Frodge Samba Member
Posted: Thu Jun 21, 2018 5:40 pm Post subject: Where can I source Bosch distributor grease? |
Anyone have a source? |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76946 Location: Sneaking up behind you
Tim Donahoe Samba Member
Joined: December 08, 2012 Posts: 11740 Location: Redding, CA
Posted: Thu Jun 21, 2018 6:03 pm Post subject: Re: Where can I source Bosch distributor grease? |
I saw a tube in line for $235.00.
Try Mallory. It’s getting harder to find, but still doable.
Tim _________________ Let's do the Time Warp again!
Richard O'Brien |
Glenn Mr. 010
Posted: Thu Jun 21, 2018 6:10 pm Post subject: Re: Where can I source Bosch distributor grease? |
Tim Donahoe wrote: |
Tim |
$225 in my link above.
_________________ Glenn
Member #1009
#BlueSquare |
Randy in Maine Samba Member
Frodge Samba Member
Posted: Thu Jun 21, 2018 6:26 pm Post subject: Re: Where can I source Bosch distributor grease? |
Glenn wrote: |
Tim |
I actually saw that. 🙄
What is the next best option? Mallory, lubricam? That dielectric tune up grease, I had read is not suitable for the points rubbing block. Also, how often and how much are you putting on? It goes directly on the rubbing block where it contacts the distributor lines, correct?
Before I started basically doing all the work myself in the past couple years, what vet the mechanic used as lube didn’t work well at all. My first set of points closed up, pitted, and the second set started closing up shortly after. When I installed my 205t, I used the Bosch grease. I was able to track and old vw guy down and I took the distributor to him before I installed it. |
Glenn Mr. 010
Posted: Thu Jun 21, 2018 6:36 pm Post subject: Re: Where can I source Bosch distributor grease? |
I've lubed more points that I bet anyone here. dielectric grease is not like Bosch Distributor Grease, so I would not use it. I've seen everything from wheel bearing grease to candle wax.
I've not see the Standard Lubricam but it "looks" like he best option.
Personally, i'm good for a few more years.
Member #1009
#BlueSquare |
Posted: Thu Jun 21, 2018 7:06 pm Post subject: Re: Where can I source Bosch distributor grease? |
Years ago, when you went to the VW dealer and bought Bosch points, you got a tiny gob of grease in a small press container.
And, Frodge, I put a thin layer grease all around the cam, where the points block runs. I’ve seen some who scrape a little onto the inner edge of the cam block; but I always thought that having the grease on there was not going to do anything. It’s the edge of the block that contacts the cam that matters.
Richard O'Brien |
Frodge Samba Member
Posted: Thu Jun 21, 2018 7:16 pm Post subject: Re: Where can I source Bosch distributor grease? |
Thanks Tim. I can’t find the Mallory lube anywhere. The lubricam, looks like it’s available. Crazy, what the heck is everyone with a classic car using? |
Glenn Mr. 010
Posted: Thu Jun 21, 2018 7:23 pm Post subject: Re: Where can I source Bosch distributor grease? |
Frodge wrote: |
Be glad you can still get points.
Bosch and other OE's have discontinued many models. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Thu Jun 21, 2018 7:28 pm Post subject: Re: Where can I source Bosch distributor grease? |
Frodge, unless you work on vintage distributors a lot, like Glenn, Bill, etc., a tube will last a lifetime. The makers of these products no longer sell that much of the stuff, so they apparently threw in the towel.
The fact that many just use wheel bearing grease didn’t help out the situation, either.
Also, I suspect a few gougers noticed a few years back that the stuff was getting hard to find, and they bought up as much of the stuff as they could afford.
Richard O'Brien |
Frodge Samba Member
Posted: Thu Jun 21, 2018 7:34 pm Post subject: Re: Where can I source Bosch distributor grease? |
Glenn wrote: |
Frodge wrote: |
Bosch and other OE's have discontinued many models. |
Glenn, what points and condenser is for the 205t. Where is the best place to pick them up....
How long does a set of points and condenser usually last?
Glenn Mr. 010
Posted: Thu Jun 21, 2018 7:35 pm Post subject: Re: Where can I source Bosch distributor grease? |
Tim |
Whenever I find a product I use regularly goes NLA, I invest in buying as much current inventory as I can find. This has allowed me not to have to raise my prices in 4 years.
There are people out there that do the same, but then charge exorbitant prices for these parts.
These people do deserve to earn a profit for but not to gouge. _________________ Glenn
Member #1009
#BlueSquare |
Cusser Samba Member
Posted: Thu Jun 21, 2018 7:54 pm Post subject: Re: Where can I source Bosch distributor grease? |
I saw a tube on line for $235.00. |
Heck, I'll sell my Bosch tube for half that !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Glenn Mr. 010
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Fri Jun 22, 2018 4:43 am Post subject: Re: Where can I source Bosch distributor grease? |
That stuff does last forever.
When I got the GWB years and years ago, someone sent me like a quarter teaspoon worth because I couldn't find it anywhere local.
I still have most of it. _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
Frodge Samba Member
Posted: Fri Jun 22, 2018 4:48 am Post subject: Re: Where can I source Bosch distributor grease? |
So the lubricam is the best 2nd choice? Because I got nuttin. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Jun 22, 2018 5:03 am Post subject: Re: Where can I source Bosch distributor grease? |
multi purpose grease is specified in the Bentley's, doesn't have to be Bosch.
And yes, I've been using anything but BOSCH for over 40 years on hundreds and hundreds of points with no problem of it flinging off like the myth states. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Frodge Samba Member
Posted: Fri Jun 22, 2018 5:05 am Post subject: Re: Where can I source Bosch distributor grease? |
60ragtop wrote: |
And yes, I've been using anything but BOSCH for over 40 years on hundreds and hundreds of points with no problem of it flinging off like the myth states. |
What do you use specifically? I need some to keep on my bench. |
