Dkwautounion Samba Member
Posted: Wed Jul 11, 2018 8:29 pm Post subject: My 1963 "field find". The " matador " from maricopa CA. |
Heres my 1963 sedan. Just dragged it home.
Found this cyclone exhaust in it.
Original seats
Wood kit and any guess on shifter? Found some formula vee lug nut caps in the trunk.
Posted: Wed Jul 11, 2018 8:32 pm Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
Cool sticker on the dash. Any infon would be awesome .
Tore out the interior
Trunk
More to come . Gonna replace the pans soon. Just ordered the bug me video volume 6. Comes on Saturday . I Found a DMV drivers test in the car from taft ca. A book and this 7 up bottle with opener. I have registration card from 1978 which wa the original owner. A "oil man" from maricopa ca.
Slow 1200 Samba Member
Posted: Thu Jul 12, 2018 1:59 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
this car is so cool! What are your plans with it? |
russ c Samba Member
Posted: Thu Jul 12, 2018 4:55 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
Nice gonna be watching!! |
TastyTuner Samba Member
Joined: March 11, 2010 Posts: 108 Location: Tulsa, OK
Posted: Thu Jul 12, 2018 5:47 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
very cool. looks like it will clean up nicely! _________________ TastyGarage |
slave1pilot Samba Member
Joined: February 22, 2010 Posts: 943 Location: Tehachapi CA
Posted: Thu Jul 12, 2018 6:19 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
I'd love the radio if you are gonna replace it lol
Nice find, it looks like a fun project _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
vwuberalles Samba Member
Joined: October 18, 2003 Posts: 1357 Location: Richmond, VA
Posted: Thu Jul 12, 2018 7:32 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
I'm going to preserve what I can. Interior will be new. Paint is gonna stay. I would like to have the radio working. I just bought Albert gravel guards and the door handle scratch protectors. Still debating on the wood kit on the glove box, ashtray , and around fuel gauge . |
mukluk Samba Member
Posted: Thu Jul 12, 2018 8:09 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
The "wood kit" looks like standard contact paper or shelf liner, shouldn't be too difficult to find new if you want to keep the look. _________________ 1960 Ragtop w/Semaphores "Inga" |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Thu Jul 12, 2018 12:51 pm Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
mukluk wrote: |
The "wood kit" looks like standard contact paper or shelf liner, shouldn't be too difficult to find new if you want to keep the look. |
Exactly- I don't see any slots die cut into the section covering the gas gauge panel. A PO just wanted the FV look but on the cheap- and without the gassy draft. _________________
EverettB wrote: |
FU#5 |
Posted: Thu Jul 12, 2018 2:17 pm Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
Then that stuff will be coming off asap. Any idea about this shifter?
A little clr on the decklid and a little wax.
Picture of the front
mukluk Samba Member
Posted: Thu Jul 12, 2018 2:35 pm Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
Wooden stair banister knob most likely. _________________ 1960 Ragtop w/Semaphores "Inga" |
Rome Samba Member
Joined: June 02, 2004 Posts: 9651 Location: Pearl River, NY
Posted: Thu Jul 12, 2018 6:34 pm Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
Looks like the stock, original shifter was cut down a bit. Stock shifter has a shallow "S" curve; yours does not appear to have the upper approx. 1/4 length. The wood knob could either be just friction-pressed onto the shifter shank, or glued on. My suggestion would be to lightly sand the knob, stain it the color of your choice, then apply 2 coats of urethane. Paint the shifter shaft semi-gloss black. Install a short-shift kit, painting the base black. While you have the shifter out, check the shift rod bushing in the tunnel. Very likely it is really worn so that the shifter feels sloppy. New bushing plus the short-shift kit will give a huge improvement in shift quality.
Consider cutting some thin lauan wood for the glovebox and the speedo surround panels, and staining them the color of your shifter knob. Trace the shape of the panels onto the wood and cut them out with a fine-blade jigsaw. Attach them with contact cement. With your dry climate, the lauan probably won't warp and get wavy as it would in high humidity areas.
Does the engine rotate freely? |
Posted: Thu Jul 12, 2018 7:39 pm Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
Heres the bottom of the shitter knob
Tonight I got all 32 bolts that hold the body down off. Plus 2 more for the shitter and 2 at the steering column connection. Wiggle the body loose. It will come off this weekend when I get help |
mukluk Samba Member
Posted: Thu Jul 12, 2018 8:21 pm Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
Dkwautounion wrote: |
Cool, a legit shift knob it is then... not sure why it'd be attached to a honey bucket, or where you'd bolt that down in a Bug (or why you'd have one in a Bug for that matter).
I'd echo the sentiment to clean the knob up and refinish it, bet it'd come out nice. _________________ 1960 Ragtop w/Semaphores "Inga" |
Rome Samba Member
Posted: Fri Jul 13, 2018 3:56 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
Thanks for the close-up shot of the shift knob. I remember a company named "Cal Custom" in the 1970's offered many dress-up items for domestic cars and VWs. The knob would either be specific for a certain car, or a shift knob like this would come with a few plastic inserts/collars that you'd insert into the knob hole and would shape itself over the shifter shaft's threads to hold it in place.
You've been busy with the body separation! I would not have expected the floor to have such a large rot-through coming from the dry Central Valley.
Do you also have active interest in DKWs, possibly even own one? |
Posted: Fri Jul 13, 2018 5:09 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
I do not own one and thanks for the pic. That's awesome |
Posted: Fri Jul 13, 2018 6:31 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
exactly.
My old '70 had that same knob on it .
also, the donor dash for my 63 had the same woodgrain
TBH, the woodgrain looks too well done to be shelf paper. I'm sure there were die-cut kits back in the 70's for bugs. _________________ My Photobucket for my Herbie Project - http://s1288.photobucket.com/user/TK-439/library/Herbie?sort=3&page=1
Currently:
1963 Ragtop Beetle
Previously:
1967 Beetle
1968 Beetle
1970 Beetle |
67ctbug Samba Member
Posted: Fri Jul 13, 2018 6:36 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
Cool Beetle! I’d leave the wood grain, looks cool. _________________ '67 Beetle L41
'74 Westfalia
'69 Plymouth "Adam-12"
'63 Ragtop
'73 914
'72 Dodge Wrecker
Go Cubs!
World Series Champions 2016
KentPS wrote: |
mukluk wrote: |
Joined: August 31, 2013 Posts: 12855 Location: North Carolina
Posted: Fri Jul 13, 2018 6:43 am Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. |
NOPE, not interested in seeing that. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
