Deebs Samba Member
Joined: June 23, 2018 Posts: 248 Location: Chattanooga, TN
Posted: Sat Jun 23, 2018 3:25 pm Post subject: Back right wheel smoking? |
Took my 1970 bug out for a ride last week, got into a friend's driveway where I pulled the parking brake. I noticed it pulled up higher (more clicks) than usual). Well, stayed for a while and then left. Disengaged the parking brake and drove home. I noticed the ride was rougher on the way home. I got into my driveway where I noticed my back right brake was smoking and the hubcap was hot enough to fry an egg. I have the wheel off and have loosened the shoes using the adjustment star nut on the back. Thoughts on what it might be? The brake is definitely stuck, no doubt. Curious if it may be a cable or a spring issue? Thanks guys (first post!) |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
Posted: Sat Jun 23, 2018 3:35 pm Post subject: Re: Back right wheel smoking? |
Most likely a spring issue. Unless you messed with the brake pushrod length recently.
Likely you'll need a brake hardware kit and have to clean stuff up. Make sure the shoes are fully in the slots. I'd do both rears, then readjust the brake shoes. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Joined: August 31, 2013 Posts: 12854 Location: North Carolina
Posted: Sat Jun 23, 2018 3:40 pm Post subject: Re: Back right wheel smoking? |
Internally collapsed brake hose or a binding parking brake cable. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Deebs Samba Member
Posted: Sat Jun 23, 2018 3:42 pm Post subject: Re: Back right wheel smoking? |
Cusser wrote: |
Likely you'll need a brake hardware kit and have to clean stuff up. Make sure the shoes are fully in the slots. I'd do both rears, then readjust the brake shoes. |
Thanks for the tip, as soon as I get the drum off I'll check. |
Cusser Samba Member
Posted: Sat Jun 23, 2018 4:44 pm Post subject: Re: Back right wheel smoking? |
TDCTDI wrote: |
Internally collapsed brake hose or a binding parking brake cable. |
Yes, these are possibilities too. I've experienced the brake hardware part myself. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Deebs Samba Member
Posted: Sat Jun 23, 2018 5:34 pm Post subject: Re: Back right wheel smoking? |
Cusser wrote: |
TDCTDI wrote: |
Yes, these are possibilities too. I've experienced the brake hardware part myself. |
I've noticed with the parking brake down the back brake is still stuck. Trying to back out of the driveway the back right wheel actually acts as if it's going over a speed bump or rolling over something. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sat Jun 23, 2018 5:37 pm Post subject: Re: Back right wheel smoking? |
edit bad reading skills _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
EverettB Administrator
Joined: April 11, 2000 Posts: 69820 Location: Phoenix Metro
Posted: Sat Jun 23, 2018 6:15 pm Post subject: Re: Back right wheel smoking? |
TDCTDI wrote: |
Internally collapsed brake hose. |
I vote for this since it's happened to me a couple times on cars I bought.
Open the bleeder valve, if fluid sprays out and now the wheel spins freely, that's your problem.
Jacking up the car may make it easier to tell.
Step on the brakes pedal a few times and if the wheel is stuck again, definitely the rubber hose.
If one is bad, change both sides or even better, all 4.
If it was hot enough to start smoking, be prepared to need new seals on the wheel cylinder, you might have melted them.
I've done that before. _________________ How to Post Photos
Cusser Samba Member
Posted: Sat Jun 23, 2018 6:38 pm Post subject: Re: Back right wheel smoking? |
I had stuck rear brakes on my 1971, needed new brake hardware and not hoses.
Bottom line is no one knows for sure. Open the bleeder valve, that should help isolate if it's free then !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Deebs Samba Member
Posted: Sat Jun 23, 2018 6:40 pm Post subject: Re: Back right wheel smoking? |
EverettB wrote: |
TDCTDI wrote: |
I've done that before. |
I think you guys are right. Took my boot off the e-brake and I've got play in both cables so they're not seized. |
Cusser Samba Member
Posted: Sat Jun 23, 2018 6:46 pm Post subject: Re: Back right wheel smoking? |
Deebs756 wrote: |
I think that "seized cables" were a less likely scenario. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Deebs Samba Member
Posted: Sat Jun 23, 2018 7:18 pm Post subject: Re: Back right wheel smoking? |
Cusser wrote: |
Deebs756 wrote: |
I think that "seized cables" were a less likely scenario. |
My terminology sucks, I'm new to mechanics but I'm trying to learn!! |
Deebs Samba Member
Posted: Sat Jun 23, 2018 9:14 pm Post subject: Re: Back right wheel smoking? |
If it is a brake hose, will I be able to replace without bleeding the master cylinder? |
Posted: Sat Jun 23, 2018 10:40 pm Post subject: Re: Back right wheel smoking? |
Deebs756 wrote: |
You have to bleed the brakes after a hose or wheel cylinder replacement but nothing directly related to the master cylinder other keeping the reservoir full while you bleed _________________ How to Post Photos
bluebus86 Banned
Posted: Sun Jun 24, 2018 6:50 am Post subject: Re: Back right wheel smoking? |
if the hubcap was hot enough to fry an egg, the wheel cylinders rubber bits maybe damaged, it would make sense to examine it internally. Wheel cylinders are cheap, might be worth replacing, check it out.
Shoes may also have been damaged, check appearance of the shoe, make sure lining is not separating from the shoe. compare shoes to that on opposite side, if one is really worn more than other, it is wise to replace the entire rear set for even braking action.
If hot enough, the oil seal found on early Bugs (swing axle) maybe damaged. if later Bug with IRS the bearing grease may have over heated.
The damage all depends on how hot it got.
Next time the Bug is not acting normal, stop and inspect before driving more.
Bug On, Now Stop It! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
EVfun Samba Member
Posted: Sun Jun 24, 2018 7:51 am Post subject: Re: Back right wheel smoking? |
One thing I don't see mentioned is the wheel cylinder. When they get rusty inside they may seize. The pressure when using the brakes will expand them but the rust will keep them from returning.
If cracking and tightening the bleeder causes that wheel to spin free again it is likely the flex hose. If it leaves the wheel stuck it is likely a rusted wheel cylinder. _________________
Wildthings wrote: |
vamram Samba Member
Posted: Sun Jun 24, 2018 8:01 am Post subject: Re: Back right wheel smoking? |
I had an issue similar to this a few months ago on my (since sold) '72 Super Beetle. I'm not ASE certified or anything, but I replaced spring kits, wheel cylinder, soft lines (steel-braided lines actually) and it kept happening. The problem in my case ended up being an out of round drum. That was the last thing that occurred to me since the drum wasn't even 3 years old, but there you have it. Cheap chinese drum. _________________ Eventually, "we are what we pretend to be.’”
Give peace a chance - Stop Russian-Soviet Aggression!!
'75 Super Le Grande...waiting it's turn in line behind '74.
Click to view image
Save the Supers!! |
Deebs Samba Member
Posted: Thu Jun 28, 2018 6:42 am Post subject: Re: Back right wheel smoking? |
Okay guys, finally got the drum off and got some investigating done! Top spring isn't moving at all?
There is quite a bit of play in the parking brake cable when it is disengaged, and wobbles back and forth. As if it is not sitting flush against everything else. I noticed when it was engaged and then disengaged, the front shoe does not move at all.
Take a look at my photos, and please watch the video (only 41 seconds) and let me know what you think.
https://youtu.be/U-dH91Iu4Dk
Cusser Samba Member
Posted: Thu Jun 28, 2018 7:06 am Post subject: Re: Back right wheel smoking? |
Your horizontal spacer bar is installed incorrectly. The same part is used on BOTH sides, VW didn't make a mirror image part for the right side. So on the right side the "channel" in the middle must face up. There also should be a clip to help hold that spring in place.
See these right side photos, the second photo shows it best.
Deebs Samba Member
Posted: Thu Jun 28, 2018 7:26 am Post subject: Re: Back right wheel smoking? |
Cusser, I see what you're saying. Thanks for the help. I guess this would explain why these are backwards and does not hold the parking brake lever as it should.
