Frodge Samba Member
Posted: Wed Jun 20, 2018 7:45 am Post subject: Valve adjustment/feeler guage feel |
Can anyone explain what the correct feel is like when you’re pulling the guage through the valves? I know practice makes perfect, but there has got to be some way to explain how much tension it should feel like. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Wed Jun 20, 2018 8:00 am Post subject: Re: Calve adjustment/feeler guage feel |
That happy little area between too tight & too lose is where the blade can be pushed & pulled with a bit of drag & just barely reinserted if it slides out. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Pruneman99 Samba Member
Joined: February 22, 2012 Posts: 5013 Location: Oceanside
Posted: Wed Jun 20, 2018 8:00 am Post subject: Re: Valve adjustment/feeler guage feel |
It should slide through, with just a tiny bit of drag. If you think your feeler is going to get scratched, it's too tight. |
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9829 Location: Somewhere between Dubuque and Keokuk
Posted: Wed Jun 20, 2018 8:09 am Post subject: Re: Valve adjustment/feeler guage feel |
I don't think this discussion is going to end well. |
windfish Samba Member
Posted: Wed Jun 20, 2018 8:10 am Post subject: Re: Valve adjustment/feeler guage feel |
A set of go-no-go feeler gauges makes it easy, they have a .002" step.
When you have a slight drag on the lower section and the upper wont fit you're good.
Randy in Maine Samba Member
Posted: Wed Jun 20, 2018 8:29 am Post subject: Re: Valve adjustment/feeler guage feel |
windfish wrote: |
X2 very handy to have. |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Wed Jun 20, 2018 9:40 am Post subject: Re: Valve adjustment/feeler guage feel |
I suppose everyone has a slightly different technique. For me, if I have to force the feeler gauge between the valve and rocker, it's too tight. If wiggling the rocker makes a clacking noise with the blade in place, it's too loose. I find this makes for pretty fast checks. _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Zundfolge1432 Samba Member
iowegian wrote: |
correct is .007 won’t go but .005 is loose. Slight drag as in guage goes in and if you removed hand gauge would stay in place. Just remember especially with exhaust valves better little loose than too much tight. |
Frodge Samba Member
Posted: Wed Jun 20, 2018 9:54 am Post subject: Re: Valve adjustment/feeler guage feel |
Zundfolge1432 wrote: |
iowegian wrote: |
so your saying that if the .005 is loose and the .007 doesn’t fit, the .006 should
Kind of hang in place if you let go of it... |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Jun 20, 2018 10:18 am Post subject: Re: Valve adjustment/feeler guage feel |
buy a mic, set it to .006 and fiddle with it and the feeler gauge till you get a feel for what it should be _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Wed Jun 20, 2018 10:50 am Post subject: Re: Valve adjustment/feeler guage feel |
This is not a difficult procedure. If the .006 blade passes through with a “slight” drag—and, subsequently, your .007 blade won’t fit—unless you force the shit out of it—then you’re where you want to be.
If one can’t fathom the concept of what “slight” means, then you also may have trouble with the legal term “reasonable doubt”. In this case, please don’t show up for jury duty. Just pay the fine.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Frodge Samba Member
Posted: Wed Jun 20, 2018 11:02 am Post subject: Re: Valve adjustment/feeler guage feel |
Tim Donahoe wrote: |
Tim |
busman78 Samba Member
Joined: August 17, 2004 Posts: 4524 Location: Oklahoma City, OK
Posted: Wed Jun 20, 2018 11:15 am Post subject: Re: Valve adjustment/feeler guage feel |
Personal I like a .006-.008 go-no-go, as for what is snug, what is slight, what is loose, the silly .001 that makes the difference is irrelevant to the longevity of the engine. Course an easy although expensive cure is buy a set of steel Manley push rods set to zero lash, oh darn that creates a problem with what is and when does "zero" lash happen.
You will know when the .006 or whatever gap you use is too loose or too tight, just practice setting loose, then tight, back and forth, the right fit will become apparent. As far as I know nobody was born with micrometer fingers with built in gauging. |
Posted: Wed Jun 20, 2018 11:35 am Post subject: Re: Valve adjustment/feeler guage feel |
easiest way if your not sure I’d bribe a competent ASE certified Mech using charm, cold drinks, food etc to show you. Also maybe visit local vo tech take a class in auto repair. John Muir has a good description in his book. The absolute best would be finding and befriending an older retired person who would take the time to teach you, there is no substitute for apprenticeship training. |
Frodge Samba Member
Posted: Wed Jun 20, 2018 11:42 am Post subject: Re: Valve adjustment/feeler guage feel |
Thanks guys. I have the Bentley and the John Muir book. I’ll re-read. |
Posted: Wed Jun 20, 2018 12:31 pm Post subject: Re: Valve adjustment/feeler guage feel |
I picked one a "go-no go" feeler gauge up at a AutoBone for less than $10 a few years ago when I was helping a young lady with her 70 beetle. I actually bought 2 and kept one for me. She got the hang of it in a couple of times.
http://www.lislecorp.com/divisions/products/?product=396 |
ashman40 Samba Member
Joined: February 16, 2007 Posts: 15985 Location: North Florida, USA
Posted: Wed Jun 20, 2018 12:53 pm Post subject: Re: Valve adjustment/feeler guage feel |
I don't have no "fancy" no-go feeler gauges....
I adjust the valve with the 0.006" feeler until there is a slight drag. Lock the nut down and make sure the 0.006" STILL fits (go gauge) AND the 0.007" feeler WONT'T FIT (no-go) between the valve and the rocker arm (or 0.007" is clearly too tight to slide thru w/o "gouging" the gauge -- be gentle). Done. Move on to the next valve.
If the 0.007" fits between, then the adjuster moved while you were locking the nut, or you didn't adjust the gap correctly.. .try again. After you doing this for all 8 valves a few times you will get the feel for it. Easy enough you can do it every oil change (3-months)! _________________ AshMan40
mark tucker Samba Member
Posted: Wed Jun 20, 2018 1:08 pm Post subject: Re: Valve adjustment/feeler guage feel |
snug. in reality it matters little as long as there all adjusted the same.... but the way many people adjust their valves it dose not matter any way. |
