Blimpie Samba Member
Posted: Fri Jun 29, 2018 7:10 am Post subject: Ghia exhaust |
Hey all. Just joined up. Been a air head for many years. My question: i have a 70 ghia with a 1776 mill. i am looking for a good exhaust that I can get and NOT have to take anything off to adjust the valves. What have you guys found to be the best. I looked at A-1 but they said they didn't have a system that I could use without dropping the muffler. Someone mention Vintage Speed. Looking more towards mellow that horsepower. Any help you guys/gals could share would be absorbed with great interest!!! Thanks to all!! |
xzener Samba Member
Posted: Fri Jun 29, 2018 7:14 am Post subject: Re: ghia exhaust |
Have you seen the Trip Mil 2 tip exhaust? _________________ My 70 beetle was totaled Now to build the Ghia I always wanted. Rest in peace Ruby, I will miss you. Hello <insert Ghia name here>! |
sactojesse Samba Member
Joined: November 21, 2006 Posts: 2655 Location: Sacramento, California, USA
Posted: Fri Jun 29, 2018 9:48 am Post subject: Re: ghia exhaust |
What are the specs on your 1776? Stock heads? Heater boxes? Assuming "yes" to both, you'll be looking for a 1 3/8" exhaust that works with heater boxes. I'm partial to four-into-one extractors with dual quiet packs, but ground clearance is an issue with those. Most of the two-tip exhausts, e.g., "hot dog" and Empi GT, etc., are loud and don't particularly perform well. The Vintage Speed might be an exception, as they supposedly have a deeper, mellower tone. _________________ 1966 Karmann-Ghia convertible |
c21darrel Samba Member
Joined: August 31, 2013 Posts: 12850 Location: North Carolina
Posted: Fri Jun 29, 2018 12:18 pm Post subject: Re: ghia exhaust |
Turn them puppies up 45* & you could be sportin the first Bosozoku Ghia. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
kiwighia68 Samba Member
Joined: October 20, 2013 Posts: 2874 Location: Auckland, New Zealand
Posted: Fri Jun 29, 2018 1:28 pm Post subject: Re: ghia exhaust |
I've just installed the Vintage Speed "quiet" exhaust on my stock 1641 motor and it does have a slightly deeper sound. It's not as quiet as I expected, but the fit and clearance are both good. Looks good too. Very good workmanship.
Expensive, though. _________________ Festina lente - hasten slowly
1968 Ghia named Emiko
Resto completed Dec 2015 |
VeloMikey Samba Member
Posted: Fri Jun 29, 2018 2:18 pm Post subject: Re: ghia exhaust |
My A-1 Sidewinder has a V-Band so I loosen the clamp, remove a single nut and bolt and swing the muffler out of the way. Takes less than 5 minutes. Doesn't look like an after thought hanging off the back of the car. Sorry, it had to be said.
_________________ '58 Ghia 2387cc with a Berg / Folts 5 Speed
Ghia Build Thread https://www.thesamba.com/vw/forum/viewtopic.php?t=768748 |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Sat Jun 30, 2018 6:45 am Post subject: Re: ghia exhaust |
This thread is useless without sound clips.
Well OK, ... "useless" may be a bit too strong of a word, but isn't how an exhaust system sounds equally (or perhaps even more) important as how convenient it is when it comes to performing a valve job? |
Posted: Sat Jun 30, 2018 2:00 pm Post subject: Re: ghia exhaust |
KGCoupe wrote: |
This thread is useless without sound clips. :(
Well OK, ... "useless" may be a bit too strong of a word, but isn't how an exhaust system sounds equally (or perhaps even more) important as how convenient it is when it comes to performing a valve job? :) |
Okay, I get it. I'll try doing one later today. _________________ Festina lente - hasten slowly
SixtyThreeRag Samba Member
Joined: July 12, 2015 Posts: 101 Location: Fort Worth, TX
Posted: Sat Jun 30, 2018 9:30 pm Post subject: Re: ghia exhaust |
I don't have to remove anything to adjust my valves with my A1 Sidewinder exhaust. It's a bit in the way, but nothing I can't work around for a valve adjustment. The exhaust sounds great, and the build quality is top notch. I'll post a pic when I get a chance. |
Posted: Sun Jul 01, 2018 11:29 am Post subject: Re: ghia exhaust |
kiwighia68 wrote: |
KGCoupe wrote: |
Okay, I get it. I'll try doing one later today. |
I tried to post a video with before and after sound but can't get it to work. Sorry. _________________ Festina lente - hasten slowly
Posted: Sun Jul 01, 2018 12:47 pm Post subject: Re: ghia exhaust |
kiwighia68 wrote: |
kiwighia68 wrote: |
KGCoupe wrote: |
I tried to post a video with before and after sound but can't get it to work. Sorry. |
No worries, I tried to write a novel, run a half marathon and restore a Karmann Ghia once and couldn't get any of the three to work either.
tommu Samba Member
Posted: Wed Jul 04, 2018 7:20 pm Post subject: Re: ghia exhaust |
kiwighia68 wrote: |
Expensive, though. |
I had one too - with pre-heat. Louder than I liked but I doubt it’s louder than anything else non-stock. I went back to stock in the end for better pre-heat and sound and everything else. _________________ |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2504 Location: Santa Cruz, CA
Posted: Thu Jul 05, 2018 11:33 am Post subject: Re: ghia exhaust |
Blimpie wrote: |
Looking more towards mellow that horsepower. |
A good-quality stock muffler with tapered exhaust tips will provide just what you're looking for.
xzener wrote: |
Have you seen the Trip Mil 2 tip exhaust? |
I tried one of these 'hotdog' mufflers and found it to be annoyingly LOUD...especially when the motor is under load at mid-to-high RPM.
tommu wrote: |
I went back to stock in the end for better pre-heat and sound and everything else. |
I wound up doing the same...couldn't take the harsh racket from that Tri-Mil muffler any longer. Much happier now running a stock muffler with SS tapered tips. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
xzener Samba Member
Posted: Thu Jul 12, 2018 8:39 pm Post subject: Re: ghia exhaust |
sactojesse wrote: |
What are the specs on your 1776? Stock heads? Heater boxes? Assuming "yes" to both, you'll be looking for a 1 3/8" exhaust that works with heater boxes. I'm partial to four-into-one extractors with dual quiet packs, but ground clearance is an issue with those. Most of the two-tip exhausts, e.g., "hot dog" and Empi GT, etc., are loud and don't particularly perform well. The Vintage Speed might be an exception, as they supposedly have a deeper, mellower tone. |
Hello. my motor has 044 heads and I have decided to go with j-tubes. really would like it to be more mellow than loud. My motor guy says I will need at least a 1.5 inch header. Thanks for your time and help. It is very much apericiated! |
Posted: Thu Jul 12, 2018 8:41 pm Post subject: Re: ghia exhaust |
c21darrel wrote: |
Agree, you want to match your components. With my current exhaust I dont have to remove anything for the once a year valve adjustment. I used to run a hide-away where I did, it wasnt much extra, maybe 10 minutes to remove the muffler. My new system breaths better, no obstruction of valve covers, no hitting going in driveways, works for me. I had a guy build it for me, I think I spent less the $240? It's jet coated so no maintenance. Old school duels.
very nice!! |
Posted: Thu Jul 12, 2018 8:44 pm Post subject: Re: ghia exhaust |
kiwighia68 wrote: |
hello. do you have a picture of your set up? also where did you purchase your system? Thanks ever so much!! |
