Fan Hub Oil Seal Installation Type 4
mygreenbus
mygreenbus is offline
PostPosted: Wed Jul 11, 2018 5:15 pm    Post subject: Fan Hub Oil Seal Installation Type 4 Reply with quote
'72, 1700cc. So, I have a leaking fan hub seal. It looks like a job I should be able to do, but when I look at Bentley, it calls for special tools to take the hub plate off and to put the seal back in. Is it really that difficult? Maybe I'm missing something? Thanks.
'72 Bus
SGKent Premium Member
SGKent is offline
PostPosted: Wed Jul 11, 2018 5:18 pm    Post subject: Re: Fan Hub Oil Seal Type 4 Reply with quote
it can be done without the special tools but first be sure that your breather isn't plugged.
Godspeed to all who undertake a journey in a VW Bus.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
* VW Buses and VW cars share many of the same systems but if you haven't owned a bus and maintained it for awhile, you really don't know how different it is.
1971 (sold)
1977
Wildthings
Wildthings is offline
PostPosted: Wed Jul 11, 2018 5:29 pm    Post subject: Re: Fan Hub Oil Seal Type 4 Reply with quote
Also check the oil pressure switch for leaks.
mygreenbus
PostPosted: Wed Jul 11, 2018 6:16 pm    Post subject: Re: Fan Hub Oil Seal Type 4 Reply with quote
SGKent and Wildthings, thanks...
'72 Bus
aeromech
aeromech is offline
PostPosted: Wed Jul 11, 2018 7:05 pm    Post subject: Re: Fan Hub Oil Seal Type 4 Reply with quote
Sure, the MM always call out for special tools. This job doesn’t require any. Many different things can be substituted. Reminds me of working on my 1991 Toyota truck years ago. There’s an electrical box Located in the engine compartment and they wanted you to use a Toyota special shop tool to jumper two contacts in order to read the flashes on the check engine light. A paper clip worked just fine.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Tcash
Tcash is offline
PostPosted: Wed Jul 11, 2018 9:26 pm    Post subject: Re: Fan Hub Oil Seal Type 4 Reply with quote
VW 185 For pressing off the hub of the fan from the crankshaft
Tcash wrote:
Type 4 Fan hub Puller
VW 190 For installing the crankshaft seal in the crankshaft on the fan side
1. Plastic cap of the appropriate size, with an 8mm hole drilled in the center.
2. 8mm bolt long enough to thread into the crank>seal>plastic cap>nut
3. 8mm Nut
4. 8mm Washer
Assemble installation tool as follows.
Bolt>nut>washer>plastic cap>seal
Thread bolt into crankshaft. Then use nut to press the seal in.
Wildthings
PostPosted: Wed Jul 11, 2018 10:27 pm    Post subject: Re: Fan Hub Oil Seal Installation Type 4 Reply with quote
A harmonic balancer puller works just fine for pulling the fan hub. Just thread the center bolt in a bit (but not even close to being tight) for something to push against.
