Rear Drum Brakes Locking On (1972 Camper)
Page: Previous  1, 2, 3
Tcash
Tcash is offline
PostPosted: Wed Jul 11, 2018 9:20 am    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Make sure you get all the old grommet out of the fill hose. Ask me how I know?
Embarassed
Tcash
Ben Middleton
Ben Middleton is offline
PostPosted: Thu Jul 12, 2018 3:58 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Lol, I made sure to get it all out! I removed the pipe, checked for leaks and cleaned it all up. Only the lower grommet needed replacing.
I dismantled the Varga master cylinder. It was mostly clean inside. There was no visible cylinder paste inside, just brake fluid. I cleaned it out as best as I could with a combination of methylated spirits (denatured alcohol), a cloth and an air compressor. I tried my best to remove any contamination, but itís possible that thereís more in it now than there was before. I couldnít really tell because I used cylinder paste to rebuild it.
Bentley recommends silicone grease for a couple of areas but I didnít have any so I just used more cylinder paste.
I also dismantled, cleaned and rebuilt the pressure regulator again. I wanted to remove any residue from the brake cleaner I used before. I used the cylinder paste and brake fluid to rebuild it after cleaning with methylated spirits.
As I was refitting everything, I decided to check the clearance between the internal push rod in the servo and the master cylinder. There was no clearance. Quite the opposite. The depth of the tube on the master cylinder was 47mm, and the push rod was 54mm (approx). This means that the push rod had been opening the master cylinder at all times by 7mm.
The internal push rod is adjustable. I couldnít find any official resource that gave the necessary push rod clearance, but I found some discussions on The Samba that led me to giving it a 1mm clearance.
The bungs were also badly swollen. A comparison of the new vs old is shown below:
I have now bled the brakes and things are initially seeming to be much better. I wonít get a chance to test it until I have fitted the new handbrake cables and adjusted the drum brakes. I will hopefully have reached the conclusion by tomorrow!
Ben Middleton
PostPosted: Fri Jul 13, 2018 7:41 am    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Well, Iíve bled the brakes but the pedal is now soft and going to the floor. Iím stumped.
Maybe thereís a vacuum leak somewhere, but thatís my only idea. Anyone else have some suggestions?
Tcash
Tcash is offline
PostPosted: Fri Jul 13, 2018 10:45 am    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Did you Bleed the master cylinder first?
Ben Middleton
PostPosted: Fri Jul 13, 2018 2:08 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
My master cylinder doesnít have a bleed nipple, or if it has, then I havenít noticed it lol. I bled the pressure regulator, then the front right, front left, rear right and rear left wheels.
The pedal is better now that Iíve adjusted the shoes, but it still feels kind of squishy. Iím going to replace the servo vacuum hose tomorrow just in case thereís a leak and Iíll fit the handbrake cables.
Fingers crossed!
Ben Middleton
PostPosted: Sat Jul 14, 2018 4:01 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Another frustrating day.
I tried to install and set the handbrake cables but it seemed like I had to use almost all the thread. It was obvious I needed to readjust the shoes again.
I slacked off the handbrake cables and tried to adjust the shoes again. My problem is that when I make them fully tight and back them off by 3 clicks, the shoes are still causing a lot of friction. I back them off until I canít hear them rubbing anymore, but that was probably too much. The second time, I backed them off about 7 clicks on each shoe until they were still rubbing but mostly free. The handbrake now works at about half of the thread on the cables.
After a test drive, the left rear drum is cool but the right one is very hot so I obviously need to adjust those shoes even lower.
I also havenít bought any air hose for the servo yet so I canít give feedback on how the brakes perform.
And the cherry on the cake, I dropped a massive car jack on my toe and it swelled up to quite a size.
Fun.
Tcash
Tcash is offline
PostPosted: Sat Jul 14, 2018 4:41 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Do you have a Bentley? https://www.amazon.com/Volkswagen-Station-Wagon-Service-Manual/dp/0837616352
Tighten adjuster until a slight drag and then back off, 3-4 turns.
Bleeding sequence
To bleed the Master, crack the brake lines as if they where bleeder valves.
Right front, Left front, Right rear, Left rear[/img]
ToolBox
ToolBox is offline
PostPosted: Yesterday 11:59 am    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
You need to adjust the brakes first, re-bleed, adjust, re-bleed, adjust, drive, check adjustment and once adjusted and bled properly do you install and adjust the park brake cables. No tension on park brake cables till the bled and adjust portion is finished.
Ben Middleton
PostPosted: Yesterday 2:47 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Just curious, why do you need to keep bleeding? I have been through that process of bleeding it twice and adjusting it multiple times and I test drove it today.
Thankfully the rear brakes were cool when I returned, but the braking performance was dangerously bad. The pedal went completely to the floor and worked a bit better with some pumping. I know that means it is likely to have air in the system, but Iíve already bled it so many times. I donít understand how there can be any left in there. It may also be possible that Iíve adjusted the brakes shoes too low, but any higher and they rub on the drums.
Here is a video of me pumping the pedal before and after starting the engine. As you can see, my foot goes lower after starting the engine.
https://youtu.be/dn_b9wwFtI4
Any advice is greatly appreciated at this point!!
Wildthings
Wildthings is offline
PostPosted: Yesterday 3:02 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Some light rubbing is normal, just watch for excessive heating.
Tcash
Tcash is offline
PostPosted: Yesterday 5:10 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Brakes adjusted and bled. There is no way your pedal should be that low.
Watch the videos and make sure you are bleeding the brakes right.
Please bleed the Master cylinder first.
https://youtu.be/0DcY5iQMtg4?t=387
Then bleed the brakes in this order. This is right out of the Factory VW Service manual.
https://youtu.be/qt3WQmv8SX0
Good luck
Tcash
Ben Middleton
PostPosted: Yesterday 5:58 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Thatís honestly exactly what Iíve done. Iíve bled two or three times - in this order - master cylinder, rear brake pressure regulator, right front, left front, right rear, left rear.
Iím thinking the problem could be one of two things. Either I have adjusted the push rod wrong inside the servo or the brake drums are damaged to the point that I have to back them off too far to get them to stop dragging. However, I definitely canít move the drums with my hands when the pedal is fully engaged, which suggests that the rear brakes are functioning correctly - just too far down the pedal travel.
There definitely looks like thereís still air in the lines though. I just canít understand it.
As a side note, should the differential be moving the rear hubs when the gearbox is in neutral? Iíve noticed that the hubs only stop moving when the clutch is engaged.
timvw7476
timvw7476 is offline
PostPosted: Yesterday 6:01 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Fingers crossed!
you gotta go old skool & get a 1/2 gallon plastic milk container & two quarts of
fluid & some gloves. Full Immersion Time. Also some brake cleaner too.
Clean it before immersion,pump it till bubbles disappear, bolt it in & attach lines, spray it down again. Bled.
Wildthings
PostPosted: Yesterday 6:27 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
It is possible for the wheel cylinders to suck in air when you release the pedal. This is most likely happen with old cylinders and brakes that are way out of adjustment.
If you raise the corner you are bleeding it can help move any trapped air into the wheel cylinder so it can be purged, I have never found a need to do this on a VW though.
Tcash
Tcash is offline
PostPosted: Yesterday 8:37 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
The drums are not causing air in the lines.
To rule out the pushrod. Loosen the master cylinder mounting nuts and bleed the system. If they bleed out, the pushrod is too long.
Good luck
Tcash
guitarman63mm
guitarman63mm is offline
PostPosted: Yesterday 8:59 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
Are you sure you bled correctly? You're bleeding with the top bleeders on the front calipers, right? That is a massive amount of travel - assuming your M/C is now fine, either the rear wheel cylinders are sucking air, or there's something up with the way it's being bled.
Jimmy
- 1974 Safarť Custom Camper. 091 trans + Dual Weber 34 ICTs + Pertronix SVDA + 1.7L 914 T4 engine.
Wildthings
PostPosted: Yesterday 9:26 pm    Post subject: Re: Rear Drum Brakes Locking On (1972 Camper) Reply with quote
I can usually bleed the brakes on my late bay by just opening each bleeder in turn and letting the system gravity bleed. This may or may not work for you if there is a lot of air in the system. Yes on front calipers you need to bleed the upper bleed screw if there are two screws on each of your calipers.
Page 3 of 3
