Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Mon Aug 06, 2018 5:04 am Post subject: Re: Pertronix No spark |
Rawq wrote: |
Also I forgot to mention the dizzy cap has a broken coil contact... probably the main problem all along.. |
That will do it. _________________ Glenn
Member #1009
#BlueSquare |
Rawq Samba Member
Posted: Sun Aug 05, 2018 7:51 pm Post subject: Re: Pertronix No spark |
Rawq Samba Member
Posted: Sun Aug 05, 2018 5:13 pm Post subject: Re: Pertronix No spark |
Well I ended up replacing the module but that still didn't fix it.. rechecked all my grounds and that as well as my fuel rail wasn't getting enough fuel to fire the engine.. So might have been a combination of a few things.. |
Glenn Mr. 010
Posted: Sun Aug 05, 2018 3:12 pm Post subject: Re: Pertronix No spark |
Rawq wrote: |
Thanks for all your comments, its up and running... |
Care to share what the problem was and the fix? _________________ Glenn
Member #1009
#BlueSquare |
Splitdog Samba Split Personality
Joined: February 16, 2004 Posts: 4125 Location: Planet VW
Posted: Sun Aug 05, 2018 3:02 pm Post subject: Re: Pertronix No spark |
GARRICK.CLARK wrote: |
As lingwendil says. UPGRADE to points |
Lol. To each their own..... _________________ CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker |
Rawq Samba Member
Posted: Sun Aug 05, 2018 1:14 pm Post subject: Re: Pertronix No spark |
ccowx Samba Member
Joined: May 15, 2015 Posts: 661 Location: Whitehorse Yukon
Posted: Sat Jul 14, 2018 9:54 pm Post subject: Re: Pertronix No spark |
I also second(third/fourth/fifth/?) the idea of giving everything a quick look over and then trying points. Ground, power to coil, gap, etc. If that does not work, you are basically down to the module. I have not used a Pertronix myself but I have certainly heard enough stories to know that they do occasionally crap out. That and the new distributors have a bad reputation and worth going through to make sure it is all ok inside.
Chris |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Thu Jul 12, 2018 10:41 am Post subject: Re: Pertronix No spark |
How's your ground strap?
My friend had one and it wouldn't start. Pulled my 009 out of my DC and installed it in his bug, started right up. His distributor worked in mine... I could only guess that he had some kind of electrical issue and his motor wasn't grounding or something. He previously had someone else just help him with a starter, and I was in nice clothes not about to crawl under it
The quality isn't there, make sure yours advances all the way (his didn't. that rubber grommet had to be trimmed) they really shouldnt be sold... _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
GARRICK.CLARK Samba Member
Joined: June 30, 2012 Posts: 1267 Location: Lancashire UK
Posted: Thu Jul 12, 2018 10:26 am Post subject: Re: Pertronix No spark |
Glenn Mr. 010
Posted: Wed Jul 11, 2018 5:01 am Post subject: Re: Pertronix No spark |
Rawq wrote: |
16 yrs into my restoration |
And you cheap out on a Chinese distributor? _________________ Glenn
Member #1009
#BlueSquare |
cbeck Samba Member
rugblaster Samba Member
Joined: March 31, 2016 Posts: 1172 Location: San Angelo, Texas
Posted: Tue Jul 10, 2018 10:33 pm Post subject: Re: Pertronix No spark |
Looks like you could throw a yellow dog through that air gap. _________________ '69 Karmy, '69 Camper, Meyers clone, '65 drag bug, 10.78 @ 128 (sold it) '51 Dodge farm truck,
'09 MB E350 '18 MB E400, '65 Plymouth Valiant convertible and a '19 Ford F250 King Ranch (nicer, but dirty, farm truck)
VWoA factory trained line tech 75 till 90 or so
ASE Master Certification
VWoA Assoc. of Quality Technicians inductee (One of 25 in the five state southwest region)
La Confrerie des Chevaliers du Tastevin (San Angelo Chapter)
TCU ......GO FROGS!!!!!! |
Dale M. Samba Member
Posted: Tue Jul 10, 2018 9:26 pm Post subject: Re: Pertronix No spark |
You should be able to put test lamp on negative terminal of coil, have someone spin the motor over and you watch test lamp, test lamp should flash on-off-on-off-on-off.... If coil has power and is good and module is good... IF you have power to coil and lamp does not flash (stays dark) you may have open coil or module bad... If lamp stay on (all the time) you have good coil and "open" in wiring or module (bad module) ...
modok Samba Member
Posted: Tue Jul 10, 2018 8:29 pm Post subject: Re: Pertronix No spark |
Spin the distributor, should make sparks if coil is hooked up. If you hook up a test light in place of coil, it should go on and off. it's just like a switch, or relay. Connects and disconnects the black wire from ground.
just testing the coil I don't like to crank the engine.
Just unbolt the distributor clamp and pull it up a little and spin it. Leave it IN the hole tho, so it's grounded. |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Volswagon Samba Member
Joined: December 29, 2009 Posts: 299 Location: Knoxville, TN
Posted: Tue Jul 10, 2018 8:05 pm Post subject: Re: Pertronix No spark |
Make sure that's a 3-ohm coil. There should be a .010" gap at the rotor pickup. I assume that red wire goes to the coil.
An overall pic might be helpful. _________________ I know the pieces fit, cos I watched them fall away.
Wanna hear God laugh? Just talk about your plans.
'75 Bus https://www.thesamba.com/vw/forum/viewtopic.php?t=697183&highlight= |
Rawq Samba Member
Posted: Tue Jul 10, 2018 7:05 pm Post subject: Pertronix No spark |
16 yrs into my restoration and I finally got time to finish the motor and install it.. Wouldn't you know it, everything went smooth until I cranked it over.. "No Spark" Everything is new (pics attached) I've ran all the normal tests (Ohm readings, test lamps on the coil, both pos. to neg, pos to ground)
All I can think of is that the ignition module is no good. This is my first time using an electronic ignition so excuse my lack of knowledge..
Is there another way to test the module?
