Clatter Samba Member
Joined: September 24, 2003 Posts: 7549 Location: Santa Cruz
Posted: Thu Jun 28, 2018 6:34 pm Post subject: Brake Booster Vacuum Hose Grommet? |
OK,
We were trying to replace the power brake booster,
And when it came off,
The grommet at the barbed input,
Where the vacuum line comes in,
Was kind of gooey and chewed up.
Part #71(?)
The barbs seemed to have pulled the grommet apart.
Can't seem to find it mentioned for sale anywhere..
Upon trying to re-assemble,
We tried using one of these reservoir tube grommets to no avail.
http://www.westcoastmetric.com/i-22966772-211-833c.html
Maybe just get a fresh hose on?
This?
http://www.busdepot.com/j18127
Front to back? Huh?
http://www.busdepot.com/211611939
Maybe just a blob of black silicone might do the trick?
If anyone here has this one sussed out, please share the secret.
Much thanks! _________________ Bus Motor Build
What’s That Noise?!? |
Tcash Samba Member
SGKent Samba Member
Posted: Thu Jun 28, 2018 10:50 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
my 1977 has a grommet in the booster that the barb goes into. The hose then clamps to the barb. Part #71 is the clamp. It also shows up on the Early bay fiche. The grommet does not, or at least I can't find it either. The fiche shows the booster with a nipple on it. My 1977 is not like the fiche. I'll keep looking.
edit: I Googled "ATE Brake Booster grommet" and got quite a few hits that kinda look like what I would expect to fit the ATE booster. They range from $1.20 to $10 but all look alike. Good luck.
I grabbed this photo out of the Ronnin10's gallery- it shows the grommet
_________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Hoody Samba Member
Posted: Fri Jun 29, 2018 5:33 am Post subject: Re: Brake Booster Vacuum Hose Grommet? |
The part you are looking for is 211-611-833D. It’s used on all of the connections of the hard plastic lines including the check valve (5) if I am not mistaken.The grommets that go into the hard plastic line between the upper and lower reservoir is 211-611-833C (2). Bughaus has both in stock. |
Tcash Samba Member
Posted: Fri Jun 29, 2018 9:01 am Post subject: Re: Brake Booster Vacuum Hose Grommet? |
Hoody wrote: |
Clatter got the 833C's.
The od of the grommet is the same diameter as the od of the plastic line.
Do the plastic lines shrink that much over time?
The only thing I can think of is to soak the line in hot water or hit it with a heat gun and try and stretch the id of the plastic line?
Thank you
Tcash |
Hoody Samba Member
Posted: Fri Jun 29, 2018 10:46 am Post subject: Re: Brake Booster Vacuum Hose Grommet? |
I would not try to alter the hard plastic hose whatsoever. You are asking for big trouble. They are pre formed. I don’t have both grommets in front of me but I do recall that they are different. The “top” of the grommet is obviously different just looking at it. I think but am not sure that the “D” grommet may be thicker thus changing the ID. Go to German Supply’s website which has a very good picture of both of the grommets in question. |
Tcash Samba Member
Posted: Fri Jun 29, 2018 11:29 am Post subject: Plastic Brake Line Grommets |
211 611 833 C Brake Grommet, Brake hose to fill and master reservoir
#59 list Qty2
211 611 833 D Brake Grommet,
#63 list Qty1
SGKent Samba Member
Posted: Fri Jun 29, 2018 1:48 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
no - like this on the booster. The inner grommets TCash showed go inside the plastic hose ends to seal them. Turn to like glue over time. Not used where the barb goes into the booster. Autohauz is where this photo comes from - it looks like the one on my 1977 booster. The part or one like it does not show on the VW fiche.
Tcash Samba Member
Posted: Fri Jun 29, 2018 5:22 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
SGKent wrote: |
no - like this on the booster. The inner grommets TCash showed go inside the plastic hose ends to seal them. Turn to like glue over time. Not used where the barb goes into the booster. Autohauz is where this photo comes from - it looks like the one on my 1977 booster. The part or one like it does not show on the VW fiche. |
The one we are talking about is the Inner grommets, inside the plastic hose ends.
The 833C's Clatter got slide nicely onto the master cylinder reservoir fitting. But the Plastic hose end is too small to slide over the grommet.
The grommet in the booster is in good condition.
Thank you for posting
Tcash |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51152 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Fri Jun 29, 2018 5:31 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
The bigger question is did you get all of it out?, or is some still rattling around inside the booster?
I'd go for a trip to the wrecking yard and eye up some other cars, that looks like a somewhat common part on many cars/trucks/vans. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Fri Jun 29, 2018 5:48 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
I have read clatter's comments many times and we are interpreting it differently. I do know what these parts are. You'll find a thread back around 2009 where I detailed which piece goes where. My 1977 has all these parts and I had to source them because the PO cut some off to use garden and aquarium hose rather than the correct parts.
Where the hard plastic hose slides over things, the rubber grommets shown go. They get gooey with age. There are several of those used on the hard plastic line - each place the plastic line goes onto something one is used. There are two different diameters.
Where the hard plastic barb goes into the booster itself there is a round rubber grommet that also gets gooey. When the barb that goes into it is pulled out it comes apart. That part is not on the fiche.
There parts go on the hard plastic line where it slides onto the booster fitting.
This part goes on the booster where that fitting goes into the booster. It is NOT on a fiche. It comes with the booster but some places sell it separately.
Tcash Samba Member
Posted: Sat Jun 30, 2018 6:34 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
SGKent wrote: |
Do you happen to have a part number for the Barb to Booster grommet.
I looked through your post, but could not find the 2009 post on the grommets.
Thank you
Tcash
It looks like the original old Servos had a pressed in metal nipple that was installed during during manufacturing. |
Tcash Samba Member
Guess I should have told you guy's that I need new glasses and a 1000 watt halogen light to see anything.
I got back under there today and stuck a screwdriver in the end of the plastic line and guess what pops out. The gooey old grommet. Might help if I removed the old grommets.
Damon got under there and installed the 211 611 833 D Brake Grommet, Booster barb to Plastic vacuum hose. I think Damon said the square end located in the hose.
Thanks to all that posted.
Tcash
Abscate I would have been blind a long time ago if what your dad said was true. |
mr. lang Samba Member
Posted: Wed Jul 04, 2018 12:26 am Post subject: Re: Brake Booster Vacuum Hose Grommet? |
Tcash wrote: |
SGKent wrote: |
Thank you
Tcash
ate 03.7718-7203.1 maybe ?
This is listed in the ate parts catalogue as vacuum grommet and looks exactly like the one pictured above in SGKents post.
EDIT: reverse search came up with VW 861 612 175 _________________ 1966 Bus | 1969 Bug | 1976 Passat LX two-door | 1984 Golf 2 C (daily driver)
There are three kinds of people: those who can count and those who can't
Und läuft ... |
Tcash Samba Member
Posted: Wed Jul 04, 2018 12:22 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
mr. lang wrote: |
Tcash wrote: |
SGKent wrote: |
Thank you
Tcash
EDIT: reverse search came up with VW 861 612 175 |
Thank you
IIRC the Booster that is available to us. Was originally manufactured for the Audi.
Does anyone know which model Audi's the Brake Booster fits?
ECS list the Audi models the VW 861 612 175 Grommet fits.
https://www.ecstuning.com/b-genuine-volkswagen-aud...861612175/
This site gives the dimensions of the seal in question.
https://www.autodoc.co.uk/car-parts/oem/861612175
ATE Seal, vacuum hose connector pipe
Number of article: 03.7718-7203.1
Reference number OEM: 861612175
(Submit a review)
Product info:
Thickness [mm]:9,5
Inner diameter [mm]:13,0
Outer diameter [mm]:28,0
ATESeal, vacuum hose connector pipe
Item number03.7718-7203.1
Tcash
Tcash Samba Member
Posted: Wed Jul 04, 2018 12:39 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
Tcash wrote: |
SGKent wrote: |
Tcash |
SGKent I owe you an apology. It clearly states that he is asking about the "Brake Booster Vacuum Hose Grommet".
There was no mention of this grommet being bad when we where working on the vehicle and it appeared to be in good condition to me. But we all know I need new glasses.
The one I was experiencing problems with was the Brake line grommet. So that was stuck in my mind. As we know, it helps to remove the old grommet before you try and put the new grommet in.
I Apologize
Tcash
PS Happy 4th |
ivwshane Samba Member
Joined: May 19, 2011 Posts: 1920 Location: Sacramento ca
Posted: Thu Aug 06, 2020 3:35 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
I was putting my booster vacuum hose back on when some hard rubber fell out. It appears that on both sides of the check valve there is a grommet sleeve that goes in both hard plastic pipes.
Is this what I need?
https://airheadparts.com/vw-part/grommet-sleeve-tube-to-servo-hose-211-611-833-d/
I know I need two in this particular spot but will I need more further up the line? _________________ 77 westy 2.0 FI
69 ghia coup 1600dp
70 single cab |
SGKent Samba Member
Posted: Thu Aug 06, 2020 4:16 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
probably. I say that because 10 years ago when I chased them, some retailers interchange the C and D. If you look earlier in the thread you see the way the parts originally looked. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
HikinFool Samba Member
Joined: September 08, 2016 Posts: 48 Location: California
Posted: Sat Oct 10, 2020 3:56 pm Post subject: Re: Brake Booster Vacuum Hose? |
I am currently replacing the last piece of hose for brake booster on a 1971 bus. It is the piece that connects to the forward most side of the booster (toward front of bus) and other end under left side of bus (where driver's hip?? would be above). All other hose I have used is 15/32" vacuum booster hose, and it fits fine, but this last piece that I have to replace is 5/8-3/4" inside diameter. I am not sure of the rules so I apologize if this is not allowed, but I screen shot someones else's picture to show where the front end of the hose would connect. My question is what is the correct size, length, and type of hose, and are there any grommets that are needed? Also, where does the other end attach, what is the purpose??
Any help would be appreciated!
Posted: Sat Oct 10, 2020 4:01 pm Post subject: Re: Brake Booster Vacuum Hose Grommet? |
The hose on the front bellows is the atmosphere vent, it doesn't have to be vacuum rated, any bulk watercooled heater hose will do just fine there, your FLAPS should have 5/8" ID on a roll by the foot.. Even clear vinyl hose would work, it just has to be waterproof and not kink. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
