ndorian Samba Member
Posted: Sat Jun 23, 2018 8:51 am Post subject: Hello from Portsmouth, Va |
Hello my name is Nick and I just joined this site. I've been reading posts for a while but just bought an 83 diesel Vanagon camper. The previos owner seems cool and has two other T3's in his driveway. My first problem is that on the drive home from buying it I broke down. The engine was rebuilt less that 1oo miles ago and the p.o. replaced a lot of other parts so I was really bummed. A belt had broken. Here is the thing. All of the info including the fac. manual show two small belts, one going from alt to water pump and one from crank to water pump. Well my water pump has only one pulley. The crank does have two but the outside pulley is not inline with anything. The belt was gone when I pulled over so I don't have it for reference. It has to be one belt that covers all three pulleys. I measured the distance around the pulleys and bought two belts that are closest in inches, 35 and 36. I figured I could try but I would appreciate any help. The po says it was an import from Sweeden if that helps.
-Nick |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17007 Location: Retired South Florida
Posted: Sat Jun 23, 2018 8:57 am Post subject: Re: Hello from Portsmouth, Va |
Nick, post a picture of your engine compartment and pulley arrangement. The waterpump pulley should have 2 grooves as well as the crank pulley. From the factory, the waterpump pulley had shims between the pulley halves for adjusting the belt between the crank and the water pump.
A single belt may work, but you don't want to risk the waterpump slipping from lack of tension. Not saying it won't work. That you lost a belt indicates something is not aligned. Welcome to the Samba. _________________ ☮️ |
Posted: Sat Jun 23, 2018 9:28 am Post subject: Re: Hello from Portsmouth, Va |
Posted: Sat Jun 23, 2018 9:31 am Post subject: Re: Hello from Portsmouth, Va |
I can see that the alt and water pump dont line up well. So I guess I will start there. Also learned that new canvas on top doesn't mean she doesnt leak. Water on engine deck lid. Heavy rain last night though. Garage took on water too. Oh boy. |
Posted: Sat Jun 23, 2018 9:33 am Post subject: Re: Hello from Portsmouth, Va |
Thanks Mark. |
RoryGirl Samba Member
Joined: October 14, 2016 Posts: 768 Location: WestWorld Nanaimo BC
Posted: Sat Jun 23, 2018 10:16 am Post subject: Re: Hello from Portsmouth, Va |
That doesn't look rebuilt 100 miles ago to me! _________________ 1991 Double door pop top conversion |
Posted: Sat Jun 23, 2018 10:45 am Post subject: Re: Hello from Portsmouth, Va |
Yeah, well the p.o. said built up. I am starting to wonder about some things though. I would really like to learn how to work on it and that is why I joined this site. |
