62kellison Samba Member
Posted: Wed Jul 11, 2018 12:52 pm Post subject: steering flex disc |
anyone know the proper size bolts (and grade bolt)for the steering column flex disc? 1962 vw dune buggy..thanx I got black disc not the red.i have heard the red r junk. |
slalombuggy Samba Member
Posted: Wed Jul 11, 2018 2:08 pm Post subject: Re: steering flex disc |
8mm grade 9.9 or 5/16 grade 5 will be fine. The rubber coupler would be long gone by the time you encounters forces strong enough to sheer either bolt
brad |
Posted: Wed Jul 11, 2018 2:22 pm Post subject: Re: steering flex disc |
slalombuggy ,thank you will pick them up tomorrow. |
MrGoodtunes Samba Member
Joined: May 14, 2012 Posts: 852 Location: South Florida
Posted: Wed Jul 11, 2018 5:50 pm Post subject: Re: steering flex disc |
Got my rag joint out of a Super Beatle at a salvage yard back around 1990; along with all 4 bolts, which had German locking nuts. Lock nuts today have a nylon ring at outer end. That's what came on my new tie rod ends. Things as crucial as steering components probably need to have lock nuts. |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16758 Location: State College, PA
Posted: Thu Jul 12, 2018 4:29 am Post subject: Re: steering flex disc |
Something you should look at. Many times on a buggy or if a car has had camber adjusters installed the steering box angle is wrong. What happens is that the flex disc is stressed too much. What I do is try to get the T fittings as parallel as possible by rotating the steering box. You may need to enlarge the notch in the clamp, if it has the indicator pins on the beam. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Thu Jul 12, 2018 4:32 am Post subject: Re: steering flex disc |
andk5591 ,thanks for the info.will be installing today I will dble check everything |
Posted: Thu Jul 12, 2018 4:36 am Post subject: Re: steering flex disc |
MrGoodtunes ,thanks for the info.i was wondering about that.wasnt sure if I should use lock washers or what,to prevent it from coming apart.i don't want to screw around when it comes to this I value my children and my life. |
57BLITZ Samba Member
Joined: June 12, 2012 Posts: 2385 Location: DEEK - U.S.A.
Posted: Thu Jul 12, 2018 6:31 pm Post subject: Re: steering flex disc |
andk5591 wrote: |
. . . get the T fittings as parallel as possible by rotating the steering box. You may need to enlarge the notch in the clamp, if it has the indicator pins on the beam. |
Great tip! _________________ Jesucristo es mi Seņor y Salvador! |
Posted: Thu Jul 12, 2018 6:37 pm Post subject: Re: steering flex disc |
Did not mention that you SHOULD double check the toe if you move the steering box. It may impact it.
And I use lock nuts for steering couplers. _________________ D-Dubya Manx clone - 63 Short pan,1914.
Posted: Thu Jul 12, 2018 7:01 pm Post subject: Re: steering flex disc |
ok will do thank u.adjusted the toe once already.if I have to do it again not a big deal. |
Posted: Thu Jul 12, 2018 7:07 pm Post subject: Re: steering flex disc |
can anyone tell me the bolt size for the top of my front beam.the two bolt holes sticking up that I am supposed to put front body mounts(z shapedmetal brackets) on,so the front end doesn't bounce around.they r the 2 big threaded holes on top towards the middle of the beam. |
Posted: Thu Jul 12, 2018 9:28 pm Post subject: Re: steering flex disc |
I think they are 10x1.5
brad |
Posted: Fri Jul 13, 2018 2:29 am Post subject: Re: steering flex disc |
thanks ill give it a try,worst case i got extra bolts that will get used on something |
