, the belt would stretch closer to the 1/2 or 5/8 inch mark.
But, as I said before, it seems this initial tightness would wear more on the generator bearings, although maybe not for long. But still ...
Richard O'Brien |
Posted: Tue Jun 19, 2018 11:31 pm Post subject: Re: Belt tension |
Tim Donahoe wrote: |
Tim |
I think i have figured out why they said this. According to the Clymer one, there was a belt made with different materials introduced in 71. Ill still use the 1/2” method, but its still intriguing.
1968 F250
Frodge Samba Member
Posted: Wed Jun 20, 2018 3:45 am Post subject: Re: Belt tension |
If your belt is too tight it probably definitely puts too much tension on the generator bearings. But I have a question about being too loose. Would the generator light flicker if the belt is too loose? I never understood how to get the tension just right. Everyone presses with a different strength. Would in fact the generator light flicker if the belt was slipping and too loose. |
jeffinohio Samba Member
Joined: February 02, 2017 Posts: 197 Location: Scio Ohio
Posted: Wed Jun 20, 2018 5:38 am Post subject: Re: Belt tension |
johnanddes wrote: |
8 sided nut anyone?.... _________________ 64 Sunroof
73 Standard
70 Convertible
67 Cougar
3 Subarus |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Wed Jun 20, 2018 7:21 am Post subject: Re: Belt tension |
I would run the belt looser rather than tighter. In my experience a belt too tight can flip inside-out. Running too tight probably won't wear bearings any faster than the pulley exploding (also from experience).
The formula-vee guys purposely run their belts on the loose side. Think of it this way: the belt is transmitting HP through it. It spins the generator and the fan. The tighter you make the belt, the more power you transmit through the belt. Too tight and you stress out the pulley with too much heat. It also creates some HP loss, which is why there's not much sense running a tensioned serpentine belt on these engines, as well as risking blowing up the fan.
Your belt is your mechanical fuse in the system - you'd rather throw a belt, then break a pulley, bearing, or fan blades. Ideal belt tension can be calculated, and the measured deflection method is just a ballpark for the shadetree mechanic. _________________ 1972 Standard Beetle
1969 Baja Beetle |
Posted: Wed Jun 20, 2018 8:13 am Post subject: Re: Belt tension |
Frodge wrote: |
Only if the belt is super loose. If one is in doubt that the belt might need to be tightened more:
1. Engage parking brake.
2. Shift into neutral.
3. With socket turn the generator pulley CW so in turn the crankshaft is turned. You are not trying to turn the crank quickly as if you were trying to crank start the engine, instead turning the crankshaft one RPM in about 5 to 10 seconds. If belt slips it needs tightening.
Belt is designed to slip some with sudden huge RPM change. _________________ In Stereo, Where Available! |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Jun 21, 2018 5:37 pm Post subject: Re: Belt tension |
Every time I change a belt I toss the wrench in the car and keep it with me for the first couple drives. That way the tension will settle in and you can easily re-torque the nut wherever you are. Chicks dig it. _________________
EverettB wrote: |
FU#5 |
PuddleRainbow Samba Member
Joined: April 13, 2018 Posts: 288 Location: The Dirtiest Of Jersey
Posted: Fri Jun 22, 2018 5:24 am Post subject: Re: Belt tension |
Quote: |
That way the tension will settle in and you can easily re-torque the nut wherever you are. Chicks dig it. |
LOL, I check the oil a lot or futz with the choke in the work parking lot for the same reason. |
bluebus86 Banned
Posted: Fri Jun 22, 2018 7:47 am Post subject: Re: Belt tension |
Frodge wrote: |
It may flicker, it may not, it depends how loose is loose and how much load is on the electric system, headlamps, wipers operating will cause the light to illuminate at a lower threshold of slip than if those accessories are off.
Bottom line is dont use the generator light as a check for belt tightness.
for the thumb pressure test, push as hard as you can with thumb on the midpoint of belt between the two pullies on the left side of the loop of belt. about half inch deflection of so is correct unless you have the new kind of belt. Unless you have a physical condition that precludes pressing hard, you will be close enough. Once the belt is pushed a given amount, it wont move that much more even with more pressure, it is not a linear response, pressure verses deflection.
you could use a belt tension test tool, I use them on serpentine belts, and they can be used on vee belts.
good luck, Bug On Under Correct Tension. _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
slave1pilot Samba Member
Joined: February 22, 2010 Posts: 943 Location: Tehachapi CA
glutamodo The Android
Joined: July 13, 2004 Posts: 26324 Location: Douglas, WY
Posted: Sun Jun 24, 2018 10:40 am Post subject: Re: Belt tension |
jeffinohio wrote: |
johnanddes wrote: |
8 sided nut anyone?.... |
By the way, there's no need to scan anything from that flippin 1972 additional "Guide" booklet, The entire book is in TheSamba archives...
https://www.thesamba.com/vw/archives/manuals/72bug_guide.php
What's this about 8 sided? I don't see it there. 13/16 is a valid enough SAE hex size (spark plug) socket and does not refer to how many sides the fasteners have. While it's a bit snug it does work for the generator pulley nut.
Now, that IS a booklet prepared after VW really "dumbed down" the glovebox owner's manual for model year 1972. Not sure where they came up with 1/4 inch on the belt adjustment though... _________________ Andy T.
Posted: Sun Jun 24, 2018 1:06 pm Post subject: Re: Belt tension |
Oh, the cover! Yeah okay. I'm a technical sort of dude, I look at text, actual illustrations and specifications, and hardly pay attention to artsy-fartsy cover art. Obviously I never paid any heed to that one. hah (my comment was looking over the indicated specifications)
It's not like double-square (8-point) sockets don't exist. I have some in SAE sizes. Hell a 5/16 8 point socket rather works nicely for the 4-point fill plug on early steering boxes. _________________ Andy T.
