mrhiggins312 Samba Member
Posted: Tue Jul 03, 2018 11:36 am Post subject: How come my 71 will not start after it warms up? |
New to me 1971 convertible super starts great in the garage; but once I've driven it for more than 30 minutes it has trouble (lots) with turning over again. Battery is charged and try to start but wont turn over. Recently tuned and gone over by a 'professional' air called mechanic but problem persists. |
Matt Wilson Samba Member
Joined: November 14, 2005 Posts: 2408 Location: Colorado
Posted: Tue Jul 03, 2018 12:33 pm Post subject: Re: How come my 71 will not start after it warms up? |
Sounds like it may be heat soak. When the engine is cold there is a tiny gap between the valve and the rocker arm adjuster screw. After it's warm, the metal expands closing this gap. If those gaps are not adjusted properly, the valves could be held open and you essentially don't have much compression for the engine to run. Then you'll kill your battery, starter or ignition switch trying to figure get it started again. I'd say it's worth checking your rocker arms on a cool morning after the car sat all night. Worth learning how to do if you are new to these cars.
After these engines warm up and then are shut off, they soak up the heat from the exhaust and the fuel in the carb gets hot, making it tough to start. If the carb and engine is tuned properly, you might try keeping your foot to the floor on a hot start rather than trying to pump the accelerator, which risks flooding the engine.
If it's vapor locked, a friend can hold their hand over the carb air intake and you work the key. This'll help suck fuel back into the carb to get it running again. _________________ 1972 Standard Beetle
1969 Baja Beetle |
Posted: Tue Jul 03, 2018 1:01 pm Post subject: Re: How come my 71 will not start after it warms up? |
Wow... thanks. That was an issue I had a couple decades ago on a 67 I owned but this happens a lot quicker and I had not considered it yet. Yes when I get out and let the wife start it the card trick works like a champ. Guess o have a small job to do once this heat lets up!! Thanks again. |
Deebs Samba Member
Joined: June 23, 2018 Posts: 248 Location: Chattanooga, TN
Posted: Fri Jul 06, 2018 4:22 am Post subject: Re: How come my 71 will not start after it warms up? |
Just in case it is vapor lock, check this video out. Might be an easy fix if you have some sand paper!
https://www.youtube.com/watch?v=eU6aVBW71Es |
Posted: Fri Jul 06, 2018 8:07 am Post subject: Re: How come my 71 will not start after it warms up? |
So I was able to drive and the trick worked to keep the pedal down. Played with Carb air intake and downed if I dent replicate so this weekend I will first try the sanding trick... then i will move the fuel line to see if either of those fix it. Thanks!! |
Joey Samba Member
Joined: August 12, 2005 Posts: 5366 Location: Nova Scotia - Canada
Posted: Sat Jul 07, 2018 2:28 am Post subject: Re: How come my 71 will not start after it warms up? |
Have you read the owner's manual on how to properly start a warm engine...
_________________ Joey
‘60 Kombi - '74 Bus - '79 Panel - '65 Beetle |
