richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Sun Aug 12, 2018 8:35 pm Post subject: Re: Scored a local ‘71 Westy |
Thanks for the tip Aeromech, I will pick one of those up. I’m gonna have to pull the top to redo the rear wood section, fiberglass the crack, gel coat it and rebuild the brackets.
Found the OG rear screen, OG tire cover (it also still has the tire tie down strap) and the OG front curtain. I washed and dryed the curtain, it’s in pretty good shape. It has one small hole and it’s missing one of the snaps.
_________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
mtnbus Samba Member
Posted: Mon Aug 13, 2018 5:40 am Post subject: Re: Scored a local ‘71 Westy |
Great score Richie ! OG Paint ! Solid floors..
Totally awesome project ! Have fun with it |
Angus II Samba Member
Joined: June 01, 2016 Posts: 708 Location: Mammoth Lakes Ca. 93546
Posted: Mon Aug 13, 2018 2:49 pm Post subject: Re: Scored a local ‘71 Westy |
Hello,
I know this isn't your first bus, but.
Did you check for the childs cot in the recess above the closet and storage cabinet??. Reach in the space before the head knocker above the closet.
That is where mine was, along with the rear bug screen, all rolled up, like new.
Like I said before cool find and you got a great start(bones) on that bus.
Doesn't look like any collision damage, and you have doglegs, rockers and lower rear corners, from the pictures; so no rot from the looks of it. Yet, how does the underside look, any rust?. That nose and drivers door area looks the worst.
I looked up the place you got it from. Looks like a nice dry area.... Kinda like were I live and found my Bus. |
Manfred58sc Samba Member
Posted: Mon Aug 13, 2018 5:16 pm Post subject: Re: Scored a local ‘71 Westy |
Nice,nice..moving right along towards good times! _________________ Fat chick owner/operator |
xyzzy Samba Member
Joined: March 24, 2014 Posts: 229 Location: Encinitas, CA
Posted: Mon Aug 13, 2018 5:23 pm Post subject: Re: Scored a local ‘71 Westy |
Angus II wrote: |
Hello,
This is the correct location -- there's a strap that holds it in place there. The same style strap that holds the table leg to the table bottom. _________________ -----
1973 VW Westfalia 2L hydraulic, dual Solex PDSIT
1987 VW Vanagon Westfalia |
Posted: Mon Aug 13, 2018 10:10 pm Post subject: Re: Scored a local ‘71 Westy |
Angus II wrote: |
Hello,
It’s actually my fifth bus.
The bus is empty and there’s no cot, I looked everywhere. I was hoping to find it because the bars on the aftermarket one are super weak. I’m still holding out for the keys though, maybe I’ll find a hide away.
The driver side dog leg is destroyed and will be replaced. The passenger one needs some help and might get replaced if it can be returned close to its normal shape. Both rockers will be replaced and there’s a section above the driver side rocker near the outlet that needs to be repaired too. My current goal is to spray paint the replaced parts with the Krylon Dover White or Ivory, whichever looks closest. That use 1500 grit sand paper to blend the paint, we’ll see how it goes. The nose will get banged out the best I can, no bondo. But all that is a project for the springtime. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
scrivyscriv Samba Electrician
Joined: October 04, 2011 Posts: 2922 Location: Memphis
Posted: Thu Aug 16, 2018 8:31 pm Post subject: Re: Scored a local ‘71 Westy |
don't forget to pull the fresh air end covers to check for stuff POs stashed in the vents _________________ Robert in Memphis
Engine rebuild thread
If you're ever in the Memphis area, you are welcome to stop by for advice and help. |
Posted: Sun Oct 21, 2018 7:36 pm Post subject: Re: Scored a local ‘71 Westy |
Worked on the bus alittle this weekend. I pulled the front bumper, the steering box and the gas tank. I wanted to get the steering box and the tank out before I tarp it for winter. I’m gonna send the box out to Wolfgang to be rebuilt and I’ll clean the tank up while the bus is buried in snow. The bumper is not to bad, most of it can be reused. The body under the bumper is in good shape and it looks like I’ll be able bang out the dents in the nose. Both dog legs are toast, lots of rust and 3 of the 4 bolts that hold the wings on snapped.
The tank isn’t that bad looking
The OG hose looks great and is still playable, I’ll be reusing it.
Working in the dirt, laying on a blanket.
94,000 original miles... 😜
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Thu Jan 24, 2019 6:40 pm Post subject: Re: Scored a local ‘71 Westy |
So I sent the steering box out to be rebuilt a week ago and I recieved it back today. What, what, what?!?!? A week?
I’d like to give a big shout out and a big thanks to Aeromech for not only offering, but taking the time to do such an awesome job on the rebuild. It looks great!!!! If you guys have never spoke to or met Aeromech, he is a great guy. We, as the Bay Window community are lucky to have such a great guy among us.
It’s gonna be a few months before it gets installed as The bus is buried under 3’ of snow right now. Which makes for shitty Vdubing but epic skiing!!!
Looks great and feels just as good!
Who wants to go shred some powder??? 🎿❄️
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Mon Mar 25, 2019 8:40 pm Post subject: Re: Scored a local ‘71 Westy |
Little report. The engine has been torn down and was in pretty good shape. Looks like it could have been run for several more miles. The case is in good shape and it will aline bored, clerenced and machined for 94 positions. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Thu Apr 25, 2019 4:56 pm Post subject: Re: Scored a local ‘71 Westy |
A little update on progress. The snow is finally gone and I’ll be pulling the bus out of the back yard this weekend to start gutting and cleaning. The transaxle was torn down today and is in great shape. New Bearings and seals will be ordered from Arizona Transaxle. I was originally going to put a ZF LSD in it but I’ve decided not to because of the cost. No biggie, I’ve never felt I needed it before and I’m gonna put Grabbers on this bus.
Saturday morning I’m headed to the local VW graveyard to pull a bunch of parts the bus needs. Some of the things I’m looking for are bumpers, over riders, splash pans, screens, steering wheel, column, ignition housing, blinker switch, horn parts, head light bucket and a rim. Hopefully I’ll be able to find all those parts.
Hopefully things will be moving quickly in the next 2 months. I gotta get this thing road worthy before 4CORE, which is the last weekend in July. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Joined: January 01, 2007 Posts: 16879 Location: sticksville, ct.
Posted: Thu Apr 25, 2019 6:17 pm Post subject: Re: Scored a local ‘71 Westy |
rich~
ditch those over riders...they are super close to the body on a good day front and rear. 1 minor tap on the bumper and you have a nose that looks like yours does.
if you need any bits you can't find, let me know _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Posted: Thu Apr 25, 2019 6:20 pm Post subject: Re: Scored a local ‘71 Westy |
Yea, I understand the damage issue with the over riders. But, I like the way they looks. Besides if I don’t run them how else am I gonna hide the damage they’ve already created on the nose. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Sat Apr 27, 2019 8:23 pm Post subject: Re: Scored a local ‘71 Westy |
Today I went to the local VW graveyard, not an easy place to get into. Many of the buses and cars have been sold but there was still some stuff to be had. We spent about 2 hours talking, searching for parts and wrenching. After pulling the parts we went to a nice Mexican restaurant for lunch and some beers.
When I got home I pulled the bus out of the backyard and into the driveway. I was very careful and pulled it slowly as it doesn’t have a steering box installed right now, didn’t want to it make an unexpected sharp turn. Now that it’s in the driveway I can start working on it. Hopefully I’ll have some time tomorrow to to wrench on it a bit. I’m getting excited.
Shot of what’s left at the graveyard
Pulled the front bumper from this bus that rolled over
My spoils. Front bumper, steering wheel, column, ignition housing w/key, blinker switch, horn assembly, 4 hubcaps, passenger vent wing, rim, 3 jealousy screens, reverse lights, headlight assembly and 2 beauty rings. Not a bad score. I really need a rear bumper, but there was none to be had there.
Can’t believe there was a key in it.
All wires look good, we just unplugged them. The blinker switch has the same amount of wires, hopefully it will work. But the ignition switch won’t work, it doesn’t have the same amount of wires. The housing will work though, so that’s cool.
The current switch
The switch out of the ‘69 only has 3 wires
I could use a rear bumper, if you have one you’d like to sell to help my build let me know. Thx! _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22462 Location: Escondido CA
Posted: Sun Apr 28, 2019 7:01 am Post subject: Re: Scored a local ‘71 Westy |
notchboy wrote: |
Um, you didn't take the parcel trays?
You are dead to me. :fist: |
Ha, comedy!
The parcel trays are in my ‘71 not a bus at the graveyard. What do you know about them, are the factory or aftermarket trays? _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Posted: Sun Apr 28, 2019 8:07 am Post subject: Re: Scored a local ‘71 Westy |
Lucky you have access to parts that close ( I think I know where that is ) to you. Nothing like that here anymore. You will have a very nice Westy on the road soon. I would bet the miles shown are correct with no more than 192,xxx.
Keep both Bus's so your son can enjoy one! _________________ Fat chick owner/operator |
Posted: Sun Apr 28, 2019 8:15 am Post subject: Re: Scored a local ‘71 Westy |
Manfred58sc wrote: |
Keep both Bus's so your son can enjoy one! |
It’s not easy to get access to that yard. The owner moved and is rarely in the area anymore. He’s been selling off the cars and buses, and pickings were scarce.
As far as the miles go i think it just 94k. I say this because of the shape of the transaxle, CV boots and ball joint boots. All look factory and still in pretty good shape. But, if I’m wrong no biggie. It’s gonna get a new 2175, the transaxle rebuilt, new front end, brakes, tires, interior, etc...
Wish I could keep both, but I can’t. I wouldn’t mind a Bug though, that would be a blast. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
Bulli Klinik Samba Member
Joined: January 16, 2005 Posts: 2079 Location: Bulli Klinik, Colorado Springs
Posted: Sun Apr 28, 2019 9:22 am Post subject: Re: Scored a local ‘71 Westy |
richparker wrote: |
notchboy wrote: |
Ha, comedy!
The parcel trays are in my ‘71 not a bus at the graveyard. What do you know about them, are the factory or aftermarket trays? |
Those are Kamei Safety parcel trays. I had a set which originally came with my Dormobile. I have some identical fabric leftover from when I had to rebuild mine. If you come to the Brewery show, find me and I'll give it to you. I have it in the garage across the street from Bristols. _________________ I've never met a Bus I didn't like.
Mike K
Bulli Klinik
Colorado Springs |
Posted: Sun Apr 28, 2019 10:43 am Post subject: Re: Scored a local ‘71 Westy |
Bulli Klinik wrote: |
Those are Kamei Safety parcel trays. I had a set which originally came with my Dormobile. I have some identical fabric leftover from when I had to rebuild mine. If you come to the Brewery show, find me and I'll give it to you. I have it in the garage across the street from Bristols. |
Thanks for the info! I like the safety aspect and that the could be OG. But I gotta he honest I really like the cup holders in the plastic BD one in my ‘68. It’s a handy spot to put your beer on those off road excursions.
I think I’ll pull them out and see what it’ll take to rebuild them and go from there. _________________ __________
’71 Westy build
Adventure thread
’65 Deluxe Build
’63 Deluxe Build |
