javashot Samba Member
Posted: Thu Jun 21, 2018 10:43 am Post subject: Street Rail - fitted |
Bought a Sandrail about 2 months ago with the intent of building a badass street rail out of it. It'll need suspension, motor work, brake upgrades, new welds and cuts, wheels, lights, paint....and probably 1 million other things.
Here is the starting point...
Way too high and way too ugly... |
Posted: Thu Jun 21, 2018 11:08 am Post subject: Re: Street Rail - fitted |
here is another...kinda looks like a tractor. I am going to have to cut the top off soon |
Posted: Thu Jun 21, 2018 11:19 am Post subject: Street Rail - fitted |
Step 1..
Remove aluminum beam and add adjustable beam. Picked up a rebuilt king pin (brazil) ...this thing is way heavier. Cut the shock tower mounts off of the frame.
The beam gives me about 2" more of shock height that the shock mounts would with the aluminum beam.
Picked up a disc kit also.... nothing fancy.
The height is pretty good but the tie rod (pass side) is close to frame. I think I will have to add drop spindles after all. Then I can slam the rail about 1 more inch!
Did I mention I picked up some badass Centerline wheels...they are awesome, but they will need thicker tires. I think I may go with bigger in the rear and keep the front as is. |
Posted: Thu Jun 21, 2018 11:25 am Post subject: Street Rail - fitted |
Front stance
The rear has some gas shocks. With the smaller tires and the lowering that will take place I will have to lift the motor/trans about 3 inches and weld a new mount.
Quick cpu sketch, but the frame will look like a simpler version of this when done. maybe....
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Thu Jun 21, 2018 11:39 am Post subject: Re: Street Rail - fitted |
I don't want to rain on your parade, but before you invest a ton of money...
http://www.thesamba.com/vw/forum/viewtopic.php?t=700798
Posted: Thu Jun 21, 2018 11:51 am Post subject: Re: Street Rail - fitted |
Thanks Dale, but the law wont rain on my parade. I ride with my middle finger up just so they know not to attempt to pull me over.
Works every time! |
di11ard Samba Member
Posted: Thu Jun 21, 2018 8:45 pm Post subject: Re: Street Rail - fitted |
Fuckin awesome. I look forward to the updates. |
Fenix Samba Member
Joined: October 05, 2016 Posts: 468 Location: St Louis
Posted: Fri Jun 22, 2018 7:58 am Post subject: Re: Street Rail - fitted |
javashot wrote: |
Works every time! |
What Dale was nicely trying to say is...As it stands the titling, licensing, and on-road insurance issuing is/was on hold pending further hearings. An initial round of title and license revocation already happened about 1 year ago. Hence why many rails and "manx" buggies went up for sale in texas and just across the boarder in Arkansas. Shot last forth of July I was in Fort Smith AR. One of the used car lots had 20+ buggies and rails all with Texas plates on them for sale. Most for under 4K. |
Posted: Fri Jun 22, 2018 8:28 am Post subject: Re: Street Rail - fitted |
I am not an expert on lowered beams... But I have learned a lot over the last couple years.
The goal to reduce bump steer is for the tie rods to be parallel to the ground. Obviously you are not in this category. One thing you can do is flip the tie rods to the underside of the spindle arm. Although a lowering spindle would be ideal, flipping the tie rod would be a good bandaid until new parts can be sourced.
What size wheels/tires are you running in the second pic? That setup looks killer. |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Fri Jun 22, 2018 10:55 am Post subject: Re: Street Rail - fitted |
I hope you have huge arms. Steering that thing with those wide tires up front is either going to take a giant wheel, or a lot of muscle! |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5411 Location: Holland, MI
Posted: Fri Jun 22, 2018 11:14 am Post subject: Re: Street Rail - fitted |
Yeah, that’s what I was thinking. That’s also a lot of extra stress on the front suspension. Wide tires may look cool, but they don’t really gain you anything on a vehicle like this. Really, too wide on something this light up front and it really just makes it worse. There is a reason rails run skinny tires up front. But if what you are going for is looks, go for it man. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
Fenix Samba Member
Posted: Fri Jun 22, 2018 11:46 am Post subject: Re: Street Rail - fitted |
Bashr52 wrote: |
Electric Power Steering conversion. |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Fri Jun 22, 2018 3:03 pm Post subject: Re: Street Rail - fitted |
1st thing I would do is put that battery in a box, nothing like battery acid in you face in a crash or big bump!
Casey _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
Posted: Mon Jun 25, 2018 12:52 pm Post subject: Re: Street Rail - fitted |
Fenix wrote: |
javashot wrote: |
Works every time! |
Thanks for the info...I am aware of the law and I feel optimistic about the progress and outcome. |
earthquake wrote: |
Casey |
for sure! |
Posted: Mon Jun 25, 2018 12:54 pm Post subject: Re: Street Rail - fitted |
Bashr52 wrote: |
Although it is harder to steer, it is not difficult. I do have huge sexy arms BTW... ahaha |
Posted: Mon Jun 25, 2018 12:57 pm Post subject: Re: Street Rail - fitted |
di11ard wrote: |
These are 245/45/15...I am considering 295/50/15 in the rear. Thanks BTW. I will go ahead with the drop spindles. |
Posted: Tue Jul 17, 2018 12:22 pm Post subject: Street Rail - fitted |
got a new MC to pump these discs out...
made some tubing
and I finally got the grinder out...looks over safety any day!
Posted: Tue Jul 17, 2018 12:24 pm Post subject: Re: Street Rail - fitted |
Dropped spindles finally arrived...I will put them on sometime in the next few days. |
cbeck Samba Member
Posted: Tue Jul 17, 2018 1:09 pm Post subject: Re: Street Rail - fitted |
Wow, I can put a 5 gallon fuel can under my beam. Your roads must be better than mine. _________________ My cut in half and rebuild thread
www.thesamba.com/vw/forum/viewtopic.php?t=647779 |
