Raymondo Samba Member
Posted: Wed Jul 11, 2018 8:06 am Post subject: Skid Plates |
Recently fitted a skid plate i bought from limebug to my 67 beetle.
I have had to use the original bolts as the ones supplied are too long.
I did contact them to ask about the problem. They said they would look into it but i haven't heard anything since i got in contact a couple of months ago.
They did say i could either pack out the bolts supplied with washers which is not ideal or i could use the originals.
I'm wondering if the original bolts will be safe to drive around on with the plate fitted? or if there are slightly longer than standard bolts available.
Cheers |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Wed Jul 11, 2018 8:28 am Post subject: Re: Skid Plates |
Welcome to The Samba!
Do y'all not have hardware stores with nut & bolt selections?
If what you've got ain't workin & your supplier ain't making good on it, you don't have much choice other than to do it yourself. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Mike Fisher Samba Member
Joined: January 30, 2006 Posts: 17970 Location: Eugene, OR
Posted: Wed Jul 11, 2018 9:50 am Post subject: Re: Skid Plates |
Put a nut on the long bolt & grind it down shorter with a 4.5" angle grinder. Taper the end a little with your 1/8" thick 4.5" wide grinding/cutting disc. The nut should come off pretty easily to clean up the thread. I buy just what I want new from Eugene Fastener that has every conceivable bolt/nut in stock or they will order them for you out of their Dorman etc catalogs! Our local Ace Hardware is well stocked too! _________________ https://imgur.com/user/FisherSquareback/posts
69 FI/AT square Daily Driver
two 57 oval ragtops sold
'68 Karmann Ghia sold
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed Jul 11, 2018 3:31 pm Post subject: Re: Skid Plates |
I have found that suppliers do not back some of their own products when they are not a standard application... for me, it was installing an engine mount on a bay-bus... standard bay bus engines had threaded holes in them to mount the engine and for the replacement type one engine, those threaded holes were not there and one had to use an adapter... incorrect bolts and no instructions came with the package.
Never encountered your problem, but it sounds similar to me. _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Chad1376 Samba Member
Joined: January 29, 2005 Posts: 1435 Location: Henderson, Nevada
Posted: Wed Jul 11, 2018 3:51 pm Post subject: Re: Skid Plates |
I had to look up the skid plate to understand the issue - it uses the lower front beam bolts.
Yes, they make longer beam bolts, for use with caster shims. My guess is they supplied these longer bolts in anticipation that many buyers also run caster shims.
The only way to know for sure if the stock length will work is to measure the thread engagement. You'll want the bolt threaded in at least the same distance as the bolt diameter (1.5x would be better.)
Barring that, use washers, or cut the longer bolts down to fit. _________________ My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22 |
Posted: Wed Jul 11, 2018 6:04 pm Post subject: Re: Skid Plates |
Chad1376 wrote: |
Barring that, use washers, or cut the longer bolts down to fit. |
I once had a VW publication called, VWs in severe conditions or something like that and it was how to equip your (mostly type 2) VW in places like the sandy desert, in the jungle where one had to drive-through (ford) rivers and etc... there was a chapter on where to place and how to fabricate skid plates... they were mostly welded on.
I made all my friends a copy of it... was really cool - like snorkel intakes for river conditions...
I once bought a 1987 S-10 with 4x4 and it had skid plates option - the best part was the S -10 could not fight it's way out of a paper bag... removed them and still have 'm around here...the one I removed blocked the oil drain plug. _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
Posted: Wed Jul 11, 2018 6:21 pm Post subject: Re: Skid Plates |
ZENVWDRIVER wrote: |
Somehow I doubt they took into account some of the other weaknesses, like the generator belt slinging water on/into the distributor or the Archimedes screw pumping water into the block. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
Posted: Thu Jul 12, 2018 6:47 am Post subject: Re: Skid Plates |
TDCTDI wrote: |
Somehow I doubt they took into account some of the other weaknesses, like the generator belt slinging water on/into the distributor or the Archimedes screw pumping water into the block. |
... I no longer have the publication. I sold it, last year and I really don't know how your concerns were addressed, but I bet they were, in some fashion... _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Jul 12, 2018 1:27 pm Post subject: Re: Skid Plates |
You might just replace a stock bolt with a new long one and see if it bottoms out.
It might not and there you have your solution. _________________
EverettB wrote: |
FU#5 |
