tobloyd Samba Member
Joined: May 28, 2018 Posts: 184 Location: Fountain Hills, AZ
Posted: Sat Jun 30, 2018 7:14 pm Post subject: Vanagon Vent airflow direction? |
It seems that the vents on the side of an air cooled vanagon are designed to scoop air in and channel it down to the engine compartment for cooling. But, does anybody KNOW that’ll be the case for certain?
The air is rushing past the side of the van at quite high velocity, and I know that increase in velocity corresponds to a decrease in pressure, so it’s certainly *possible* that the air is being scooped in somewhere from the undercarriage and being sucked *out* the vents (even though that seems counterintuitive).
Pease share if you happen to know the answer, and also please identify basis for your answer. Thanks! |
Paulbeard Samba Member
Posted: Sat Jun 30, 2018 7:23 pm Post subject: Re: Vanagon Vent airflow direction? |
There are threads on this…
Consensus seems to be that for water-cooled motors, the vents pull air down and into the engine at speed (they are forward-facing and angled to catch the air) and act as chimneys/passive exhaust when the motor is off or at a stop. Air-cooled motors use the fan to pull air down all the time. I missed that this was specifically about air-cooled motors: I thought it was understood that rear vents/scoops were the source of air for cooling. _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers
Jon_slider Samba Member
Posted: Sat Jun 30, 2018 8:05 pm Post subject: Re: Vanagon Vent airflow direction? |
deleted _________________ My Soapboxes: Inflation; Handling; Gearing; Decoupling; Swepco
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32432 Location: Reading Pennsylvania
Fiddlestyx Samba Member
Posted: Sun Jul 01, 2018 8:53 am Post subject: Re: Vanagon Vent airflow direction? |
Don't some vans have a long factory snorkel that goes up there and sucks air in to the intake?
My aircooled has a short snorkel that sits at the bottom of the chimney, therefore air would need to be going into the vents. _________________ 1983 Vanagon Westfalia Air-cooled
1973 Super Beetle |
Posted: Sun Jul 01, 2018 12:04 pm Post subject: Re: Vanagon Vent airflow direction? |
B-bear604 Samba Member
Joined: August 16, 2014 Posts: 118 Location: Delta BC
Posted: Sun Jul 01, 2018 8:30 pm Post subject: Re: Vanagon Vent airflow direction? |
So Dave I guess the air cooled is similar to the water cooled, as mine has a panel that blocks the airflow from the passengers side. The only air that passes is through the snorkel into the air cleaner. Of course the drivers side has no blockage so when your level sensor blows out of your tank the steam does come out the vent....but I was stuck in traffic and not moving. _________________ Brent H
1991 Westfalia Multivan "Vicki"
1986 Westfalia "Wolfsburg Edition" Lowered, RIP😭
2005 Jetta Wagon TDI
1985 Mercedes 380sl |
tencentlife Samba Member
Joined: May 02, 2006 Posts: 10067 Location: Abiquiu, NM, USA
Posted: Sat Jul 07, 2018 12:20 pm Post subject: Re: Vanagon Vent airflow direction? |
I've measured up to 1/2" water column differential across my oil cooler matrix at speed at 6500'ASL. Even with the engine at full power drawing its air from upstream of the cooler, there's still enough airflow down the pillar and enough depression in the engine bay to induce a substantial differential. 1/2" w.c. doesn't sound like a whole lot, but in a large sectional area such as this that much differential will move a sizable volume of air. For comparison, the oil cooler's fan moves 330cfm and produces a palpably strong blast of air out the cooler, yet at standstill produced no visible column change in the manometer. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6798 Location: Fort Lauderdale, Fl.
Posted: Sat Jul 07, 2018 6:26 pm Post subject: Re: Vanagon Vent airflow direction? |
I think if VW wanted the airflow to go up through the air vents from the engine compartment then the design would have the opening facing the rear instead of designing scoops facing the oncoming airflow.
Just my opinion. _________________ This free advice is worth exactly what you paid for it.
84Cabby82Westy Samba Member
Joined: April 03, 2004 Posts: 49 Location: Missoula, MT
Posted: Sat Jul 07, 2018 11:16 pm Post subject: Re: Vanagon Vent airflow direction? |
djkeev wrote: |
On an air cooled unit there is without a doubt air flow down the rear vents. |
Absolutely. With an air-cooled there is a seal around the tin to prevent air from being pulled from the bottom of the engine. If its missing, the engine will overheat. The license plate door is similarly sealed (or should be). The rear vents are the ONLY place to pull cold into the engine. When the engine isn't hot, you can feel a little bit of airflow into the vents at idle (or at least I can on my 82). At operating temps and at idle or when its turned off, heat does come out like a chimney (heat rises). I don't have any experience with a watercooled van, but I know they lack the engine tin, so maybe it works differently? |
Posted: Sat Jul 07, 2018 11:33 pm Post subject: Re: Vanagon Vent airflow direction? |
calo1956 Samba Member
Joined: April 18, 2011 Posts: 683 Location: long Island new york
Posted: Sun Jul 08, 2018 5:46 am Post subject: Re: Vanagon Vent airflow direction? |
I looked at the video Jon posted, I don't know how those streamers would do anything else on the highway, the velocity is just to much for them to be doing anything else. I don't know about you water cooled guys, but i do know that on my air cooled, those 2 vents are the only way cool air gets in and hot air escapes the engine bay. _________________ Enjoy the ride....
72 bug
80 westfalia |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 17009 Location: Retired South Florida
Posted: Sun Jul 08, 2018 6:23 am Post subject: Re: Vanagon Vent airflow direction? |
Idling, my 68 bus would hold a piece of paper against the outside of the vent. My intercooler is at the base of the chimney with a cutout under it. I don't run an elec cooler fan. There is enough air movement through the cooler at speed to maintain 30F over ambient. I suppose the air flow could be from bottom to top. I don't have those window vents on my 82 shown with the streamers above. _________________ ☮️ |
DanHoug Samba Member
Joined: December 05, 2016 Posts: 4715 Location: Bemidji, MN
Posted: Sun Jul 08, 2018 6:32 am Post subject: Re: Vanagon Vent airflow direction? |
tencentlife wrote: |
I've measured up to 1/2" water column differential across my oil cooler matrix at speed at 6500'ASL. Even with the engine at full power drawing its air from upstream of the cooler, there's still enough airflow down the pillar and enough depression in the engine bay to induce a substantial differential. 1/2" w.c. doesn't sound like a whole lot, but in a large sectional area such as this that much differential will move a sizable volume of air. For comparison, the oil cooler's fan moves 330cfm and produces a palpably strong blast of air out the cooler, yet at standstill produced no visible column change in the manometer. |
perfect! this is really the only measurement that applies. so with this real number, we can calculate the air velocity as Feet Per Minute airflow by taking the square root of the differential X 4005 = ~2800FPM. that's essentially a 30mph breeze in the vent cavity flowing thru the oil cooler. Chris- i assume the differential was measured at hwy speed, around 60mph? just as a point of reference, a straight 60mph headwind has a W.C. of 1.74"
i mounted my cooler in the drivers vent space as i had the room from my air cond delete. the faster i go, the better it cools as seen by reduced engine oil temps. the vent grill is always cool when i check immediately after stopping. if it was drawing engine bay air, it would be warm. empirical observations supporting measured data.
streamers taped near the vents are too subject to turbulence and kiting effect of the streamer itself to know much about the net air flow in the vent. a streamer IN the channel with a camera would be somewhat informative. _________________ -dan
www.thefixitworkshop.com |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Sun Jul 08, 2018 7:19 am Post subject: Re: Vanagon Vent airflow direction? |
This is all very confusing and upsetting to me, I think I will drive my Van out to a pub and sit on the patio for a while. I hope that my engine stays cool. Maybe I could tape my kids budgie to an air vent and see if it is in the engine Bay when I get there, or maybe it will be blown clear during the drive.
Vanagon song is cued up and ready on my playlist. Drive more, argue less.
Fahrvergnügen _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
dkoesyncro Samba Member
Posted: Sun Jul 08, 2018 10:23 am Post subject: Re: Vanagon Vent airflow direction? |
Okay, I believe on the water cooled it's simply a hangover of the air cooled era. It was the 80s and louvered plastic was a "styling" thing. It was a cheap alternative and also staying with a design that has become signature to VW vans since 68'.
Had scoops been added during the air-cooled t25-t3, prehaps it would have been slower, creating a drag effect similar to a parachute. It may of even blew apart the seal separating the top from the bottom.
Scoops have shown to work by grabbing air that travels down the sides at speeds. Scoops are another subject! |
Posted: Sun Jul 08, 2018 12:11 pm Post subject: Re: Vanagon Vent airflow direction? |
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4065 Location: East Kootenay, British Columbia
Posted: Sun Jul 08, 2018 12:17 pm Post subject: Re: Vanagon Vent airflow direction? |
The air vents on water cooled T3's are totally functional, serving to provide air both to the engine intake and helping to cool the engine bay. At speed air will travel down the stack and out under the vehicle, at rest the stack allows excess heat to vent upwards.
On the newer Vanagons with the plastic rear window vents, the airstream flowing along the side of the van will be somewhat diverted, lessening the inward flow to the stack. Hence, the add-on scoops to help.
Take a look at the newer "big window" T3's built in South Africa ('92-'03), these have a refined fresh air system which vents stale cabin air out of the rear of the van behind the air inlet at the stack.This eliminates the flow interruption of the window vent.
Clearly VW intended the vents to allow air into the engine bay even with the water-cooled versions.
I tried to find some clear pictures of the vent on these vans and only found a couple easy ones. You have to look closely to see the cabin air exit at the rear of the vent scoop.
https://www.gumtree.co.za/a-cars-bakkies/garankuwa...=Q317_Cars
https://www.gumtree.co.za/a-cars-bakkies/vereenigi...1263650309
https://campervanculture.com/2012/11/1992-south-af...ot-syncro/
https://www.youtube.com/watch?v=BQW88Z6w5bM
We've had this same discussion before. _________________ Currently:
Defend democracy, support Ukraine.
kamzcab86 Samba Moderator
Posted: Sun Jul 08, 2018 12:21 pm Post subject: Re: Vanagon Vent airflow direction? |
DanHoug wrote: |
perfect! this is really the only measurement that applies. |
Jack Bombay did the same manometer test years ago, the results of which were posted in this forum, which I then reposted in the above-linked, lengthy thread on the same topic. But some people *cough* completely overlook or disregard that scientific evidence, instead choosing to focus on stupid little streamers taped onto the van while being driven on a road with outside environmental influences, rather than in an isolated wind tunnel. Nevermind the fact that VW put the engine air intake into the D-pillar, nevermind VW adding scoops to the S.A. van D-pillars, and nevermind the other empirical data posted in prior threads.
DanHoug wrote: |
a streamer IN the channel with a camera would be somewhat informative. |
My GoPro is charged up. I'll do that this week just so we can finally lay this beaten dead horse to rest. My dad just suggested a hinged flap mounted inside the pillar. _________________ ~Kamz
2016 Golf GTI S
