joshlm Samba Member
Joined: January 10, 2018 Posts: 49 Location: Fresno, CA
Posted: Sun Jul 08, 2018 9:33 pm Post subject: Re: Oil spot analysis. |
My engine has been leaking oil and now the neighbors are calling the cops trying to get me in trouble for it. So I’m trying to indentify the solution. I’ll order some of those gaskets and hope that helps a bit. It is obviously dripping from the oil sump but also looks like it from the pushrods. PO said he replaced pushrods and no luck. I wasn’t worried about the leak at all until the neighbors are calling the police. The oil spot is in a very weird pattern. This is after sitting for 8 hrs in the working parking lot. Any thoughts?
_________________ 1970 Bug, first VW, first time doing my own wrenching |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31360 Location: Hot Arizona
Posted: Sun Jul 08, 2018 9:41 pm Post subject: Re: Oil spot analysis. |
May be time to ditch the crummy adjustable leaky pushrod tubes and the antique Claude's Buggies deep sump !!! _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Towel Rail Horizontally Opposed
Joined: April 15, 2005 Posts: 4622 Location: SE CR IA US NA PE
Posted: Sun Jul 08, 2018 9:44 pm Post subject: Re: Oil spot analysis. |
joshlm wrote: |
Your heads, cylinders, and tin are all wet with oil, so it's obviously not just the sump or pushrod tubes. Looks like you have a leak near the top of the engine that is getting spread all over before dripping down -- oil cooler seals perhaps? _________________ 1974 Thing -- under the knife
1967 Beetle -- spring/summer/fall driver
1996 Subaru OBW (EJ22, 5-speed, AWD) -- winter car, 3-seasons "don't feel like biking today" car
049 > 070 > 053 > 009 |
Frodge Samba Member
Posted: Mon Jul 09, 2018 3:05 am Post subject: Re: Oil spot analysis. |
Could also be when you add oil in the filler that it’s leaking down. |
