Ted2 Samba Member
Posted: Fri Jun 29, 2018 4:22 pm Post subject: Wheel bolts vs studs and lug nuts |
Good afternoon everyone,
Is there any advantage to changing from the standard wheel bolts to lug nuts and studs like on a 356?
Thanks |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Jacks Samba Member
Joined: July 15, 2006 Posts: 2344 Location: San Clemente, Ca.
Posted: Sat Jun 30, 2018 8:39 am Post subject: Re: Wheel bolts vs studs and lug nuts |
RareAir wrote: |
much more easier... |
That made me laugh. Mrs. Prescott must be rolling in her grave! Thanks! _________________ Jack Staggs
Actual name |
Larmo63 Samba Member
Posted: Sat Jun 30, 2018 1:56 pm Post subject: Re: Wheel bolts vs studs and lug nuts |
Redundancy is redundant around here. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Sun Jul 01, 2018 7:54 pm Post subject: Re: Wheel bolts vs studs and lug nuts |
lug bolts on a Bug are just part of ownership... one gets used to it, in time... I had an old Mopar with lug bolts once, but they engineered a post on the hub and a hole in the wheel to hang the wheel on, to aid in putting the bolts on... 356 style is awesome-easy. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Sun Jul 01, 2018 9:26 pm Post subject: Re: Wheel bolts vs studs and lug nuts |
ZENVWDRIVER wrote: |
lug bolts on a Bug are just part of ownership... one gets used to it, in time... I had an old Mopar with lug bolts once, but they engineered a post on the hub and a hole in the wheel to hang the wheel on, to aid in putting the bolts on... 356 style is awesome-easy. |
Modern Porsche equips their cars with an alignment pin/tool. It simply threads into the rotor, you hang the wheel, install several lug bolts, remove the alignment pin, install last lug bolt.
_________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Sun Jul 01, 2018 10:21 pm Post subject: Re: Wheel bolts vs studs and lug nuts |
Ted2 wrote: |
Studs can help prolong the life of the threaded holes in hard-to-find brake drums.
Cast iron can be unforgiving if a bolt is cross-threaded.
I have never personally ruined a drum, but I have bought more than one VW that was missing a lug bolt . . . because the hole was stripped! _________________ Jesucristo es mi Seņor y Salvador! |
Posted: Mon Jul 02, 2018 6:21 pm Post subject: Re: Wheel bolts vs studs and lug nuts |
... interesting, I have had over 100 VWs and never experienced a stripped lug hole... guess if it happened though, i'd just run 4, out of five lugs.... _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Jacks Samba Member
Posted: Mon Jul 02, 2018 6:37 pm Post subject: Re: Wheel bolts vs studs and lug nuts |
Easy to shorten a bus lug nut and tap larger to fit _________________ Jack Staggs
Actual name |
Joined: August 31, 2013 Posts: 12815 Location: North Carolina
Posted: Tue Jul 03, 2018 5:45 am Post subject: Re: Wheel bolts vs studs and lug nuts |
Most of the stud kits seem to be made out of cold rolled cat turds, be sure to go outside of the VW aftermarket to buy quality wheel studs. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
