GregKnod Samba Member
Joined: April 11, 2005 Posts: 374 Location: San Jose, CA
Posted: Sun Jul 01, 2018 6:09 pm Post subject: Horn Ring Component? |
Want to confirm if this item is from the horn ring or in that section of the car. It fell out during the disassembly.
_________________ '73 Westy Weekender sharing the garage with a '66 Ocean Blue Beetle (daily drivers are out in the weather) |
hitest Samba Member
Joined: September 30, 2008 Posts: 9905 Location: Prime Meridian, ID
Posted: Sun Jul 01, 2018 6:34 pm Post subject: Re: Horn Ring Component? |
With no sense of scale- I'd guess if it's sitting on a hand towel then it's a horn wire anchor plate. It should have been held with a screw. _________________
EverettB wrote: |
'62 L390 151, '62 L469 117, '63 L380 113, '65 L512 265, '65 L31 SO-42, '66 L360 251, '71 L12 113, '74 ORG 181
FU#5 |
mukluk Samba Member
Joined: October 18, 2012 Posts: 5239 Location: Clyde, TX
Posted: Sun Jul 01, 2018 6:53 pm Post subject: Re: Horn Ring Component? |
Looks like the plate the turn signal switch set screw threads in to, holds the switch in place on the steering column tube. _________________ 1960 Ragtop w/Semaphores "Inga" |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7546 Location: Big Wonderful WYO 82401
Posted: Sun Jul 01, 2018 7:08 pm Post subject: Re: Horn Ring Component? |
yep for the turn signal set screw _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
sb001 wrote: |
maybe he just snapped cause his car sucked  |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14573 Location: 18 miles North of the border
Posted: Sun Jul 01, 2018 9:45 pm Post subject: Re: Horn Ring Component? |
Cool - thanks. _________________ '73 Westy Weekender sharing the garage with a '66 Ocean Blue Beetle (daily drivers are out in the weather) |
hitest Samba Member
Posted: Mon Jul 02, 2018 10:01 am Post subject: Re: Horn Ring Component? |
Good to learn !  _________________
EverettB wrote: |
FU#5 |
