60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sat Jul 14, 2018 2:51 pm Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant |
Glenn wrote: |
everyone that used wheel bearing grease had it slung all over the inside.
The problem is not that it doesn't lubricate, jut just doesn't stick as well as the correct product |
No, not a true statement at all.
and I have been using the correct lube all this time and it sticks without being flung all over. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76889 Location: Sneaking up behind you
Posted: Sat Jul 14, 2018 2:58 pm Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant |
60ragtop wrote: |
Glenn wrote: |
and I have been using the correct lube all this time and it sticks without being flung all over. |
Well, I guess I won't have to resort to finding an alternative for a few years.
garagebandking41 wrote: |
I was wondering why some 36hp parts are hard to come by. |
Actually there is a huge supply of VJU4BR8 cores. Now the vacuum canisters are still out there but the supply is drying up. Tuneup parts are another story since Bosch has continued to discontinue many of them.
While I love that you were able to take a worn part and recondition it, there are good used parts available for the next person who it looking for a easier alternative.
Rusty scale is the biggest issue. One of the parts that is often unusable is the upper shaft that has the cam and holds the springs. Rusty scale and pitting can cause the points rubbing block to wear quickly. Also i've seen some with deep gouges due to the owner not greasing the cam and the rubbing block wears down and the metal points contact the cam and damage it.
The mechanical part of the VJU4BR8 along with the mechanical only cast iron distributors are very robust.
_________________ Glenn
Member #1009
#BlueSquare
Posted: Sat Jul 14, 2018 3:01 pm Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant |
Why not sell some of that hoarded overstock to the people who think they need it _________________ Rick
tasb wrote: |
sb001 wrote: |
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Sat Jul 14, 2018 4:56 pm Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant |
Now Glenn, that's not fair or accurate. Muir wrote one of the best books on early VW repair. It has some misinformation and points I don't like or follow but he shouldn't be misquoted. The Bentley has errors in it too
I find plenty of cores with dried and semi dried bearing grease stuck to the inside bottom of the housings too. On a part that doesn't move much and doesn't rotate, pfff- why not. Obviously there are some applications where bearing grease is appropriate and other places where there are better choices, rather than just a blanket rejection. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
glutamodo The Android
Joined: July 13, 2004 Posts: 26306 Location: Douglas, WY
Posted: Sat Jul 14, 2018 6:50 pm Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant |
When it comes to lubing the bushings of the distributor, that's one thing. Motor Oil works its way up there for that over time, but a tiny bit of grease if you've taken it apart is fine. Now, motor oil will not wick up to the points rubbing block. Me, while I certainly own a tube of GOD APPROVED BOSCH GREASE, I didn't always have it. Hell, back in the day when I was a mechanic, the only time I used "Bosch grease" was on those expensive oddball Type 2 points from the mid 70s that came with a tiny packet of grease. The rest of the time I just used moly CV joint/wheel bearing grease, applied in moderation. I never had a problem with that.
I did see a few failures where customers did not use any lube, and with the shift to plastic rubbing blocks, FAIL. _________________ Andy T.
Glenn Mr. 010
Posted: Sat Jul 14, 2018 7:01 pm Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant |
60ragtop wrote: |
Why not sell some of that hoarded overstock to the people who think they need it |
I'm not hoarding, i plan on using it.
"they" say one tube will last a lifetime. not in my case, I go through a tube every 2-3 years depending how many distributor I rebuild. I like to use genuine Bosch parts and not resort to creative alternatives.
Member #1009
#BlueSquare |
Posted: Sat Jul 14, 2018 7:41 pm Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant |
A lifetime for an average consumer. You are not exactly a consumer, eh?
Does the fact that my tube of Bosch Grease is yellow make it better?
No, I think not, but then again, is my blue tube of moly any worse? it never failed for me.
Posted: Sat Jul 14, 2018 7:59 pm Post subject: Re: Bosch VJU4BR8 Distributor Contact Plate Lubricant |
Glenn wrote: |
I like to use genuine Bosch parts and not resort to creative alternatives. |
Hardly being creative by using what VW approves even tho you won't accept it
Aren't you one of the first to state get a manual and read it _________________ Rick
tasb wrote: |
sb001 wrote: |
