fcgadget Samba Member
Joined: August 21, 2017 Posts: 111 Location: Willow Glen, CA
Posted: Sun Jul 08, 2018 3:32 pm Post subject: steering rag joint |
I give up. Tried disconnecting the joint to remove the shaft, but could not get the shaft to budge. The clamp was loosened, the bolt pulled out, the shaft tuns in the coupling, but it would not come out.
So, I tried to put it back together. Lined up the divot for the bolt but could not get the two sides of the coupling to cooperate.
I did not mess with the steering box side, just the upper, which now will not slide down to allow the bolt to go through the divot in the shaft. Tried prying with screwdrivers and bars, but that did me no good.
Does anyone have any bright ideas?
I'm assuming that the steering box side has the same indexing divot that the upper side has.
OvalinAz Samba Mini Tech
Posted: Sun Jul 08, 2018 4:51 pm Post subject: Re: steering rag joint |
I would pull the bracket that holds the tube, pull the tube off, then un bolt the coupler from the shaft end. pull the shaft out and push the end back on and put the bolt back in. plus while its apart, you can fix the horn brush _________________ Dad's 4/55 Oval
8/56 Oval
5/64 French Notchback
12/62 French 11 Window Bus
Wedge VW
Pandraggers C.C. |
EVfun Samba Member
Posted: Sun Jul 08, 2018 5:01 pm Post subject: Re: steering rag joint |
I'd slip the clamp up and stick a fat screwdriver in the open slot above the coupler and then tap and wiggle it into pry the slot of the tube open a little. Don't get violent, but with patience and a little lube you should get the steering shaft off the male coupler.
I see it has moved about 1/4 inch. You are getting there! _________________
Wildthings wrote: |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sun Jul 08, 2018 5:08 pm Post subject: Re: steering rag joint |
Unbolt the T-fitting from the rubber coupler.
Move the steering shaft away from the steering box.
Take a hammer and knock the T-fitting out of the steering shaft _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Ovally Samba Member
Posted: Mon Jul 09, 2018 1:39 am Post subject: Re: steering rag joint |
You can try to heat it up carefully with a hot air gun/paint stripper.
Regards. _________________ VW Bug Oval 1953
VW Bug 1200 D motor
Porsche 911S MFI 1970
Mazda 929 Hardtop 1977
Mercedes SLC 180 Roadster 2018 |
jason Samba Member
Posted: Mon Jul 09, 2018 10:33 am Post subject: Re: steering rag joint |
Bushing up top by steering wheel probably off. Loosen column, put everything back where it is supposed to be then tighten. |
Posted: Tue Jul 10, 2018 9:58 am Post subject: Re: steering rag joint |
RARE AIR ??
what is the "T fitting"??
I see a clamp on each side of the rag joint, held tight with a U shaped bend-over strap. Buy nothing that looks like a T |
Joined: August 31, 2013 Posts: 12861 Location: North Carolina
Posted: Tue Jul 10, 2018 10:12 am Post subject: Re: steering rag joint |
Loosen the bolts holding the column to the bottom of the dash & push the steering wheel/column towards the dash & see if that's where your alignment issue is. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Tue Jul 10, 2018 3:37 pm Post subject: Re: steering rag joint |
Loosened the column hanger, and put a 3/4" pipe nipple on the steering wheel nut and whacked it with a hammer. That shoved the shaft into the right place.
Maybe sometime in the cooler future I will attempt the shft removal again.
Thanks for all your help!! |
