richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Tue Aug 27, 2019 6:33 pm Post subject: Re: Scored a local 71 Westy |
Checked the valves today, didnt have to adjust one. All were spot on! I pulled exhaust and resealed it. The backfiring was caused by a leak at the heat exchangers. I cleaned everything up and used red RTV to reseal every joint. I also made a template for the front mud flaps, cut them out and installed them. And...wifey drove the bus for the first time, she was super proud.
Rotors and brake calipers looked good, although the steering box is leaking...
First time wifey driving a bus
_________________ __________
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Abscate Samba Member
Posted: Tue Aug 27, 2019 8:12 pm Post subject: Re: Scored a local 71 Westy |
Check that vacuum balance, its making the bus pull left..
.......Troll scuttles back under his bridge,,.... _________________ .ssS! |
Spike0180 Samba Member
Joined: June 06, 2015 Posts: 2269 Location: Detroit, Michigan
Posted: Wed Aug 28, 2019 5:55 am Post subject: Re: Scored a local 71 Westy |
Abscate wrote: |
.......Troll scuttles back under his bridge,,.... |
Oh shit, thanks for pointing that out. I had forgotten about vacuum balance for a minute. I was gonna adjust my brakes this week because my bus pulls a little when braking, but I should probably check my vacuum balance first.
... scurries nowhere. just gives a stink eye like a G waiting for you to react... Detroit style _________________ Brutis Patches Izabich: 1970 VW Transporter - 1776cc DP
Current State: Projects never truly end...
Other cars: 2003 F150, 2003 Jetta GLI vr6-6sp
Sambastic: adj; the quality of being nit picky, elitist, expecting everyone to do things the way they believe is best with no regard to situation, "sambastic" |
Posted: Sun Jun 07, 2020 4:12 pm Post subject: Re: Scored a local 71 Westy |
Been pushing oil past the pully seal. Turns out the new CB cases dont have galley restricter to the pully. JAD pulled the plug and machined a custom restrictor.
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Posted: Sun Jun 28, 2020 2:54 pm Post subject: Re: Scored a local 71 Westy |
Raised the rear another 3*. Rides way better now, personally I think it looks better and it should handle the weight of our vending gear better too.
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
FredH17 Samba Member
Joined: January 10, 2019 Posts: 27 Location: Netherlands
Posted: Mon Jun 29, 2020 5:11 am Post subject: Re: Scored a local 71 Westy |
Great build !! Love the big tires |
Bills85Westy Samba Member
Posted: Mon Jun 29, 2020 7:46 pm Post subject: Re: Scored a local 71 Westy |
Just read your build thread start to finish and really enjoyed how you brought this back leaving the patina! Even better if the wife enjoys driving it too! _________________ 89 Tristar Syncro Doka - White
85 Westfalia Syncro (conversion)
SAH 1.8T Conversion - 2005 AWP
Engine Conversion Thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=612144&highlight=
85 Doka L345 Grey - 1.9L |
Posted: Tue Jul 14, 2020 7:57 pm Post subject: Re: Scored a local 71 Westy |
I took the spice rack off the sink cabinet and installed it on the back of the passenger seat bulkhead. It flip up table was missing, but it still had the top and the hinges. The top was pretty beat up so I made a new top and table out of hard wood from HD. The locking rod was part of a trade I made with MTNbus last year. I stained it and polyurethaned it, looks pretty good.
I also got my CB Equalizer Pulley in the mail. I just need to have it installed, Zoom Zoom.
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build
Tbob Samba Member
Joined: May 26, 2007 Posts: 417 Location: Pensacola, Fl.
Posted: Wed Jul 15, 2020 4:06 am Post subject: Re: Scored a local 71 Westy |
In your mudflap picture, it shows rusty holes that would allow water to go into the rockers and other spots every time it rains and you drive. I would twist your arm to cover those holes, even temporarily, to keep more water from getting in there. You could clean off the undercoating, and even carefully applied aluminium tape could help until you can fix it right. If you don't get much summer rain where you are, it may not matter as much, but water intrusion where it shouldn't be is never beneficial. Or, a temporary fiberglass repair that you can grind off later when you get to the metal work. _________________ 1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps |
Manfred58sc Samba Member
Posted: Wed Jul 15, 2020 6:04 am Post subject: Re: Scored a local 71 Westy |
The table sure looks good! Hope you get some camping in this summer. _________________ Fat chick owner/operator |
Posted: Wed Jul 15, 2020 7:07 am Post subject: Re: Scored a local 71 Westy |
Tbob. No rockers, no problems
Manfred58sc. Thanks, Im doing little things to the bus these days got get it dialed while things are crazy in the world. Think Im gonna work on the paint, work on the factory parcel shelf I have, among some other small projects.
We went camping last weekend, pics in my adventure thread. It was great to be out with the family in the forest. _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Posted: Wed Jul 15, 2020 8:00 pm Post subject: Re: Scored a local 71 Westy |
After taking apart one of the OG parcel trays, I decided was no way I was gonna be able to successfully get them back together. They have been just sitting in the garage as I mulled over what to do. I went back and forth about buy one from BD or giving the OG one a go. I decided to take them to the neighborhood upholster, cause oddly enough there is an upholster in my neighborhood. He didnt have the same mesh, so we looked at what he had and I decided to go with a mesh like material that was tan to match the front seats. Picked them up today and he only charged me $40. I think they came out pretty good and cant wait to install them.
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Posted: Wed Jul 15, 2020 9:42 pm Post subject: Re: Scored a local 71 Westy |
Way to save a set for another day! Those turned out nice.
Simular modern mesh material can be found a Michaels in several colors. You can also buy a bag made for wet gear, like snorkel equipment, carpet cleaners hose and the like.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Joined: January 01, 2007 Posts: 16882 Location: sticksville, ct.
Posted: Wed Jul 15, 2020 9:52 pm Post subject: Re: Scored a local 71 Westy |
richparker wrote: |
Tbob. No rockers, no problems. |
but all you're doing is shoveling shit into the sliding door track. those are a REAL bitch to make right.
the top "slot" in your mud flap pic is the track, the lower is the rocker cavity if you will.
good to see you back posting _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Jul 16, 2020 2:13 pm Post subject: Re: Scored a local 71 Westy |
Thanks Skills. Im not concerned about shit getting into the rocker area, but the slider track is an issue. Ill come up with something, actually think I have an idea already. _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build
Posted: Sat Jul 18, 2020 1:58 pm Post subject: Re: Scored a local 71 Westy |
Had a fun family adventure to the VW shop today. We cruised out in the bus and I had the CB Equalizer Pulley installed. We also inspected the ball joints for play and greased them. The joints were within spec and there is only one torn boot. We are gonna replace the torn boot and install 6mm grease fittings in place of the plastic plugs. After completing the work I instantly noticed the difference with the pulley. Engine kept it speed more, there was less bogging on climbs and no oil spray! The steering was also noticeably smoother. Cant wait to get the boot replaced, new tire rods and drag link installed! It was a great morning, I always love spending time at JAD Machine!
CB Equalizer on the dope ass 2275! Dats a 6 pounder!
Ball joint inspection
Lil P getting in the mix and helping with the lug nuts!
Lil P in his natural habitat...
Hes about out grown the booster
VWs everywhere
All systems go!!!
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build
Posted: Sun Jul 19, 2020 11:13 am Post subject: Re: Scored a local 71 Westy |
Great pics, nice to see the next generation of VW mechanics in action ( lots of us are getting too old to do it much longer) _________________ Fat chick owner/operator |
Posted: Sun Jul 19, 2020 11:14 am Post subject: Re: Scored a local 71 Westy |
Took a trip to the local Ace Hardware last night and picked up 6mm x 1.0 grease zerks for the ball joints, some water proof insulation and some metal zip ties for the heater channel. This morning I installed all that stuff.
Think Im gonna put a few more ties on it then paint it with some undercoating. Samba member MTNbus turned me into this material.
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
