VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 10639 Location: Huntington Beach, CA
Posted: Sun Mar 31, 2024 8:57 am Post subject: Re: The 'Ol 55 |
tehillah1 wrote: |
Happy Easter Samba community.... |
Happy Easter man! Have a great day with the family! Only one of
My daughters will be over today. The oldest one will be with her boys family. Don’t get me wrong, I do not mind sharing her. But, I do miss her when I cannot see her. But it is good to see her grow up! The up and downs of being a parent!
And, my 101 year old grandfather passed away on Tuesday. Going to miss seeing him, ever. But I did make the voyage out to his house several months ago. But still going to miss him.
All that to say. Enjoy all of them while they are with you! Happy Easter! _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
tehillah1 Samba Member
Joined: August 23, 2009 Posts: 306 Location: Colorado
Posted: Mon Apr 01, 2024 7:13 am Post subject: Re: The 'Ol 55 |
Thanks for checking in Jimbo. 101 is long time to stick around. If you are any indication your grandfather had a rich and productive life and left a legacy that will continue long after you've done your 101...My kids are spread around so getting all together in one place at one time only happens now and again but we grab all the time we get together and hold on to it like the precious thing it is.
Out to the bug this morning...more sanding, stripping, beating little dents here and there on the fenders, doors, hood and decklid. I've got projects set up all over my shop. I'd like to be ready to shoot primer and sealer once the weather and temps allow....I think I see a dim light at the end of a long tunnel... |
Posted: Wed Apr 03, 2024 9:54 am Post subject: Re: The 'Ol 55 |
tehillah1 wrote: |
Lucky! But at least I am not seeing any rust! _________________ Jimbo
TDCTDI wrote: |
Posted: Thu Apr 04, 2024 6:55 am Post subject: Re: The 'Ol 55 |
Maybe that light I see are the pinholes in the rust repair... |
Posted: Fri Apr 05, 2024 9:22 am Post subject: Re: The 'Ol 55 |
tehillah1 wrote: |
Fiberglass filler (look up Duraglass) over epoxy primer, NOT BONDO! All good, IF you nail the open time on the primer! _________________ Jimbo
TDCTDI wrote: |
Posted: Fri Apr 05, 2024 9:50 am Post subject: Re: The 'Ol 55 |
VW_Jimbo wrote: |
Fiberglass filler (look up Duraglass) over epoxy primer, NOT BONDO! All good, IF you nail the open time on the primer! |
Good info, Jimbo, thanks. I haven't gotten acquainted with the primer/filler end of things. Open time on the primer makes sense. How about scuffing the primer up if the "open" window closes? I see your car in primer...I'm guessing you'll be scuffing things up before you fill, eh? I won't be getting to this phase until things warm up a bit more.
Jim |
Posted: Fri Apr 05, 2024 10:16 am Post subject: Re: The 'Ol 55 |
tehillah1 wrote: |
VW_Jimbo wrote: |
Jim |
Pretty sure you will need to expose the steel to apply the Duraglass (fiberglass filler) over any weld holes. Sand that to 120. Hit it with epoxy, then lay down some plastic filler of your choice. 120 to shape, refill and sand, repeat till you got it! Then lay a sand able primer down! Sand 220, prime, 320, prime, 400. Or something similar. Lots of variations of this same ritual!
And yes, I went with epoxy primer, knowing the car was going to sit for awhile. Epoxy is an awesome saltwater deterrent. Everything that is steel near the ocean start rusting, just being in the air. That salt component really accelerates the oxidation process! _________________ Jimbo
TDCTDI wrote: |
Posted: Fri May 31, 2024 6:03 pm Post subject: Re: The 'Ol 55 |
I got a set of correct running boards from Restoration Parts....Thanks Mika! These running boards are beautiful. I couldn't resist and had to bolt one up...that lead to quick bolt up of the front fender...
and then the rear... I had to draw the line at hanging the door. I'm looking at this and thinking "I could drive around in that..."
Plugging away at the tedious stuff...cleaning and prepping everything below the fender lines in hopes of getting everything below sealed up during the warmer weather.
I got one of those sandblaser things that work with a pressure washer and tried it out last fall before things froze up. Seems like it could do all the blasting that I need to get to where I want to be and without the dust. Its just about warm enough to break it out and see what I can do.
Going around and around the car panel by panel prepping, cleaning, finding things that still need attention. Still addressing rust in the wheel arches. This spot failed the sharpened punch test.
I'm wanting to mitigate all the rust that I can and then seal it all up and maybe get this body mated back to the pan before deep fall... |
markendee Samba Member
Joined: April 30, 2009 Posts: 292 Location: Kyabram, Australia
Posted: Fri May 31, 2024 7:09 pm Post subject: Re: The 'Ol 55 |
I would have to have bolted the running board up too Jim.
Looking so good, finish line in sight.
Keep it up.
Mark. _________________ Member # 145244 |
Posted: Fri May 31, 2024 9:29 pm Post subject: Re: The 'Ol 55 |
The addition of the running board makes it a Bug! Looking really good! _________________ Jimbo
TDCTDI wrote: |
Posted: Sat Jun 01, 2024 11:59 am Post subject: Re: The 'Ol 55 |
Thanks for looking in on me Mark and Jimbo...I'm doing my research on priming and sealing with a goal of having things sealed up this summer. I'd love to get the body mated to the pan...now that'd feel like progress. |
Posted: Sat Jun 01, 2024 4:29 pm Post subject: Re: The 'Ol 55 |
tehillah1 wrote: |
Yes it does! But then you realize, the pan has to be dropped so that you can prime and paint without having to mask off the pan! Ah, the Ying and Yang of auto restoration. Take it apart, fix something, put it all back together, then pull it apart, do more of something…..you get the idea!
Looking good! You ought to be in primer shortly! _________________ Jimbo
TDCTDI wrote: |
Posted: Thu Jun 06, 2024 7:24 am Post subject: Re: The 'Ol 55 |
This spot failed the icepick test...so more rusty metal to cut out and replace.
Done
Left rear wheel well ready for primer...
Dan22 Samba Member
Joined: August 30, 2019 Posts: 565 Location: Battle Ground, WA
Posted: Sun Jun 09, 2024 4:43 pm Post subject: Re: The 'Ol 55 |
Thanks for looking in on me Dan. I appreciate the encouragement...I should be able to get back into the shop this week sometime and get to work on the right side rear wheel well. My wife and two of my 4 daughters flew to Phoenix this weekend for a graduation ceremony for my youngest daughter who finished up her residency at the Mayo clinic...I sure don't travel as easily as I used to. |
Costa66 Samba Member
Posted: Sun Jun 09, 2024 5:14 pm Post subject: Re: The 'Ol 55 |
tehillah1 wrote: |
When you say, "Restoration Parts" who are you referring to? Can't find a website!
Thanks,
Josh |
Posted: Mon Jun 10, 2024 6:39 am Post subject: Re: The 'Ol 55 |
Howdy Costa.
Best parts I've purchased. They came from Virtanen Restoration Panels:
https://restorationpanels.com/product-category/oval/
I've purchased other panels from other vendors that didn't even come close to matching the parts I needed to replace in my 55. Virtanen's parts are the best I've received. I would add Wolfparts to the list of excellent parts and they have some panels that Virtanen doesn't.
https://wolfparts.com/?post_type=product |
Posted: Tue Oct 01, 2024 1:46 pm Post subject: Re: The 'Ol 55 |
Serious props to all the build threads out there that keep things up to date...Figuring out how I'm doing what's next overrides the documenting of what's going on... I get caught up in the scenery and forget to document the road trip. Summer has come and gone. October already. Where'd 2024 go? We've still got some beautiful fall days happening and the nights are getting nice and cozy.
I've finished all the necessary prep on the rear apron, rear fender wells and valance areas. Fixed all the little pin holes, welded up a few new spots needing some help, pounded out what need attention and scrubbed everything up for paint.
All the while it was a summer of classroom work, reading everything I could get my hands on regarding the successful application of epoxy primer.
Like everything else there's a learning curve that's been pretty but I finally got the gumption to jump in with both feet. Painting 101. I moved from the paint classroom to the paint shop (very loose description of the place where I'm applying the product).I'm a sprayer at best at this point but everything is moving in a productive direction. Mixing, spraying, fixing the low quality results of my lesson subjects (running board, rear apron inner, rear wheel wells) and re-spraying. Learning the doing by applying what I've read.
I got the back side of the valance as clean as possible and sealed it up with MasterSeries.
Then I sprayed the back end of the car with a couple of coats of epoxy primer.
And a couple of coats of epoxy primer on the backside of the apron I got from Larry.
Fitted and tacked the apron and then did a quick fit up of the fenders and rear deck lid. After some pushing and pulling and making everything line up satisfactorily I got the apron welded back in place on the car.
Everything fits up right.
I'm gonna move the rear end of the rotisserie back to the bumper brackets to better facilitate tipping the body up to access/prep and epoxy the bottom of the car. |
Dan22 Samba Member
TomVaughan64 Samba Member
Joined: February 02, 2023 Posts: 89 Location: California
Posted: Tue Oct 01, 2024 8:40 pm Post subject: Re: The 'Ol 55 |
Great looking work! MasterSeries seems like great stuff. I have tried to buy some but they are perpetually sold out. You have inspired to keep looking. _________________ Tom
"Begin with the end in mind"
Stephen Covey
"Keep focused and seeking knowledge, you will never find disappointed, only small hiccups!"
Jimbo
56 Old Speed Euro Deville Influenced Build Returning
Returning My 55 Ragtop To Stock |
