Fuel tank connection for 73' gas heater
Dougster43
Dougster43 is offline
PostPosted: Thu Jul 05, 2018 8:56 am    Post subject: Fuel tank connection for 73' gas heater Reply with quote
I'm just about to dive into the gas heater on my 73 thing. The previous owner had put in a new fuel tank and took out the fuel pump for the heater. I have a pump and bracket on the way, but I was hoping someone would have more info on the pump connection to the fuel tank.
There is a single connection on the bottom of the tank. Doe this get "teed" off to feed the fuel pump? Does anyone have a picture of the tank connection?
Thanks to anyone that would have some additional information.
vwwestyman
vwwestyman is offline
PostPosted: Thu Jul 05, 2018 10:45 am    Post subject: Re: Fuel tank connection for 73' gas heater Reply with quote
I don't have a pic, but yes it is just a T in there.
You'll want a filter for the fuel going to the heater, so I suppose you can either filter prior to the T and filter both heater and engine fuel, or if you have engine fuel filter out back, you can add one in the line to the heater.
I don't recall if the hose diameter between the tank and pump on a Thing is the same or not. If they are the same, it'll be reasonably easy to find a suitable T at a flaps.
If they are different, then it'll be a little more difficult to find an off-the-shelf T.
If you run into that, what I did when installing and Espar heater in my Bus was go to the ACE hardware store to the plumbing section. I found a little brass T with three threaded ends, and found three hose barbs that threaded into the T. I cranked them in tight, and also soldered the connections. Worked like a charm!
Dave Cook
Stuartzickefoose wrote:
I'm gonna punch vwwestyman then shake his hand when I meet him.
notchboy wrote:
Ill just punch you in the face. Wink
1973 Wild Westerner
My Thing
Wildthings
Wildthings is offline
PostPosted: Thu Jul 05, 2018 11:04 am    Post subject: Re: Fuel tank connection for 73' gas heater Reply with quote
It is pretty small line, maybe 3/16" or 5mm. I don't think there was a filter there originally other than the sock screen in the tank. Use either 30r14 or 30r9 hose in order to handle the ethanol laced fuel.
KAmes
KAmes is offline
PostPosted: Mon Jul 16, 2018 2:10 pm    Post subject: Re: Fuel tank connection for 73' gas heater Reply with quote
I originally put separate filters after the T and had some trouble, it was like the heater pump would lose its prime and the heater would time out before it got going. I changed it to a single filter before the T reasoning that the running engine would keep fuel without air bubbles present at the pump inlet, and haven't had trouble since.
