richparker Samba Member
Joined: November 24, 2011 Posts: 6983 Location: Durango, CO
Posted: Thu Aug 26, 2021 4:58 pm Post subject: Re: Scored a local 71 Westy |
I Received my new collapsable camp sink today. It comes with a wash basin, drain pan and a bucket. Still dialing in the camp set up after all these years
Headed to the VW graveyard in Cortez tomorrow with Samba a member Mtnbus, stoked for that adventure!!!!! _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Manfred58sc Samba Member
Posted: Thu Aug 26, 2021 7:03 pm Post subject: Re: Scored a local 71 Westy |
Nice set up! I know where you are headed, say hi to the gang for me. _________________ Fat chick owner/operator |
Xevin Samba Member
Posted: Wed Sep 29, 2021 3:28 pm Post subject: Re: Scored a local 71 Westy |
2109cc???
Why? I know you got parts to do it. Is that the reason?
Great looking bug. Have a grand time RP. _________________ Keep on Busin'
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Clatter wrote: |
Damn that Xevin... |
skills@eurocarsplus wrote: |
SGKent wrote: |
Posted: Wed Sep 29, 2021 6:28 pm Post subject: Re: Scored a local 71 Westy |
Xevin wrote: |
2109cc???
Yup, going with a strokered out 2109cc. Having a lot of the parts already made the decision easy, but I want it to sleeper. Itll be a AS41 case, CB 76mm crank, CB 044 heads with doubled sprung valves, Mahle pistons, Berg 297-A high lift cam, Kaddies, real 009 with Petronix, Brosol fuel pump, CB 26mm oil pump with filter, Silverline main. bearings, Mahle double thrust cam bearings, CB straight cut cam gears and 9:1 compression. It should spin to about 6200 rpms. Zoom Zoom!
I have a build thread going in the beetle forum, the link is in my signature line.
It was towed to the shop today, hopefully Ill get it back in time to rip it up the the ski resort in a few months! _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build
Shonandb Samba Member
Joined: January 12, 2019 Posts: 1196 Location: Vancouver, BC
Posted: Wed Sep 29, 2021 6:29 pm Post subject: Re: Scored a local 71 Westy |
richparker wrote: |
Headed to the VW graveyard in Cortez tomorrow with Samba a member Mtnbus, stoked for that adventure!!!!! |
We have the same collapsible kit + a portable 5L camp shower and it works out great for doing the dishes. A small foldable wood table competes it.
_________________ *******************************
Previous 1973 Panel Bus:
Click to view image |
Posted: Thu Sep 30, 2021 7:57 am Post subject: Re: Scored a local 71 Westy |
That is going to be a fast Beetle, make sure it can stop ( not sure factory drum brakes will be up for the task). Nice pair! _________________ Fat chick owner/operator |
Posted: Thu Sep 30, 2021 10:31 pm Post subject: Re: Scored a local 71 Westy |
Manfred58sc wrote: |
That is going to be a fast Beetle, make sure it can stop ( not sure factory drum brakes will be up for the task). Nice pair! |
How fast can it really be? _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Posted: Sun Oct 03, 2021 9:24 am Post subject: Re: Scored a local 71 Westy |
Changed the oil (used Lucas Zink additive), oil filter, adjusted the valves and installed new cork valve cover gaskets. It was only 1200 miles since my last oil change but I wanted to change it before we head to Albuquerque on Friday for Buses and Balloons, which should be about 3 1/2 hours each way. The oil was pretty blacks and all the valves measured at .004, I set them all back to .006.
Just need to pack and we should be ready for our next adventure! _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Abscate Samba Member
Posted: Sun Oct 03, 2021 7:36 pm Post subject: Re: Scored a local 71 Westy |
richparker wrote: |
Which set is that Rich? Having trouble finding it. _________________ .ssS! |
Posted: Sun Oct 17, 2021 8:17 am Post subject: Re: Scored a local 71 Westy |
Ive been getting fumes in the cab at slow speeds while the heat is on. No issues at speed but under 50 it stinks! Figured it was a exhaust leak, so I grabbed some donuts and gaskets from the shop to fix the issue. I pulled the hitch, bumper, rear apron and the breast plate. There was a leak on the 1/3 side and the heater hose on the 2/4 side had a hole in it. I cleaned the area. Tightened the donut bolts and used RTV to seal the leak. It wast that big and I think the RTV will do the trick. Also replaced the heater hose and cleaned up the exhaust. I wiped down the engine and Ill change the oil and adjust the valves before we head off to SoCal.
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sun Oct 17, 2021 8:23 am Post subject: Re: Scored a local 71 Westy |
Hi Rich,
Regarding your bug, have you run a 009 with Kaddies before? If you have I'll shut up.
Best, Tom _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Sun Oct 17, 2021 10:56 am Post subject: Re: Scored a local 71 Westy |
Well, Im fooked...
Posted: Sun Oct 17, 2021 11:55 am Post subject: Re: Scored a local 71 Westy |
TomWesty wrote: |
Hi Rich,
Best, Tom |
Yes, I ran a very similar 2109 back in 2013 in my old 68 Tin Top. In the pic below you can see the Kaddies and the 009. This new 2109 will have the same heads, P&Cs and Kaddies that was on the old engine. The new 2109 will have a more aggressive cam and higher compression.
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Posted: Sun Oct 24, 2021 8:04 pm Post subject: Re: Scored a local 71 Westy |
Well, I had to take it apart again this weekend b/c I did not fix the exhaust leak last weekend. This time I removed the exhaust, cleaned everything and tried to figure out why it was leaking. Although I cannot be completely sure what was happening I found that the flutes were bent up and the donuts were not seating correctly. I bent them back into shape and made sure the donuts fit in the flutes nicely. Upon reinstall I used RTV on all the sealing parts to try and make sure it seals and doesnt leak. Hopefully it works, cant go to Cali with exhaust fumes in my heat.
Next weekend Ill change the transaxle oil, engine oil, adjust the valves and check the tire pressure. Then on 11/6 we head to SoCal for 15 days. We will be be Lego Land for 3 days and 4 nights and camping mostly at RV resorts on this trip. So far we have reservations in Kingman, Joshua Tree, LL, and Santa Barbara. I need to make one more reservation in Big Sur, they are only taking those over the phone and well be hoping for first come first serve camping in Monterey. We are all excited!!!
I got a hitch mounted cargo carrier for this trip. This should free up a lot of room in the bus and make everyone a little more comfortable. _________________ __________
71 Westy build
Adventure thread
65 Deluxe Build
63 Deluxe Build |
Posted: Mon Oct 25, 2021 8:58 am Post subject: Re: Scored a local 71 Westy |
What a fun trip!!! You will have a blast. It should be warm so not much need for heat once you are past the desert. Never had heat in my Bus, what's it like? _________________ Fat chick owner/operator |
DocNexil Samba Member
Joined: January 19, 2021 Posts: 145 Location: Southern Utah
Posted: Mon Oct 25, 2021 11:34 am Post subject: Re: Scored a local 71 Westy |
Legoland, eh?
I've been wanting to make a westy pop-top model for a bit and used your bus for reference since it's now relevant. _________________ 1971 Dormobile "Juliett"
1970 beetle "Rudie" |
