Maine Samba Member
Joined: September 21, 2010 Posts: 150 Location: Maine
Posted: Mon Jul 02, 2018 12:22 pm Post subject: Bombay or Go Westy |
Go Westy's top lift strut kit is currently out of stock so I am looking at Jack Bombay's kit. I am in no big rush so should I wait for the Go Westy kit or is Jack's just as good?
Thanks |
Altoona Samba Member
Posted: Mon Jul 02, 2018 12:25 pm Post subject: Re: Bombay or Go Westy |
Bombay. Less invasive and works well. |
E1 Samba Member
Joined: January 21, 2013 Posts: 6544 Location: Westfalia, Earth
Posted: Mon Jul 02, 2018 12:28 pm Post subject: Re: Bombay or Go Westy |
We use both so it depends on how much weight you're lifting. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
Maine Samba Member
Posted: Mon Jul 02, 2018 12:33 pm Post subject: Re: Bombay or Go Westy |
Most likely a canoe or kayak, 100 lbs give or take. Thanks |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 9800 Location: Mt Lemmon, AZ
Posted: Mon Jul 02, 2018 12:46 pm Post subject: Re: Bombay or Go Westy |
I went with Jack's -- no drilling to install, works great (many years now).
You will want advice from those lifting loads as to how strong a strut you want to use. |
jimf909 Samba Member
Posted: Mon Jul 02, 2018 12:49 pm Post subject: Re: Bombay or Go Westy |
I bought and loved Jack Bombay. In addition to the three strengths of struts he sells (60, 90 and 120 psi) one can get a150 psi strut if you put way too much stuff on the roof.
Jack Bombay’s struts installed in 30 minutes? 60 max and that’s goofing around. They only require that you drill one hole per side. GW struts require a bit more work.
If I had to do it over I’d do the same thing.
Lotsa weight (8 towers, 4 bars, box, basket, etc.) Bombay struts with 150 psi struts (bought on Amazon for $30?)..,
_________________ - Jim
Abscate wrote: |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Mon Jul 02, 2018 1:31 pm Post subject: Re: Bombay or Go Westy |
I used JB's for a long time but had constant problems with one of the struts popping off when I'd close it. JB was very supportive via email and said it was due to the bolts from my rain gutters, but that wasn't the case. It's a very well-designed product but I couldn't figure out why I was having this problem.
I ended up buying the GoWesty kit and installing it, and it works fine. It's definitely more intrusive due to the holes and rivnuts, but it also seems more stable towards the front of the top due to its mounting position.
What I came to find out is the base of one of my push bars was loose. Every time I went to lift or close the top, the passenger's side base of the push bar would move about a half-inch either forward or back and make the top open and close unevenly, making a JB strut pop off. Duh.
So, having used both, I can say that they're both great products. JB's is a quicker, cleaner install and is less expensive to boot.
Had I paid more attention to everything that was happening with the lifting mechanism, I'd probably still be using JB's; however, since I went through the trouble of drilling, I'm using GW and it has worked fine.
TLDR: I'm an idiot and Jack Bombay makes a great product that is less expensive and easier to install. _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5911 Location: Tsawwassen, BC
E1 Samba Member
Posted: Mon Jul 02, 2018 1:51 pm Post subject: Re: Bombay or Go Westy |
Maine wrote: |
Agree with above, "Jack" is a great guy in our community and really deserves our support.
Okay, with just the 90 lb. Jack's it's perfect to easily -- almost automatically -- lift an empty roof.
We have a 62 lb. Yakima with about 120 lbs. or a bit more in it, so added the GW 160s. Perfect lift amount for our load.
Know if you have too much lift it's really hard to pull back down!!! _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
theadventureneverends Samba Member
Joined: December 24, 2009 Posts: 585 Location: Gig Harbor WA
Posted: Mon Jul 02, 2018 2:24 pm Post subject: Re: Bombay or Go Westy |
JB! |
chrisfreemanca Samba Member
Posted: Mon Jul 02, 2018 7:53 pm Post subject: Re: Bombay or Go Westy |
Maine wrote: |
Thanks |
Love the JB's! I got the dual kit so can swap out if needed for varying load weights. _________________ 87 2wd manual. |
Alaskaberrys Samba Member
Joined: June 19, 2016 Posts: 1001 Location: SE Alaska
Posted: Mon Jul 02, 2018 11:22 pm Post subject: Re: Bombay or Go Westy |
We’ve got Jack Bombay’s struts on our Westy - nothing on the roof (yet) so went with the lighter struts.
Best part, we were traveling through Utah and queried how we might arrange a spot to ship them too - turned out he was working a job on our route - invited us to stop in and pick them up. We did and to our surprise he installed them right then and there. In less than 10 minutes (I think he’s had some practice )
Great product and great guy. Highly recommend. _________________ '91 Westfalia, Bordeaux Red Pearl 2.1L 2wd Auto
'91 T3 Syncro Doka, Escorial Green 1.9L TD AAZ “Gremian” (to provoke, irritate, exasperate, vex...) |
Ride-Fly Samba Member
Posted: Tue Jul 03, 2018 4:29 am Post subject: Re: Bombay or Go Westy |
I bought the JB dual shocks and only use the HD struts. With only the Yakima bars and Skybox 18 on top, it provides a nice automatic lift. I can get the top down without any trouble. However, with my box loaded with about 130 lbs, it wasn’t quite up to the task of lifting the top. If I were to add a kayak or SUP, in addition to my camping load, I think I’d need additional assist, so I am considering adding the GW struts as well. |
markswagen Samba Member
Joined: January 28, 2018 Posts: 1030 Location: san diego
Posted: Tue Jul 03, 2018 7:20 am Post subject: Re: Bombay or Go Westy |
Another vote for the jack Bombay struts, I've fitted both, and prefer his. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
dgbeatty Samba Member
Joined: October 26, 2006 Posts: 702 Location: Sacramento
Posted: Tue Jul 03, 2018 9:54 am Post subject: Re: Bombay or Go Westy |
The GoWe$ty struts are a near copy of the factory struts, there is a picture in the ETKA. The Bombays are a little easier to install I guess, but not by much. For a really heavy roof the combination of the two is nice. My thought is that the Bombay style stresses the roof if the roof is loaded heavier toward the front. A final though, shoulhn't the top be supported by the available brackets that rest on the gutters. It is asking a lot of the latch and seals to support the heavier loads especially over rough terrain and strong winds? |
Maine Samba Member
Posted: Thu Jul 05, 2018 1:29 pm Post subject: Re: Bombay or Go Westy |
Thanks for all the replies ordered the JB lift struts today. |
E1 Samba Member
Posted: Thu Jul 05, 2018 1:59 pm Post subject: Re: Bombay or Go Westy |
Right call made, we gotta support the good guys. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32598 Location: Reading Pennsylvania
E1 Samba Member
Posted: Thu Jul 05, 2018 4:42 pm Post subject: Re: Bombay or Go Westy |
That's hilarious, same here.
Just saw him as a handyman on Andy Griffith a few nights back, but was far more enlivened by cousin Sabrina. _________________ ‘84 Westy, 2.1L with Digijet, 5.43 R+P, GT Gears
— Colin Chapman |
