Komissar Samba Member
Joined: May 18, 2008 Posts: 894 Location: Bucharest, Romania
Posted: Thu Jul 12, 2018 2:16 pm Post subject: Question about custom (turbo) exhaust collector design |
Hello,
I am currently fabricating a custom exhaust for my '72 Type 3 Squareback. 1600 dp engine with dual stock PSDIT carbs.
This exhaust is sort of an experiment, I intend to use it for a blowthrough turbo in the end.
The turbo itself will be a small one, (for example one from a 1.5L diesel donor car) and I intend it to use it for bottom end boost, rather than high rpm boost.
The steel pipes I have used for fabricating the header have an ID slightly smaller than the ones used on the stock muffler system which is about the same diameter of the inlet opening of the turbo (the exhaust inlet) - I have chosen this diameter to get good exhaust gas velocity.
Now, regarding the collector header - should the "outlet" of the collector be slightly larger than the diameter of the incoming merging pipes (and incidentally larger than the inlet of the turbo) or should it be the same diameter?
Thanks in advance. _________________ 1965 Sunroof Beetle
1972 Type 3 Squareback
1978 Skoda 105S
jpaull Samba Member
Joined: February 22, 2005 Posts: 3460 Location: Paradise, Ca
Posted: Thu Jul 12, 2018 2:34 pm Post subject: Re: Question about custom exhaust collector design |
I suggest you include "Turbo" in your thread title. That way all the Turbo Junkies will get all excited and give you some input.
Such as:
Question about Turbo custom exhaust collector design |
Posted: Thu Jul 12, 2018 2:38 pm Post subject: Re: Question about custom (turbo) exhaust collector design |
Thank you I have just done that. _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
clonebug Samba Member
Joined: January 29, 2005 Posts: 4027 Location: NW Washington
Posted: Thu Jul 12, 2018 8:14 pm Post subject: Re: Question about custom (turbo) exhaust collector design |
In my personal experience.......I found it doesn't matter much what you have for a exhaust as long as it pushes it through the turbo.
I've been running a cheap......actually free......sedan header with a 2 inch outlet flange up to my turbo for quite a few years. It performs pretty well.
I suppose if you had a race car and were trying to extract every once of performance out of it you could do better if you wanted to spend big bucks on a professionally built header or build one yourself out of many bends but I doubt the the difference would be worth the money unless a couple tenths of a second would make or break your reputation.
Here is my header...... A cheapa** sedan header with thin flanges.....
This is what I started with in 2011....
Here is the same header with a new up-pipe for my third turbo upgrade.
Here is the same header 7 years later supporting 24 lbs. boost and over 200 whp.
My turbine inlet is 1 7/8ths inch and my turbo up-pipe is 2 inch......the inside diameter of the 2 inch up-pipe pretty well matches the turbos turbine inlet.....I would try to keep it the same. or flare it up or down into the inlet to match. _________________
vwracerdave wrote: |
Take a good long look in the mirror and report back on what you see. |
Paul.H wrote: |
That one line on that chart is probably better info than you can get from this place in a month |
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936 |
theKbStockpiler Samba Member
Joined: July 07, 2012 Posts: 2316 Location: Rust Belt
Posted: Fri Jul 13, 2018 4:28 pm Post subject: Re: Question about custom (turbo) exhaust collector design |
You should use a Merge Collector if possible or use an actual Collector which is going to be significantly larger than your primaries. Otherwise you will not have a scavenging effect. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Use all safety devices including a mask. |
tripicana Samba Member
Joined: February 13, 2003 Posts: 1164 Location: colorado springs
Posted: Fri Jul 13, 2018 4:36 pm Post subject: Re: Question about custom (turbo) exhaust collector design |
I cut up and used a S&S type 3 header.
Had to add a few bends I got from an exhaust shop.
More pics in my gallery.
_________________ foam cowboy hats aren't good helmets. |
modok Samba Member
Joined: October 30, 2009 Posts: 26781 Location: Colorado Springs
Posted: Fri Jul 13, 2018 5:14 pm Post subject: Re: Question about custom (turbo) exhaust collector design |
I don't really understand the question.
It should be obvious that steps, sharp corners, and sudden changes in cross-section, and mismatches ect, should be avoided. The center line of the primaries should be aimed at the inlet of the turbo. It isn't highly critical, but if you can get the details right...it will help slightly.
What taper to use exactly, I don't really know. I'd lean towards about 7 degrees, (about a 1/4 inch per inch) but not totally sure. Maybe a little sharper? |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4278 Location: deepest, darkest Switzerland
Posted: Fri Jul 13, 2018 10:10 pm Post subject: Re: Question about custom (turbo) exhaust collector design |
From what I understand (or maybe don't), SHORT trumps over equal length. |
Posted: Sat Jul 14, 2018 1:51 am Post subject: Re: Question about custom (turbo) exhaust collector design |
If the primaries are not close to equal length it is not a header and IS a tubular exhaust manifold. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
modok Samba Member
Posted: Sat Jul 14, 2018 2:33 am Post subject: Re: Question about custom (turbo) exhaust collector design |
The term does not seem to have a specific definition in American english.
Example: Zoomie header, is a OLD term for a streamlined tubular manifold. |
oprn Samba Member
Joined: November 13, 2016 Posts: 12708 Location: Western Canada
Posted: Sat Jul 14, 2018 5:00 am Post subject: Re: Question about custom (turbo) exhaust collector design |
FreeBug wrote: |
^^^ This makes sense to me when under boost. Get the exhaust gasses to the turbo quickly before they cool and lose velocity.
Equal length and primary tube length for better scavenging would only apply under light loads pre boost - not? Once the turbo is loaded up and boosting the back pressure in the exhaust system would cancel any scavenging effects?
Perhaps there is a compromise between efficiency of the system on/off boost?
I don't know the answer, just wondering out loud.
The first turbocharger book I bought years ago the author felt there was little advantage to "tuning" an exhaust system in a turbo application but I bought his second updated book later and the subject was not covered in that book at all. |
Posted: Sat Jul 14, 2018 5:57 am Post subject: Re: Question about custom (turbo) exhaust collector design |
Quote: |
The term does not seem to have a specific definition in American english |
This is the term I hear used for when the original manufacturer of the car just connects all the exhaust ports up using the least amount of tubing instead of cast iron to get the exhaust gases to the rear bumper of the vehicle.
Quote: |
This makes sense to me when under boost. |
Just because an obstruction is going to create static pressure doesn't mean you can't create a lower pressure area somewhere using dynamic pressure. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
oprn Samba Member
Posted: Sat Jul 14, 2018 6:15 am Post subject: Re: Question about custom (turbo) exhaust collector design |
theKbStockpiler wrote: |
Just because an obstruction is going to create static pressure doesn't mean you can't create a lower pressure area somewhere using dynamic pressure. |
I will agree with that but the higher the back pressure the less it would matter? If for example you had 1 psi difference at atmospheric pressure would that 1 psi be noticeable with 25 psi back pressure?
Maybe it is not a linear relationship or that simple.
I'm just thinking that there is a trade-off between having a perfectly "tuned" system and losing exhaust gas temp/velocity. |
Posted: Sat Jul 14, 2018 6:51 am Post subject: Re: Question about custom (turbo) exhaust collector design |
If pressure was just all the same type you could block off the exhaust intentionally but the exhaust gas has to be moving to spin a turbine. The scavenging effect creates two separate pressure zones in the exhaust.
When the cylinder 'blows down' it removes the spent fuel charge which is helped with a tuned exhaust and or a header with a collector/merger-collector. With a turbo engine this is going to be worse because the spent fuel charge is going to be greater and have more mass. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
oprn Samba Member
Posted: Sat Jul 14, 2018 7:11 am Post subject: Re: Question about custom (turbo) exhaust collector design |
So your theory then is that a tuned system is more important in a turbo application than an N/A one? |
Posted: Sat Jul 14, 2018 7:43 am Post subject: Re: Question about custom (turbo) exhaust collector design |
No because power is made or wasted in more than one way.
My theory is that an exhaust should not be like plumbing. If you want a low cost/performance turbo exhaust for many people that is fine because they can turn up the boost. Cutting a 90 degree fitting in 1/2 , making it a 45 degree and welding them together at an angle does not create a smooth transition for example but did not have to be custom bent. The separate pieces are just being connected at this point. _________________ My beetle is not competing with your beetle. I have the yellow beetle in my town. There is a red one, a green one ......
Coyotemutt Samba Member
Joined: June 16, 2017 Posts: 360 Location: Pecos, New Mexico
Posted: Sat Jul 14, 2018 7:50 am Post subject: Re: Question about custom (turbo) exhaust collector design |
clonebug wrote: |
Okay, would you just stop tempting me? Lol! Your posts are like eye candy.
I got a turbo off of a Subaru legacy, for free, that would work great for this, but I don't actually NEED that kind of power in my offroad car... |
Posted: Sat Jul 14, 2018 9:33 am Post subject: Re: Question about custom (turbo) exhaust collector design |
Coyotemutt wrote: |
clonebug wrote: |
Nobody needs boost......
Well....I digress.........
You can build or spend any amount you want for a turbo header but the end result is you need to get it through the turbo....no matter how many big words you use to describe it.
Do it as cheap as possible first to get a taste of boost and then once the addiction takes over you can sell your children to increase the boost.
Boost is boost and there is nothing like it when it hits 24 lbs......
My definition of lag is the difference in pull from when it hits 18 lbs at 3300 rpm and pulls even harder at 3800 rpm and 24 lbs.....
If you are planning on running 6.0 lbs on the stock Subaru wastegate you can just do like I did and bolt a 2 inch flange to the offroad style header and build a short up-pipe to the turbo.
The Subie turbo is ideal for a baja or buggy since it is clocked from the factory for exhaust going in the bottom and the outlet going horizontal.
You can get a clocking bracket for the TD04L-13T that will turn it 70 degrees up like mine is and still use the stock wastegate if you want to install an intercooler.
My advice is build an exhaust like mine and spend the money on a way to keep intake temps down. You will gain more hp that way than some fancy header system that costs $500.00 for a minimal return.
If you are offroad just use the offroad baja header with a really short up-pipe.
I originally tried one but it was bent and I cracked it trying to straighten it.
The sedan header was free so I used it.
Here was my first try with the Baja header.......it didn't work out like I wanted so on to plan B....
Paul.H wrote: |
Audi TT intercooler
EcuMaster PMU16
oprn Samba Member
Posted: Sat Jul 14, 2018 1:05 pm Post subject: Re: Question about custom (turbo) exhaust collector design |
I agree with clonebug, the difference in exhaust systems with turbos is small and hard to quantify without controlled conditions. Boost pressures and intake temps are the biggest bang for your buck. You can feel that any time of the day!
I didn't have an intercooler on mine and on a hot summer day it would get into detonation at 8 psi while in the winter at -30 it would go well over 15 psi with no issues. |
Posted: Sun Jul 15, 2018 12:49 am Post subject: Re: Question about custom (turbo) exhaust collector design |
Thank you all for your input and the useful information provided.
Regarding the above mentioned intake temps, i guess that other then keeping boost levels as down as necessary, for a type 3 Squareback water injection might be a solution, since there is no room for an intercooler back there. _________________ 1965 Sunroof Beetle
1978 Skoda 105S |
