Starbucket Samba Member
Posted: Tue Jun 26, 2018 8:14 am Post subject: Turn signal flasher |
I have a 70 Ghia and my turn signals are not working. Does anyone know how to bench test the flasher unit? All bulbs are tested and grounds are good at each light unit. I checked and cleaned all the fuses. Everything worked good then nothing works after it sat for 2 1/2 Mo.s (left, Right, and 4-ways). |
jeffrey8164 Samba Member
Joined: January 06, 2018 Posts: 3819 Location: Georgia
Posted: Tue Jun 26, 2018 10:42 am Post subject: Re: Turn signal flasher |
Check the relay and connections. Could be as simple as a wire popped off. Or the relay could be on its way out. Tap it while power is applied and it could free up. If it does, replace it as it will happen again |
Posted: Tue Jun 26, 2018 12:02 pm Post subject: Re: Turn signal flasher |
jeffrey8164 wrote: |
Ok, I'll pull each wire off and clean the spade and try the tap test when the wife gets home. Thanks |
Posted: Thu Jun 28, 2018 3:58 pm Post subject: Re: Turn signal flasher |
Update Checked wires and cleaned and tapped on flasher and finally the 4-ways are working but that's it. I need a way to bench test the relay so I don't throw money at the wrong part. |
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5998 Location: Brooklyn
Posted: Fri Jun 29, 2018 7:43 am Post subject: Re: Turn signal flasher |
If the 4-ways work then the relay is good. Same relay for both turn signals and 4-way flashers.
The turn signals and 4-ways have different power sources though, and both run through the 4-way switch. The 4-way switch should have a black wire coming into terminal 15, that's power for the turn signals. 15 is switched power, that way the turn signals only work with the key on. That black wire should come direct from the fuse box.
The 4-ways are powered by a red wire to terminal 30 on the 4-way switch. 30 is always hot, so that's why the flashers work whether the key is on or off.
the 4-way switch passes through 12v from whichever power source depending on its position. When it's off, it passes the 12v from terminal 15 through to the + terminal on the flasher. When it's turned on, it does the same thing but the 12v is sourced via terminal 30.
The flasher relay, having 12v, will only flash when the load (the lights) is cut into the circuit. The way you do that is with the turn signal switch.
So I would look at the wiring from flasher terminal 49a to the turn signal switch and/or the switch itself. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Sat Jun 30, 2018 12:45 pm Post subject: Re: Turn signal flasher |
sjbartnik wrote: |
Turn signal switch tests good so it must be in the 4-way switch, I'm getting some electrical contact cleaner and spray in the switch. |
