Hoping for some guidance...rear shock mount sheared off
vwthingboy
vwthingboy is offline
PostPosted: Tue Jul 03, 2018 12:42 pm    Post subject: Hoping for some guidance...rear shock mount sheared off Reply with quote
Hey everybody,
Happy Summer!
So, the Short Version:
The rear passenger-side lower shock mount sheared off of the trailing arm.
The mount metal is still attached to the shock, which is now just dangling.
The mount metal is a little deformed and I assume can't/shouldn't be re-used or re-attached.
Can a competent repair shop re-weld or fabricate an attachment, which will work and be safe?
Should I think about replacing the trailing arm?
I have considered a set of +1" boxed trailing arms.
Background:
This situation was probably the unintended consequence of my 3" raised Doug Fuller spindles in the front, which necessitated adjusting the torsion bar splines in the back.
That probably put too much strain on the replacement shocks that my shop put in. Or maybe the length of the shock wasn't right.
Not sure how to progress.
Any thoughts are appreciated.
Duffer 2005-2012
Bashr52
Bashr52 is offline
PostPosted: Fri Jul 06, 2018 5:26 am    Post subject: Re: Hoping for some guidance...rear shock mount sheared off Reply with quote
Are you talking about this shock mount?
vwthingboy
PostPosted: Fri Jul 06, 2018 5:31 am    Post subject: Re: Hoping for some guidance...rear shock mount sheared off Reply with quote
Yes, that's the one
Duffer 2005-2012
califblue
califblue is offline
PostPosted: Tue Jul 10, 2018 10:47 am    Post subject: Re: Hoping for some guidance...rear shock mount sheared off Reply with quote
just buy a new trailing arm
Canadian VW
Canadian VW is offline
PostPosted: Tue Jul 10, 2018 11:44 am    Post subject: Re: Hoping for some guidance...rear shock mount sheared off Reply with quote
As a welder, if that trailing arm can be purchased easily I would definitely go that route and replace the entire unit.
Instagram: patrick_macpherson
Samba 67 Beetle build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=607949&highlight=
