Bmptree Samba Member
Posted: Sat Jun 30, 2018 7:38 pm Post subject: Wont Rev Past 3 Grand |
I have a 78 Bay with a 2 litre fuel injected motor.
recent complete build. approx 5000 kms
Its lifted 2 1/2 inches with 215/15 bfg's
I thought it felt sluggish because of the tires, but recent realized it wasnt rev ing over 3000 rpm
Sitting, in neutral, I can accelerate up to 3500 rpm, at 1/2 throttle/pedal, and then if craps out and drops and stays around 3000
Ive ......
swapped out three different dizzies, with different variations of new points, old points, condensors and electronic
swapped out coils
swapped out air flow sensor
pulled and cleaned throttle body
swapped out dual relays
checked compression
removed muffler
checked for full throttle cable
check fuel pressure
changed fuel filter
still same issue ..... ugh
you guys got anything? |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sat Jun 30, 2018 8:12 pm Post subject: Re: Wont Rev Past 3 Grand |
What’s the fuel pressure at high throttle under load? _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Sat Jun 30, 2018 9:25 pm Post subject: Re: Wont Rev Past 3 Grand |
Check to make sure your spark plug wires are 1-4-3-2 in CLOCKWISE orientation.
www.airschooled.com |
Tcash Samba Member
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51150 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jul 01, 2018 9:36 am Post subject: Re: Wont Rev Past 3 Grand |
Hydro lifters?, or solids? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Tue Jul 03, 2018 10:14 pm Post subject: Re: Wont Rev Past 3 Grand |
So, the fuel pressure was 2 psi over Bentley specs, both at idle and accel, and checked fuel pressure regulator. They are hydraulic lifters.
It runs great, but poops out at 3400 rpm. It flutters slightly at top rev, then drops and stays at 3000-3200 in neutral and driving |
cmonSTART Samba Member
Posted: Wed Jul 04, 2018 4:04 am Post subject: Re: Wont Rev Past 3 Grand |
I would hate to suggest it, but broken valve spring? Were the springs re-used? _________________ '78 Bus 2.0FI
de K1IGS |
Posted: Wed Jul 04, 2018 6:33 am Post subject: Re: Wont Rev Past 3 Grand |
How many turns preload on the lifters? _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Wed Jul 04, 2018 7:01 am Post subject: Re: Wont Rev Past 3 Grand |
The motor was built by a shop. I'm guessing the usual 1.5 or 2 turns.
I'm rechecking all valves today. Hope not to find any broken springs. |
Posted: Wed Jul 04, 2018 7:05 am Post subject: Re: Wont Rev Past 3 Grand |
Try temporarily resetting them all to 1/2 turn for a test and see if it helps, if the problem goes away we'll have to figure out which one is acting up. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
SGKent Samba Member
Posted: Wed Jul 04, 2018 9:00 am Post subject: Re: Wont Rev Past 3 Grand |
Do make sure the tach is accurate. There is a rev limiter in the ECU at 5400 RPM. Also if it has a catalytic converter that is plugged it will limit the RPM because of back pressure. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Wed Jul 04, 2018 10:09 am Post subject: Re: Wont Rev Past 3 Grand |
Tach is fine. Matched dwell meter. No cat |
Posted: Wed Jul 04, 2018 10:13 am Post subject: Re: Wont Rev Past 3 Grand |
busdaddy wrote: |
Try temporarily resetting them all to 1/2 turn for a test and see if it helps, if the problem goes away we'll have to figure out which one is acting up. |
Are you saying with less adjust it should run fine but one lifter will act up?
Pulled #4 and exhaust has weird wear. Not oval pattern? |
Posted: Wed Jul 04, 2018 10:25 am Post subject: Re: Wont Rev Past 3 Grand |
Weird wear on the lifter face?, that may be another issue.
If a lifter is pumping up it can temporarily stay open and drop a cylinder at higher revs, it feels like it has a governer on the engine, usually a little rough or shaky when it happens as well. Reducing the preload temporarily often solves the problem by allowing it to flush itself, but if it still does it after resetting to 1.5 turns you need to determine which cylinder is dropping to locate the faulty lifter.
Don't mix up any lifters, they have to remain in the same bore for the life of the cam. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Tcash Samba Member
Posted: Wed Jul 04, 2018 1:34 pm Post subject: Re: Wont Rev Past 3 Grand |
Lube your distributor lately?
Lubing the Distributor
Does your rotor look like this?
Rev speed limiting distributor rotor 1 234 332 208
Happy 4th
Tcash |
Posted: Wed Jul 04, 2018 7:04 pm Post subject: Re: Wont Rev Past 3 Grand |
So, I was at a reputable shop who checked lifters/valves and determined pull L possible cam failure. Waiting on an ecu/afm to arrive to cross those of list of exterior failures
ps: yes it's lubed and no, mines normal |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Jul 04, 2018 9:38 pm Post subject: Re: Wont Rev Past 3 Grand |
Youve checked for vacuum leaks, correct? I would think a vacuum leak after the afm, could cause a super lean condition causing a pop at 3400 and losing power at 3200. Does the power seem low? No... you said it ran fine up till 3000rpm... hmm... if check vacuum leaks still. _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Tcash Samba Member
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Thu Jul 05, 2018 9:09 am Post subject: Re: Wont Rev Past 3 Grand |
Don't know about that T., not in my experience. If it was almost completely flat, then yes. Just starting to wear? That's more like having carb jets or venturi that's too small for the engine- OK to a point, then it chokes and acts just like the OP is describing.
The other clue is the "funny wear" on the one follower the OP mentioned. Cams and followers just don't wear independently of each other for no reason.
I'll be really surprised if this doesn't wind up being a cam and lifter replace.
For the record, every worn Type 4 cam I've ever seen was in a solid lifter engine. This was a lot of the reason VW went hydraulic. It's been 20 years since I was elbow deep in these engines, though, aside from a few stragglers. The older things get, stuff starts wearing that never wore before. Look at our bodies.
OP, didn't you say this engine was just overhauled? Did they replace the cam and followers with fine aftermarket units or "rebuilt" ones, by chance? _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Thu Jul 05, 2018 11:09 am Post subject: Re: Wont Rev Past 3 Grand |
Thank you so for all your input.
Muchly appreciated
All new parts I believe, except crank |
