mhm8767 Samba Member
Joined: June 20, 2018 Posts: 15 Location: Los Angeles (Shadow Hills/Sunland)
Posted: Wed Jun 20, 2018 11:33 am Post subject: Pop top seal repair or replacement |
Hello, this is my first post on this website. In 2008 when the warranty was about to run out on my 2003 EV Weekender, my service advisor at VW Santa Monica suggested replacing the vinyl seal that runs around the lower edge of the pop top shell. He ordered an OEM replacement part, and it was installed.
As the years passed, however, the silicone adhesive that had been applied started to bubble out, as I live in a hot climate. Whatever they used is extremely sticky and difficult to remove. GoWesty said the seal doesn’t need adhesive. I’ve seen various opinions on this site both for and against.
I really like the original seal, but Steve at Karmachanix in Berkeley said that although I could probably remove the adhesive from the fiberglass using WD40, it would be extremely difficult to get it out of the inner channel of the seal itself. He recommended ordering a new aftermarket seal.
If anyone has any suggestions regarding any aspect of this issue, I would greatly appreciate your help. Specifically:
- Is there a way to salvage my current seal?
- If not, what is the best seal to order as a replacement?
- Any suggestions for someone in the Los Angeles area who would take the time to do a careful and professional installation? _________________ 2003 EuroVan MV Weekender VR6 (blue)
Previous: 1999 EuroVan (white)
Previous: 1978 Westy Camper (automatic/beige)
Childhood Family Car: 1967 Squareback (manual/white) |
amyshannon Samba Member
Posted: Thu Jun 21, 2018 7:33 am Post subject: Re: Pop top seal repair or replacement |
mhm8767 wrote: |
- Any suggestions for someone in the Los Angeles area who would take the time to do a careful and professional installation? |
I just ordered the one from GOWesty, about $75.00
I just installed it a week ago, really simple, no glue needed and took less than 40 minutes, although I had very little old glue to remove |
Posted: Thu Jun 21, 2018 9:00 am Post subject: Re: Pop top seal repair or replacement |
Ok, thanks! I really appreciate your feedback. _________________ 2003 EuroVan MV Weekender VR6 (blue)
Posted: Tue Jul 10, 2018 7:50 pm Post subject: Re: Pop top seal repair or replacement |
Any other suggestions on this topic? I’m about to order the GoWesty seal, and thought I’d check in one last time. _________________ 2003 EuroVan MV Weekender VR6 (blue)
VAEV1993 Samba Member
Joined: January 17, 2014 Posts: 153 Location: Harrisonburg, VA
Posted: Wed Jul 11, 2018 4:04 am Post subject: Re: Pop top seal repair or replacement |
I also installed the GW seal. Real easy and clean. Fits tight and looks great. Go for it! _________________ 1993 Weekender - Hula
2002 Golf TDI
2017 Golf Alltrack |
Posted: Wed Jul 11, 2018 10:03 am Post subject: Re: Pop top seal repair or replacement |
Ok, thanks! _________________ 2003 EuroVan MV Weekender VR6 (blue)
vw_dude Samba Member
Posted: Wed Jul 11, 2018 10:48 pm Post subject: Re: Pop top seal repair or replacement |
got a seal here http://www.moore4motors.com/
was pretty happy, 3.50 pound a meter |
Posted: Thu Jul 12, 2018 5:16 am Post subject: Re: Pop top seal repair or replacement |
Ok, thank you! _________________ 2003 EuroVan MV Weekender VR6 (blue)
Posted: Thu Jul 26, 2018 5:19 pm Post subject: Re: Pop top seal repair or replacement |
I went ahead and ordered the pop top seal offered by GoWesty. I knew it wasn’t OEM equipment. However, I was told it was “pretty close” to the original. Considering the other company was in the UK, I figured I’d go local.
Once it arrived, however, I was disappointed to find that, although it will fit, it feels like cheap smooth spongy generic rubber, with none of the texture and character of the hard vinyl/rubber of the original. Although this might not seem like a big deal, it is sort of like the bow tie that sets off the pop top roof.
I took another look at the “Moore4Motors” link in the UK that was provided in one of the responses. Although it doesn’t have a photo, it says it’s “high quality EPDM rubber.” Does anyone know what this means? Is it closer to the original OEM trim in terms or hardness and texture? _________________ 2003 EuroVan MV Weekender VR6 (blue)
