Frodge Samba Member
Brian Samba Moderator
Posted: Fri Jun 29, 2018 7:10 pm Post subject: Re: Harmonic Balancer. Good upgrade? |
Depends on the engine setup really. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
APPLEGREENVW Samba Member
Joined: November 30, 2003 Posts: 2388 Location: Seekonk,Massachusetts USA
74 Thing Samba Member
Posted: Sat Jun 30, 2018 12:57 am Post subject: Re: Harmonic Balancer. Good upgrade? |
Yes, where are you going to find a Fisher Dampener? |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Sat Jun 30, 2018 6:27 am Post subject: Re: Harmonic Balancer. Good upgrade? |
I investigated this a ways back and supposedly the type 1 should have one but the type IV does not. Changing the main bearing placement in the type V supposedly eliminates the issue with the type I harmonics.
When the right people see this thread they will state the technical reasons. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
bluebus86 Banned
Posted: Sat Jun 30, 2018 10:58 am Post subject: Re: Harmonic Balancer. Good upgrade? |
I have never needed one, the factory didnt supply them. For a stockish motor it probably is money not well spent. If vibrations of the crank where an issue, wed have a lot of crank/bearing failures, but stock Bugs dont suffer from that. the flat four is fairly well balanced by design with its opposed pistons. some other engine configurations are more susceptible to destructive vibrations.
Id pass on it, specially for the price quoted, but most my motors are close to stock. But even my 2180 cc Bug motor dont have one
Bug On _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sat Jun 30, 2018 2:35 pm Post subject: Re: Harmonic Balancer. Good upgrade? |
They are not currently available and were somewhere around $500 back when they were. They didn't sell enough to justify continuing making them. If you want some reading go to www.geneberg.com and read his opinion. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
