kenney158 Samba Member
Joined: September 05, 2014 Posts: 121 Location: Easton, Pa.
Posted: Fri Jun 29, 2018 5:33 am Post subject: Erratic speedometer |
I have checked other posts, but not finding my exact situation. Travelling across very hot midwest (temps high 90s). Speedometer periodically jumps all over the place- actual speed between 60-75 but needle waves as high as 120 then drops but continues to waver. This lasts a few minutes then seems to return to normal.
Driving is not effected- so far. RPMs around 3,000. No change in power or speed.
I've seen posts suggesting the VSS may be bad- 2 questions- 1) how likely is it that the VSS is the culprit, and 2) what does the VSS effect besides the speedometer- does it communicate with other parts, e.g., engine or trans? Will there be eventual driving problems? (Okay, 3 questions.)
One post suggested possible low trans fluid level. Is this a possible cause?
Info is appreciated- especially since I'm on a 3 week road trip- |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Fri Jun 29, 2018 6:14 am Post subject: Re: Erratic speedometer |
It sound like a VSS, a bad one is quite annoying when you are using cruise control. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jun 29, 2018 6:50 am Post subject: Re: Erratic speedometer |
I can live with the annoyance- I'm avoiding cruise control since I don't know whether it is part of the problem. More concerned there will be some other related problem. |
Posted: Fri Jun 29, 2018 7:51 am Post subject: Re: Erratic speedometer |
Low fluid isn't going to cause wild swings of the speedometer.
Cruise control gets it's signal from the VSS via the instrument cluster so that will be affected.
Depending on year, the ABS & TCM can get weirded out by a failing VSS. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jun 29, 2018 10:01 am Post subject: Re: Erratic speedometer |
It's an 03 weekend. Not too concerned about ABS. TCM is what? Control module I know but can it be driven? Odometer of course is reacting to speedometer. Looks like I'm going3 miles when I go one? |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Fri Jun 29, 2018 10:13 am Post subject: Re: Erratic speedometer |
TCM= trans control module.
I second the VSS. Could be some "gunk" collected on the magnet on the tip. |
Posted: Fri Jun 29, 2018 10:15 am Post subject: Re: Erratic speedometer |
I'm. So tcm is important. If running ok can it be driven? Where is the bad? Can I reach it easily enough to clean it? |
Posted: Fri Jun 29, 2018 10:20 am Post subject: Re: Erratic speedometer |
Hate autocorrect. Where is the vss? |
Posted: Fri Jun 29, 2018 12:52 pm Post subject: Re: Erratic speedometer |
The VSS is on the top side of the extension coming off the passenger side of the transmission.
You shouldn't be doing any harm to anything by driving it, you might get some erratic shifting due to final drive correlation. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jun 29, 2018 1:58 pm Post subject: Re: Erratic speedometer |
At a dealer now. Tech says the weird signal could be due to a plastic cog inside transmission- which of course requires a tear down. No code coming from bad but could be going bad- just not enough yet to throw a code. |
Posted: Fri Jun 29, 2018 2:23 pm Post subject: Re: Erratic speedometer |
There's no "tear down" necessary! Replace the sensor, it's on top, no need to pull shit apart first. The sensor drive gear is easily removed AFTER you take the VSS off. If they try to charge you any more than 1 hr (typical dealer minimum charge), they're bilking you. Fu*&%ng weasel bastards. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jun 29, 2018 2:25 pm Post subject: Re: Erratic speedometer |
That's the plan. Replace sensor first and see if that corrects it. Would only do tear down if it doesn't. |
Posted: Fri Jun 29, 2018 2:29 pm Post subject: Re: Erratic speedometer |
If the plastic drive gear is bad, the sensor doesn't turn so therefore, no signal/no speed registered. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Fri Jun 29, 2018 4:11 pm Post subject: Re: Erratic speedometer |
Good to know. Tech suggests drive gear may be in process of going bad so slipping at times. But will see if sensor can do the job first. Of course, getting the parts is tough in Missouri. Laid up for now. Not will to continue the trip with chance of getting stuck on the high plains of Kansas with no shop in sight. Thanks for your help. |
Posted: Fri Jun 29, 2018 7:37 pm Post subject: Re: Erratic speedometer |
Just saw your post about the gear being accessible once the sensor is removed. Very helpful. I will use that when I talk to them about the job- |
tkbartscherer Samba Member
Posted: Thu Jul 05, 2018 5:52 pm Post subject: Re: Erratic speedometer |
I had the same exact issue and I fixed it myself.
It was a bad engine ground by the ignition coil on my 1999 Eurovan Camper. Fixed it immediately and for free. Check all grounds before anything else. This should help. Good luck! |
Posted: Fri Jul 06, 2018 9:27 am Post subject: Re: Erratic speedometer |
Thanks TK. Haven't communicated with dealer yet so don't have an update. I will definitely ask them to check grounds. I've been wracking my brain for causes- power washed (at the car wash) undercarriage before my current trip. Seems unlikely but wondering whether high pressure hoses/degreaser either spread gunk to sensor or may have effected a ground. Seems like a reach given that the pan was in place and got most of the spray hit there, but don't know what may have splashed around under there.
Will definitely point out the chance of a ground problem. |
Posted: Thu Jul 12, 2018 8:06 pm Post subject: Re: Erratic speedometer |
Left my EV at the dealer for more than a week while finishing my trip. Back at dealer now and being told transmission is needed. Blaming this on a leak and low fluid level. Van shifted fine when I left it here- except for some kick down from 4th to 3rd with the erratic speedo/VSS problem which brought me to them to start with. Feeling very mistrustful of dealer now. Seeing some fluid on pavement under van now- didn't have that when I left home 1200 miles ago.
As I understand it, erratic speedometer would have nothing to do with low fluid or trans problems. They have yet to repalce the VSS, so have no info on whether that corrects speedo problem. Tech reportedly drove it "20 minutes at 70-75 mph with no problem with speedo"- claimed it shifted rough, but again, I had no such experience.
Anyone with knowledge of Lee's Summit VW in Missouri?
How about Das Autohaus in Lawrence, Ks? Thinking of having it towed there for a second opinion. Will drive it tomorrow to look for rough shifting.
Any recommendations on reputable EV mechanics within 200 miles of Kansas City are welcome. |
Posted: Thu Jul 12, 2018 8:18 pm Post subject: Re: Erratic speedometer |
Also wondering about Volkswerks in Shawnee, Ks. |
Posted: Fri Jul 13, 2018 3:56 am Post subject: Re: Erratic speedometer |
The VSS can be very sporadic & May only act up after an hour of driving, every third day, why didn’t they replace it? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
