chrisarnt Samba Member
Joined: November 28, 2005 Posts: 541 Location: New Jersey
Posted: Sat Jun 23, 2018 10:04 am Post subject: What tells the ecu to fire the cold start injector? |
The thermal switch?
Head sensor?
What’s the correct resistance across the pins? |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sat Jun 23, 2018 11:06 am Post subject: Re: What tells the ecu to fire the cold start injector? |
The ECU plays no part in the CSV's operation. The double relay sends power to the TTS while cranking, if the TTS is cold enough it will energise the CSV, this can be a second or two in sub zero temps, or milliseconds if it's warm out, if it's cranked recently and the TTS is still warm the CSV won't squirt at all.
http://www.ratwell.com/technical/DoubleRelay.html _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sat Jun 23, 2018 1:43 pm Post subject: Re: What tells the ecu to fire the cold start injector? |
Looking at the L jet manual the resistance goes to infinity about 68 degrees.
So, is it safe to assume that the cold start valve plays no part in the mix above that temp?
I'm guessing I shouldnt worry about it. |
vwoldbug Samba Member
Posted: Sat Jun 23, 2018 2:13 pm Post subject: Re: What tells the ecu to fire the cold start injector? |
Correct |
