sb001 Samba Member
Posted: Thu Jul 05, 2018 6:25 am Post subject: gas smell is sickening |
NOT my vent lines because it wasn't doing this before swapping the H30/31 carb (which had its own problems) out for the 30 PICT 3 I'm using now- this issue seemed to crop up about the same time.
It's terrible. _________________ I'm the humblest guy on this board.
1600 SP engine
Solex 30 PICT 3 carburetor
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Thu Jul 05, 2018 6:30 am Post subject: Re: gas smell is sickening |
Check the trunk area. After removing my 1970's fuel tank for the first time after 46 years, I got leaks in the 48mm i.d. fuel filler hoses, even with the hose clamps tight.
I replaced those hoses with new, gas smell gone. Check the tank vent hoses too.
Your observation of the smell may be totally unrelated to your carb swap. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
sb001 Samba Member
Posted: Thu Jul 05, 2018 6:37 am Post subject: Re: gas smell is sickening |
Cusser wrote: |
Your observation of the smell may be totally unrelated to your carb swap. |
The only other thing I can think of that I did around the same time, is install a new radio and reinstall the wiring cover in the trunk. That's it--nothing else. When I had the 30/31, I had NO radio, just a big opening in the dash--yet no gas smell at all. I do those two things and BAM it's like someone doused me in the stuff. I can also smell it in the garage after driving the car so maybe there's a leak elsewhere but I already checked the filler hose AND the sender unit plate on the tank and nada. _________________ I'm the humblest guy on this board.
1600 SP engine
AlmostHeavenWV_VW Samba Member
Posted: Thu Jul 05, 2018 6:51 am Post subject: Re: gas smell is sickening |
sb001 wrote: |
Cusser wrote: |
The only other thing I can think of that I did around the same time, is install a new radio and reinstall the wiring cover in the trunk. That's it--nothing else. When I had the 30/31, I had NO radio, just a big opening in the dash--yet no gas smell at all. I do those two things and BAM it's like someone doused me in the stuff. I can also smell it in the garage after driving the car so maybe there's a leak elsewhere but I already checked the filler hose AND the sender unit plate on the tank and nada. |
Do you have the 'EVAP' system in place?
Didn't happen to pinch off the EVAP lines when replacing that wire cover? (if you have EVAP in place)
Maybe the lines which run across the front firewall and/or something in that system? Could possible get some leaking/sweating there? Maybe the tank outlet line worth a look-see? Just coincidental timing with your other projects? _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
Hatracks Samba Member
Joined: July 10, 2016 Posts: 664 Location: Renton, WA
Posted: Thu Jul 05, 2018 6:56 am Post subject: Re: gas smell is sickening |
sb001 wrote: |
Cusser wrote: |
Did you put in any new mounts or brackets when installing the radio? The gas tank is right on the otherside of that wall and its possible to use sharp screws and poke a hole in it when mounting stuff under there.....I dont want to talk about how i know that.... _________________ 73 Super Build |
Cusser Samba Member
Posted: Thu Jul 05, 2018 7:09 am Post subject: Re: gas smell is sickening |
sb001 wrote: |
Cusser wrote: |
Get underneath and check the flex fuel hose from the pan to the steel engine tube which goes through the front engine tin, you likely rarely check this.
Get underneath and check the fuel line under the tank to the pan, you likely rarely check this. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Cusser Samba Member
Posted: Thu Jul 05, 2018 7:10 am Post subject: Re: gas smell is sickening |
sb001 wrote: |
Cusser wrote: |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Thu Jul 05, 2018 7:15 am Post subject: Re: gas smell is sickening |
Did you break the vent hose or vent system vapor separator behind the fresh air box when installing the radio? _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
sb001 Samba Member
Posted: Thu Jul 05, 2018 7:50 am Post subject: Re: gas smell is sickening |
I suppose it's possible I did something vent-line related when installing the radio, as that line does cross over the trunk up under the dash, although it routes below that opening. I'll double check and see.
My car is a 69, it does not have the EVAP system or that vapor separator.
It's also possible it's an issue with the line from the steel tube coming out of the pan to the steel tube going into the engine bay- that line is a bit too short and so I had to route it up between the heat exchanger flap and the autostick clutch canister. I did check under the car for leaks and none to be found. _________________ I'm the humblest guy on this board.
1600 SP engine
SwagWagen Samba Member
Posted: Thu Jul 05, 2018 9:12 am Post subject: Re: gas smell is sickening |
What about the hard line in the tunnel? Maybe open the inspection cover under the back seat & take a whiff |
air-h2o-air Samba Member
Posted: Thu Jul 05, 2018 9:27 am Post subject: Re: gas smell is sickening |
use race gas...it smells good! |
bluebus86 Banned
RichNJohn Samba Member
Joined: April 07, 2017 Posts: 91 Location: Palm Springs, CA
Posted: Thu Jul 05, 2018 12:56 pm Post subject: Re: gas smell is sickening |
Check to be sure your gas cap is on correctly. I know you are way past that in your assessment. However, I just got back from the gas station and was smelling gas. Checked engine compartment first, no leaks, under car, no leaks, in trunk, no leaks. Walked around to passenger side and the fender and running board were covered with gas. Idiot move on my part... |
Frodge Samba Member
Posted: Sat Jul 07, 2018 5:34 pm Post subject: Re: gas smell is sickening |
Is your fuel pump leaking into the case? |
sb001 Samba Member
Posted: Sat Jul 07, 2018 9:01 pm Post subject: Re: gas smell is sickening |
Frodge wrote: |
No. _________________ I'm the humblest guy on this board.
1600 SP engine
hotsam Samba Member
Joined: December 02, 2015 Posts: 366 Location: Ashburn, VA
Posted: Sun Jul 08, 2018 8:54 am Post subject: Re: gas smell is sickening |
RichNJohn wrote: |
Check to be sure your gas cap is on correctly. |
Yup...I chased my tail for a week looking for the source of a sudden, over-whelming gas smell. The cap wasn't on correctly.
x1000 _________________ 1968 Beetle |
Cusser Samba Member
Posted: Sun Jul 08, 2018 9:34 am Post subject: Re: gas smell is sickening |
hotsam wrote: |
x1000 |
Funny, because these two things happened at same time for me, in my garage, overwhelming gasoline smell, about 20 years ago.
It turned out that the mechanical fuel pump on my '88 Mazda truck had intermittent leak AND the O-ring on my 1971 Super wasn't sealing well.
So new fuel pump for the B2200 and new fuel cap for the Super.... _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
calvinater Samba Member
Joined: September 06, 2014 Posts: 3331 Location: 802 The Pointless Forrest
Posted: Sun Jul 08, 2018 2:00 pm Post subject: Re: gas smell is sickening |
Any progress here ? _________________ "Albatross"! |
sb001 Samba Member
Posted: Mon Jul 09, 2018 8:40 pm Post subject: Re: gas smell is sickening |
I haven't messed with looking into it. It's not the gas cap, cause my 69 uses the metal cap that basically goes over the filler neck opening and twists into place (more like a radiator cap), not the screw on type. I've been using that cap for years so it was also in use during the no-smell period.
Once the fuel level in the tank gets down to half it smells a lot less. But there is also a residual smell from the car after it's been sitting in the garage, it's more of a sooty, gassy/oily smell. Oh well. _________________ I'm the humblest guy on this board.
1600 SP engine
