Ceckert64 Samba Member
Joined: September 16, 2015 Posts: 1963 Location: Manitowoc, WI
Posted: Fri Jul 06, 2018 10:56 am Post subject: VW made distributor, what year is it from |
Does any one know what type/year this distributor is made? No Bosch marking, just VW all over, is it rare? Thanks for the help!
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9770 Location: Oregon
Posted: Fri Jul 06, 2018 1:19 pm Post subject: Re: VW made distributor, what year is it from |
It's a Garbe Lahmyere. Bosch IIRC was having a difficult time supplying VW with distributors in the early 60's. VW developed that distributor to fill the gap in the supply chain.
The vac can ones are not so rare. Mechanical advance, Much more rare and valuable.
See page 4 of this link it has the information that you seek regarding what that distributor is.
https://www.thesamba.com/vw/archives/manuals/Bosch_Tune_Up_Parts/Bosch_Tune_Up_Parts.pdf
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Jul 06, 2018 3:32 pm Post subject: Re: VW made distributor, what year is it from |
The GL's are great distributors just little understood. The tune up parts and vacuum canisters are still readily available. GL was the back up supplier for distributors, coils, generators and starters starting in 1955 and ending sometime in the early 1970's. They are far from rare.
The sticker badges are now reproduced. The one on the right got wet being displayed at a show.
A group of GL's restored for a customer in Monterey
Caps and rotors will also fit the early Bosch 383's but the points and condenser will only work correctly with GL distributors.
Additional information can be found here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=457292&highlight=garbe
The vacuum advance distributors were installed on Beetle/Ghia/Bus from the late 1950's through the 1960's in small numbers. The Bus 211 mechanical advance distributors were installed in small numbers for domestic use only.
Distributors: there were three vacuum advance versions for the beetle/Ghia/Bus.
113 905 205 B August 1960- July 1965 40hp
113 905 205 J July 1964- July 1966 40hp
113 905 205 L August 1965= July 1968 1500cc _________________ Roads Scholar &
Posted: Fri Jul 06, 2018 3:52 pm Post subject: Re: VW made distributor, what year is it from |
67rustavenger wrote: |
Good Luck. |
Wow, I learn something new everyday. I had no idea IIRC was making Bosch distributors for VW back in the 1960's! _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
