Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8700 Location: Sunset, Louisiana
Posted: Thu Jun 28, 2018 6:36 am Post subject: Re: 1961 Baja Resurrection |
ConcreteAce wrote: |
1987 AutoRama
I wish we could still buy a matching set of those tires! _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
dustymojave Samba Member
Posted: Thu Jun 28, 2018 11:43 am Post subject: Re: 1961 Baja Resurrection |
Q-Dog wrote: |
1987 AutoRama
I wish we could still buy a matching set of those tires! |
Especially at the prices they were originally sold at!!!!
But yes, they were excellent tires. Especially for out here in the desert. Radial casings would be fine. The fronts are now duplicated by Mickey Thompson brand as the "Mini-Mag". Those rears are not available. Nor are the original Gates XT Commando tires these were developed from, nor the Sand Blaster 915s that I still have on my Hi Jumper buggy. All excellent tires. The very 1st offroad tires I bought back in the early 70s were a pair of Gates Air Float Commandos. They were great as well. _________________ Richard
SoCalBajas Member
ConcreteAce Samba Member
Joined: May 19, 2005 Posts: 856 Location: Spring, Texas
Posted: Thu Jun 28, 2018 9:41 pm Post subject: Re: 1961 Baja Resurrection |
a little closer.... a ton of blocking in my future tomorrow
I can not wait for this stage to be over, it is gonna take me a week to empty my garage and clean it.
_________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'68 Turbo Diesel Baja
'64 Ghia Vert
'61 Baja Build |
Posted: Wed Jul 04, 2018 11:05 am Post subject: Re: 1961 Baja Resurrection |
Not a lot to show these past few day, just a ton of blocking and wet sanding. I did do a headliner clip delete. So I will be painting the interior.
Blocked with 180 and primed again, then wet sanded with 400
Headliner clip delete
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
murray7010 Samba Member
Joined: September 26, 2008 Posts: 146 Location: Salado, TX
Posted: Mon Jul 09, 2018 6:19 am Post subject: Re: 1961 Baja Resurrection |
Awesome work, Ethan! You don't mess around! _________________ 1951 Deluxe Sunroof Beetle (11C Model)
Follow the resto up to date on Instagram @SplittyMcFiddyJuan
10/2013----->http://www.youtube.com/watch?v=B2dHtL-_80g |
Posted: Sat Jul 14, 2018 3:58 pm Post subject: Re: 1961 Baja Resurrection |
and now we have a white baja. Dad decided he just wanted a solid color. So the main body will be white and the bumpers, rack , steps, and roll bar will be black
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Tue Jul 17, 2018 8:37 pm Post subject: Re: 1961 Baja Resurrection |
Well got the ol girl on the lift and removed the drive train. Plan is to just clean and replace what is worn. I will have to rebuild the front end the king pins are wobbly. I also have new brakes. I just cleaned and put a new fresh coat of paint on the trans. I asked the previous owner who installed the trans about the gear ratio. I am hoping to get some info on that soon if he remembers. It does have long axles and type 3 drums, so the bigger pad is a bonus.
I sprayed front and rear area with Raptor coating. it turned out great.
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
BigSherm Samba Member
Posted: Wed Jul 18, 2018 6:44 am Post subject: Re: 1961 Baja Resurrection |
Jeez, that’s looking great!
Scott _________________ Thanks, Hitler, for getting this car built!
Too bad you went and did all that other stuff, though. |
heywebonya Samba Member
Joined: July 08, 2010 Posts: 823 Location: Portage, MI
Posted: Wed Jul 18, 2018 10:39 am Post subject: Re: 1961 Baja Resurrection |
Looks sweet! _________________ If I knew what I was doing; I wouldn't be building a buggy! |
classic truck Samba Member
Joined: January 17, 2010 Posts: 33 Location: NW Arkansas
Posted: Fri Jul 20, 2018 2:23 pm Post subject: Re: 1961 Baja Resurrection |
Looks awesome! |
EnjoyNukaCola Samba Member
Joined: January 27, 2014 Posts: 491 Location: Santa Clarita
Posted: Fri Jul 20, 2018 3:09 pm Post subject: Re: 1961 Baja Resurrection |
Nice job, that's some quality work _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Sat Jul 21, 2018 8:34 am Post subject: Re: 1961 Baja Resurrection |
Thanks for all the kind words!
Well I finished spraying the bottom of the heater channels and the backs of the kit. If I get a good burst of energy I might have a roller by this weekend.
I really like the look of the bar sprayed with the Upol I am thinking that this is what I will do with the front bumper ,rear cage, side bars and roll bar.
I got the fenders mounted.
also cleaned and painted the frame horns and spring plates.
also got the parts in to rebuild the spindles
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Mon Jul 23, 2018 8:28 pm Post subject: Re: 1961 Baja Resurrection |
Well still chipping away at the ol girl.
Got the shift rod bushing replaced, I also replaced the shift rod, it had a later model in it and it took me forever to get the shift couple off. Front beam is mounted and trans is now in. Also replaced the brake lines and installed a dual master cylinders.
My youngest and oldest getting some garage time in.
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Tue Jul 24, 2018 4:36 am Post subject: Re: 1961 Baja Resurrection |
Looking great!
Just FYI, those solid trans mounts are really loud!
Posted: Tue Jul 24, 2018 6:54 am Post subject: Re: 1961 Baja Resurrection |
Bashr52 wrote: |
Looking great!
Solid mounts really don’t bother me. I have had more cars solid mounted than I have had that had stock mounts. Most of my cars have had big motors and loud exhaust as well. Other than feeling the vibration at the shifter once you add a 2 liter, IDA’s or IDF’s and a loud exhaust I really can’t tell the difference. _________________ Ethan Dunlap
Spring, Texas
'51 Deluxe
'61 Build
'64 Ghia Vert
'61 Baja Build |
Posted: Tue Jul 24, 2018 8:52 pm Post subject: Re: 1961 Baja Resurrection |
Could sure use braces to the motor mount saddle or the yokes. As well as a strap over the mid-front of the trans to prevent nose cone breakage. _________________ Richard
SoCalBajas Member
Posted: Tue Jul 24, 2018 9:12 pm Post subject: Re: 1961 Baja Resurrection |
This area is a concern for rust. See the yellow arrow:
I suggest you make a fairly large hole in the bottom of that square piece to let water, mud, dirt, road debris out of that pocket. _________________ Richard
SoCalBajas Member
