60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Fri Jun 22, 2018 5:07 am Post subject: Re: Where can I source Bosch distributor grease? |
I use that dreaded wheel bearing grease and always have. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Dwayne1m Samba Member
Joined: December 31, 2011 Posts: 3538 Location: Pennsylvania
Posted: Fri Jun 22, 2018 5:52 am Post subject: Re: Where can I source Bosch distributor grease? |
60ragtop wrote: |
I use that dreaded wheel bearing grease and always have. |
Then I'm not the only one. |
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Fri Jun 22, 2018 6:10 am Post subject: Re: Where can I source Bosch distributor grease? |
i successfully used the standard stuff for about 20 years before glenn gave me a tube of the real bosch grease...both very similar in consistancy....never tried the echlin stuff....they say its a moly grease rather than silicone based...amazon has the standard....and wheel bearing grease is certainly better than nothing at all |
Posted: Fri Jun 22, 2018 6:51 am Post subject: Re: Where can I source Bosch distributor grease? |
Here's a pic of the inside of an uncleaned original dist using regular grease, you can see it is not flung all over like the old wife's tale
tasb wrote: |
sb001 wrote: |
Randy in Maine Samba Member
Posted: Fri Jun 22, 2018 7:37 am Post subject: Re: Where can I source Bosch distributor grease? |
Hell bacon grease would beat nothing. Use that stuff in the link I posted and you will be fine.
Move on to other things. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31380 Location: Hot Arizona
Posted: Fri Jun 22, 2018 7:44 am Post subject: Re: Where can I source Bosch distributor grease? |
60ragtop wrote: |
I admit that I've used wheel bearing grease there successfully for many decades. I only re-discovered my tube of Bosch grease, was hidden away. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Fri Jun 22, 2018 7:59 am Post subject: Re: Where can I source Bosch distributor grease? |
Any chance that the "flung all over" thing was more due to applying too much, and in a glob, rather than a thin coat?
Glad I bought a tube of Mallory distributor grease when I could, though! _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Posted: Fri Jun 22, 2018 9:06 am Post subject: Re: Where can I source Bosch distributor grease? |
Randy in Maine wrote: |
Why ? because some don't agree with you and others about what to use and show alternatives?
Towel Rail wrote: |
Any chance that the "flung all over" thing was more due to applying too much, and in a glob, rather than a thin coat? |
Just stating something after reading the print in the link below and other things said here by the experts.
http://vwparts.aircooled.net/Distributor-Points-and-Input-Shaft-Grease-22058-p/22058.htm _________________ Rick
tasb wrote: |
sb001 wrote: |
Frodge Samba Member
Posted: Fri Jun 22, 2018 9:29 am Post subject: Re: Where can I source Bosch distributor grease? |
I have a restored 205t. Do I need to grease in any other place besides where the points rubbing block touches the cam and oiling the wick? |
Posted: Fri Jun 22, 2018 9:49 am Post subject: Re: Where can I source Bosch distributor grease? |
Just a dusting at the points rubbing block and you will be fine. Others wise you getting that "chirping" sound.
I also use dielectric grease on O rings, electrical connections (like light bulbs/sockets), ignition wires (at the cap and plug), and rubber things that needs some lube. |
Spezialist Banned
Xevin Samba Member
Posted: Fri Jun 22, 2018 12:54 pm Post subject: Re: Where can I source Bosch distributor grease? |
That was good _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
H2OSB Samba Member
Joined: April 14, 2013 Posts: 1294 Location: Modesto, CA
Posted: Fri Jun 22, 2018 1:05 pm Post subject: Re: Where can I source Bosch distributor grease? |
LOL |
H2OSB Samba Member
Posted: Fri Jun 22, 2018 1:08 pm Post subject: Re: Where can I source Bosch distributor grease? |
So if I've understood correctly, bacon grease is A OK. DONE!
Who knew.
H2OSB |
DurocShark Samba Member
Joined: April 05, 2004 Posts: 6624 Location: Crappy town in a crappy state. But the beach is nearby, so I have that going for me.
Posted: Fri Jun 22, 2018 1:12 pm Post subject: Re: Where can I source Bosch distributor grease? |
H2OSB wrote: |
Who knew.
H2OSB |
Best smelling distributor EVAR! _________________ No boom today. Boom tomorrow. There's always a boom tomorrow. |
AlmostHeavenWV_VW Samba Member
Posted: Fri Jun 22, 2018 1:15 pm Post subject: Re: Where can I source Bosch distributor grease? |
Frodge wrote: |
A simple search revealed this:
and this:
https://www.thesamba.com/vw/forum/viewtopic.php?t=595281&highlight=distributor+greas%2A _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Posted: Fri Jun 22, 2018 2:51 pm Post subject: Re: Where can I source Bosch distributor grease? |
if you saw some of the runny slop i had to clean out of wheel bearings 40 years ago you'd know where the concept of grease being flung around inside the distributor came from...the higher temps of disc brakes being the norm these days the current generation of wheel bearing grease is a far cry from what was available back then...i think that stuff WAS bacon grease |
Mos6502 Samba Member
Posted: Fri Jun 22, 2018 7:27 pm Post subject: Re: Where can I source Bosch distributor grease? |
The distributor shaft moves relatively slowly, I can't imagine it could fling anything thicker than 3-in-1 off.
I also find it hard to believe distributor grease was ever anything other than some preexisting formulation, repackaged and priced up. |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Jun 22, 2018 8:27 pm Post subject: Re: Where can I source Bosch distributor grease? |
Towel Rail wrote: |
Glad I bought a tube of Mallory distributor grease when I could, though! |
Absolutely true. If you take the time to spread the grease instead of just glob it on there, it's not likely to fling itself about even at 1,500 revs per minute (3,00RPM). _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
mcdonaldneal Samba Member
Joined: June 13, 2013 Posts: 2649 Location: Gullane, Scotland
