Engine extremely HOT
Page: Previous  1, 2
buffalovebus
buffalovebus is offline
PostPosted: Thu Jul 12, 2018 6:36 am    Post subject: Re: Engine extremely HOT Reply with quote
TomWesty wrote:
sjbartnik wrote:
Yes exhaust will be hot.
Yes the engine gets hot. It has fire inside.
I held back from this same comment when I first read the post. Thousands of explosions every minute tend to produce heat.... Cool
at a boy!
Wildthings
Wildthings is offline
PostPosted: Thu Jul 12, 2018 7:16 am    Post subject: Re: Engine extremely HOT Reply with quote
mpmitri wrote:
After driving it 30 minutes engine 113 degrees, exhaust pipe 330, and bumper 185.
A block temperature of only 113 degrees would be very low for an engine that had run for 30 minutes. Way too low to give good engine life, your is stuck in a perpetual "cold start" mode with can greatly shorten engine life. You want your oil to be above 160F as soon as possible after start up so that it doesn't collect water. Pretty much 212F is ideal oil temperature, plenty hot enough to boil off water and other contaminates and not hot enough to cause degradation of the oil.
Do you have a thermostat and working flaps? You should, VW put them there for a reason.
malcolm2
malcolm2 is offline
PostPosted: Thu Jul 12, 2018 8:01 am    Post subject: Re: Engine extremely HOT Reply with quote
mpmitri wrote:
I am just looking for thoughts.
Baseline temps cold sitting in 72 degree shade was engine 78 degrees, exhaust pipe 80, and bumper 78.
Again, I know I'm a dummy but any thought would be appreciated. Thank you!
All those 30-minute-running temps seem correct. Think about it. The head temp under the spark plug is normal at 350*F. So if the exhaust is 330*F you the CHT might be perfect. Wait, I just realized you might mean the TAIL PIPE.
I would check each exhaust port as close as you can get to the head while it is running.
My Toys: '75 Porsche 914, '86 VW MK1 Cabriolet, '92 Ski Nautique and now a 1972 VW Transporter Deluxe
xyzzy
xyzzy is offline
PostPosted: Thu Jul 12, 2018 8:03 am    Post subject: Re: Engine extremely HOT Reply with quote
maybe the laser temp is reading celsius here... 113 in celsius would be 235 fahrenheit which is a much more reasonable temperature for the top of the engine... 330 would be 626 fahrenheit which is more reasonable for the exhaust...no?
1973 VW Westfalia 2L hydraulic, dual Solex PDSIT
1987 VW Vanagon Westfalia
Wildthings
PostPosted: Thu Jul 12, 2018 9:28 am    Post subject: Re: Engine extremely HOT Reply with quote
Could be, he might also have read the temperature of the Type 4 fan shroud and block. FWIW I just read the temperatures on my Type 1 powered Thing after a couple mile down hill run in second gear. The temperature of the block below the oil pressure switch was 120F and the muffler was 165F.
buffalovebus
PostPosted: Fri Jul 13, 2018 7:22 am    Post subject: Re: Engine extremely HOT Reply with quote
Definitely Fahrenheit . And shot it on the block above the shroud.
CarlosZ
CarlosZ is offline
PostPosted: Sat Jul 14, 2018 9:24 am    Post subject: Re: Engine extremely HOT Reply with quote
Hows your oil?
Page: Previous  1, 2
Page 2 of 2
