is my engine original
kevin'sthing
kevin'sthing is offline
PostPosted: Sat Apr 24, 2004 6:36 pm    Post subject: is my engine original Reply with quote
I have a 74 thing and i think theres only 63,ooo on it but i dont think its the original motor. The reason why is it has a oil fillter on it. I was wondering if that was a option on the car. Thank's for any help.
TimGud
TimGud is offline
PostPosted: Sat Apr 24, 2004 8:29 pm    Post subject: Reply with quote
If the filter is off the oil pump it is an aftermarket item that could be put on almost any air clooled engine. Post the engine serial # and someone will be able to tell you.
kevin'sthing
PostPosted: Sat Apr 24, 2004 9:45 pm    Post subject: Reply with quote
Where is the serial # located and should there be one on the engine that matches the car #?
Kevin
7thing3
7thing3 is offline
PostPosted: Sun Apr 25, 2004 7:22 am    Post subject: Reply with quote
It is under the generator stand, right thru the fan belt, and should start with AM if it is a Thing motor. The 74's started with engine # somewhere around 11,821 according to various references.
'73 Thing--Ted
'77 Super Beetle Convertible
'87 Vanagon GL Syncro
'84 Mercedes 280 CE
kevin'sthing
PostPosted: Sun Apr 25, 2004 10:29 am    Post subject: Reply with quote
The # is AM020769 but i was still wondering if it was a option or a aftermarket part?
Kevin
7thing3
7thing3 is offline
PostPosted: Sun Apr 25, 2004 12:31 pm    Post subject: Reply with quote
Sounds like you have the motor that your car came with from the factory. Someone probably slapped the filter on during a rebuild.
'73 Thing--Ted
'84 Mercedes 280 CE
