My 1963 "field find". The " matador " from maricopa CA.
TDCTDI
Samba Advocatus Diaboli
TDCTDI is offline
PostPosted: Sat Aug 18, 2018 1:48 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
Are you planning on top coating the POR 15? Since it's on the pan it won't be as big of a problem but it isn't UV stable & will get chalky.
Dkwautounion
Dkwautounion is offline
PostPosted: Sat Aug 18, 2018 2:17 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
I wasn't planning on it, but how chalky are we talking ?
TDCTDI
TDCTDI is offline
PostPosted: Sat Aug 18, 2018 2:22 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
Like a dirty chalkboard. The great part about that shit is the fact that it's tough as hell, the bad part is that it's tough as hell. Not much sticks to it unless you scuff it & you'll wear yourself out trying to do that.
Dkwautounion
PostPosted: Sun Sep 09, 2018 9:47 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
duplicolor cast coat aluminum and clear coat. spent the entire day day with a pressure washer and and oven cleaner. didn't work for 40 year old baked on grease. get a small chisel and hammer and turn up the music . new gaskets on the trannay and painted the axle tubes and backing plates black. re did he rear bearing seals and new rear brakes
Dkwautounion
PostPosted: Tue Oct 02, 2018 7:17 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
tranny in and new rubber.
pandraggers single bag beam painted with duplicolor engine enamel .
Gurn Blanston
Gurn Blanston is offline
PostPosted: Tue Oct 02, 2018 11:14 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
Looks almost ready for Pebble Beach...
Mark Evans Premium Member
Mark Evans is offline
PostPosted: Wed Oct 03, 2018 1:52 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
Curious as to why you offset the axle boots in different directions?
'63 Ragtop
KTPhil Premium Member
KTPhil is offline
PostPosted: Wed Oct 03, 2018 3:05 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
Looks like he sort of overthinks those like I used to do (I have IRS now).
The seams should be at about 3 or 9 o'clock, so that the seam doesn't get stressed by the extremes of axle movement.
Now, as to why not both forward or rearward with the seams? Well, if you want the same side of the wavy flaps that seal with those screws, then you would do it as he did... otherwise one is "upside down", at least relative to the other.
And as to why 10 & 2, not 9 & 3, I suppose if the seam were to leak, this way it's a little above the centerline, and less likely to drip oil out, since it's above the "high tide line."
I bet he also will take the tip to shove the small end in about 1/4" or so before tightening the small end clamps; this also gives a little extra stress relief.
At least, that's my thinking... Wink
Dkwautounion
PostPosted: Wed Oct 03, 2018 6:25 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
I like the nut to be on the bottom side , weather its 10 or 2 I dont care to much . and yes I will shove it in a little lol.
Dkwautounion
PostPosted: Mon Oct 15, 2018 7:48 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
more progress. wire wheels, acetone, duplicolor.
Dkwautounion
PostPosted: Fri Dec 07, 2018 9:39 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
been working on the car a ton still. body on. picked up a dual port 1600 and some dual baby dellortos. i drove it around the block for the first time and boy does it feel good.
kabob
kabob is offline
PostPosted: Sat Dec 08, 2018 11:53 am    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
is the lower bar in the beam soiled or a spring pack?
Dkwautounion
PostPosted: Mon Dec 24, 2018 10:22 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
all the glass is in. I also installed the one piece "easy" headliner , which came out like crap. I'm gonna pay someone to redo it with the multi piece one , in cloth. drove the car around the block which felt like a huge accomplishment. all new fuel lines.
TDCTDI
TDCTDI is offline
PostPosted: Tue Dec 25, 2018 7:33 am    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
A very fine “Merry Christmas” to ones self. Very Happy
PostPosted: Tue Dec 25, 2018 5:03 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
Don't feel bad, I've heard of all the how-to videos too, I'll just pay for it also.
'63 Ragtop
thechief86
thechief86 is offline
PostPosted: Wed Dec 26, 2018 6:42 am    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
Just how crappy are we talkin?
I need to do the headliner in my car as well, but nobody within 100 miles will do it for me. I'd just like to get an idea of how bad it's gonna look when I do it, haha.
Would love to see some photos of it, don't be ashamed, lol.
"A poor workman always blames his parts... Ya gotta have skillz to hang junk." -johnnypan
TDCTDI
TDCTDI is offline
PostPosted: Wed Dec 26, 2018 6:58 am    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
The biggest problem with installing a headliner is the fact that after working so hard on the rest of the car & it's mechanicals, your hands will be transferring the oil that has saturated your hands when you're pulling, stretching, & holding a white piece of vinyl. Evil or Very Mad
Bryan67
Bryan67 is offline
PostPosted: Wed Dec 26, 2018 9:14 am    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
You could always wash your hands before trying to put the headliner in...
If you`re going to do something, do it right.
Dkwautounion
PostPosted: Wed Dec 26, 2018 11:44 am    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
well one mistake I made was I didn't have the headliner perfectly centered, the bow slips in the sleeve on the inside of the headliner , then when you hang the headliner make sure the amount of rod that is exposed out of the sleeve is the same on both sides. . hope that makes sense .
TDCTDI
TDCTDI is offline
PostPosted: Wed Dec 26, 2018 12:55 pm    Post subject: Re: My 1963 "field find". The " matador " from maricopa CA. Reply with quote
If you work with oily,greasy parts enough, it will permeate the skin & transfer to any surface that you have to work with, especially light colored fabrics, no matter how clean you think you've gotten them.
But if it's just a hobby & you only get into grease & oil once or twice a month (or year Rolling Eyes ) then you won't have such issues
Page 3 of 4
