donemoto Samba Member
Posted: Fri Jun 22, 2018 8:09 am Post subject: looking for 71 Bus Distributor |
Looking for a 71 bus distributor. Like to find a used one at a reasonable price. What other distributors would perform the job with a 34 pict 3 carb? Is there a Beetle carb similiar? Not looking for 009 type. _________________ 1975 Campmobile
1962 Bug Convertible
Homebuilt VW Trike
1966 HD Sprint H
1940 HD ULH Flathead
1985 Electra-glide Classic with Tour-Pac
1968 Harley Rapido
1968 Honda CL Scrambler 175cc
1962 Honda Cub 50 Step-thru
1980 Honda Cub 70 |
Randy in Maine Samba Member
xyzzy Samba Member
Joined: March 24, 2014 Posts: 229 Location: Encinitas, CA
Posted: Fri Jun 22, 2018 8:41 am Post subject: Re: looking for 71 Bus Distributor |
Here's a handy reference:
_________________ -----
1973 VW Westfalia 2L hydraulic, dual Solex PDSIT
1987 VW Vanagon Westfalia |
SGKent Samba Member
Posted: Fri Jun 22, 2018 8:58 am Post subject: Re: looking for 71 Bus Distributor |
FYI - basically it says the can is no good on this one as the retard side is hosed.
Quote: |
The retard side is not working as it very typical. |
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Fri Jun 22, 2018 9:08 am Post subject: Re: looking for 71 Bus Distributor |
reach out to hazetguy, I think he has one. _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Fri Jun 22, 2018 9:12 am Post subject: Re: looking for 71 Bus Distributor |
Even though both have roughly the same total advance, the '71 bus distributor is different from bug units in that it has a lot of mechanical advance and not much vacuum advance, giving better torque. Tried both - big difference.
And yes, the vacuum retard diaphragm failure is typical. Because of the carb, can't set the idle properly with a failed one. Good luck finding a good one... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Fri Jun 22, 2018 11:39 am Post subject: Re: looking for 71 Bus Distributor |
You may want to buy that distributor and then try and locate a can to go with it. I have one as a spare but I have close to $300 invested in it.
Contact this guy: https://www.thesamba.com/vw/forum/profile.php?mode=viewprofile&u=24116 _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Jun 22, 2018 8:38 pm Post subject: Re: looking for 71 Bus Distributor |
The correct distributor for a 1971 Bus is a 211 905 205 Q Bosch # 0 231 173 001. Th vacuum canister for this distributor is very hard to come by NOS. You can find them used and even if the retard side doesn't work they can still be used. The same canister (arm# 853) is used on the 113 905 205 AH distributor used on the 1971-1973 semi auto Beetle. Not the easiest distributor to come by but at least it is an option. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Danwvw Samba Member
Posted: Fri Jun 22, 2018 9:16 pm Post subject: Re: looking for 71 Bus Distributor |
I seem to always find 205AN distributors there must be a lot of them. Seem fine with Dual Dells. So is the 009 for that matter. _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Sat Jun 23, 2018 4:21 am Post subject: Re: looking for 71 Bus Distributor |
skills@eurocarsplus wrote: |
reach out to hazetguy, I think he has one. |
Liar!!! I've got three of them! _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
wcfvw69 Samba Purist
Posted: Sat Jun 23, 2018 6:01 am Post subject: Re: looking for 71 Bus Distributor |
The one year only 1971 211905205Q distributors are out there but are drying up. When I have one restored, they sell quickly. The 853 vacuum canisters pop up occasionally but there are some folks selling NOS parts that grab them and mark them up aggressively to resell them.
I run one of these 205Q's I restored on my 1971 bus. When matched with the correct base flange number German Solex 34-3 carb, these engines run wonderfully in the heavy bay buses. The 853 vacuum can only advances the timing 3-5 degrees and retard the timing as well. I've run a bug distributor that had a vacuum advance of 10* and hated it. It was simply too much advance for a heavy bus.
The other challenge with the 205Q is finding one that's not worn out. The 1971 thru 1973 DVDA Bosch distributors were the lowest quality distributors made in the 70's IMHO. The points cams were not a very hard material. As such, the distributors would get dirty with dirt and grit. The points cam grease (when the owner used it) would pick up the grit and the points wear block would then grind it into the points cam face, undersizing the points cam lobes. You then see the the points cam not firing exactly 90* apart on the Sun distributor machine. The advance weight pins also wear heavily if the distributor was never taken apart, cleaned and lubed during it's life. Most weren't. Most people also mistakenly throw out the dust cap that keeps all the grit and the carbon from the distributor caps rotor button out of the internals.
These pictures show a heavily worn points cam.
This picture shows the wear on the advance weight pins. I've seen pins worn almost 1/2 way through in used 205Q's.
A side note on these 205Q's- I've taken apart close to a 100 of these the last couple of years. They show the most wear of any aluminum Bosch distributor I restore. Why? Many of them are found to be absolutely filthy with layers of dirt and grit that the distributor ingested during thousands of dusty, dirt road miles on the bus.
You can harvest points cams and advance weight parts from other DVDA distributors that are not heavily worn. The last 205Q I restored required me to take apart a total of 4 DVDA distributors to find enough parts still in spec to restore this one 205Q. That's why the prices are so high for these in fully restored condition. _________________ Contact me at [email protected]
The Samba member since 2004.
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Sat Jun 23, 2018 7:35 am Post subject: Re: looking for 71 Bus Distributor |
wcfvw69 wrote: |
The other challenge with the 205Q is finding one that's not worn out. The 1971 thru 1973 DVDA Bosch distributors were the lowest quality distributors made in the 70's IMHO. |
Totally agree. Those years Bosch dropped the engineering and quality of the materials.
Many are just worn past the point of restoring without needed 2-3 for spare parts. I guess Bosch learned something and improved the design and quality in 1974.
I would never buy one and would only do ones that were supplied by the customer. Just not worth buying one that's junk.
As to the retard, its mostly for emissions, so having a vacuum canister with a non functioning retard would be OK until you find a canister with working advance/retard. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jun 23, 2018 11:53 am Post subject: Re: looking for 71 Bus Distributor |
[quote="Glenn"]
wcfvw69 wrote: |
Glenn wrote: |
Bosch got cheap like VW did in the early 70's. Those DVDA's were a prime example. The materials were much better in 1974 when they changed the design of the internals. The metal hardness was much better. I rarely see wear on the advance weight pins or points cam in 1974 through 1979 Bosch VW distributors.
Glenn wrote: |
I won't pay much for any used DVDA. 80% are worn out of spec and as I mentioned, require other cores to make one good one. When I buy a bulk of used distributors, every once in a while I run across a low mileage DVDA. I had one apart that had only a few thousand miles on it. It was like new inside. It was cleaned, re lubricated, restored and it sold in a couple of hours. I took detailed photo's of it apart. Someone smart saw it was like new and grabbed it.
All the DVDA's were a part of the early smog devices for VW to meet the more stringent emission laws. Personally, I think they work best when used with all those "smog" parts like the throttle positioner and altitude correctors. The German Solex 34-3 carbs really need the dash pots installed as well as it slows the throttle down from slamming closed. _________________ Contact me at [email protected]
Glenn Mr. 010
Tcash Samba Member
Posted: Sun Jun 24, 2018 9:11 am Post subject: Re: looking for 71 Bus Distributor |
You might want to check the price on those before you press "Buy". _________________ Roads Scholar &
Glenn Mr. 010
Posted: Sun Jun 24, 2018 9:48 am Post subject: Re: looking for 71 Bus Distributor |
tasb wrote: |
You might want to check the price on those before you press "Buy". |
Tim, as you know price is set by supply and demand. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sun Jun 24, 2018 11:23 am Post subject: Re: looking for 71 Bus Distributor |
The other option when looking for a 211905205Q distributor is hold out for a NOS in the box one. I found 2 a couple of years ago in Germany. I bought them both. I kept one and sold the other. Nice to have a "good" spare.
BTW, I wouldn't buy any restored distributor from an auto house. They are all Cardone rebuilds. Search "Cardone" on this site. Plenty of folks have discussed and took apart one of these Cardone distributors. To say they are dumpster bait is an understatement. _________________ Contact me at [email protected]
Posted: Sun Jun 24, 2018 12:12 pm Post subject: Re: looking for 71 Bus Distributor |
a lot of good information so far. getting a headache from looking at distributors online. will continue on, though. _________________ 1975 Campmobile
Homebuilt VW Trike
1966 HD Sprint H
1968 Harley Rapido
1980 Honda Cub 70 |
Glenn Mr. 010
Posted: Sun Jun 24, 2018 12:50 pm Post subject: Re: looking for 71 Bus Distributor |
wcfvw69 wrote: |
...hold out for a NOS in the box one. I found 2 a couple of years ago in Germany. I bought them both. I kept one and sold the other. |
Tease _________________ Glenn
Member #1009
#BlueSquare |
